Old 02-08-2014, 06:59 PM   #3481
MR.P
MR.P is an unknown quantity at this point
hello again guys. I recently changed my headgasket in my stock jdm 2jz-gte. its a toyota HG with arp studs. The problem is that it would not run. It was running good before HG replacement exept that I had exhaust gasses in the radiator. It has spark and fuel
I had some problems with the Coolant Temp ECU Sensor before. It would not idle sometimes and when I took the plug to that sensor out and put it in couple of times, it would idle fine.
When I try to start the motor now, is it misfiring, backfiring. somtimes it cranks but nothing happens. sometimes it will start a couple of seconds with a rough idle and if I hit the pedal it will die. I checked the timing and the crank pulley is lined up and the camgears to. I checked the ground cables and all sems grounded... But the one to the engine hanger bolt isnt there. I dont remember if I had that wire. I think so but im not sure and I cant find it haha
So what do you think guys? can the problem just be the Coolant Temp ECU Sensor or is it something else? Thanks
MR.P is offline   Reply With Quote
Old 02-08-2014, 07:10 PM   #3482
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
Sounds like timing is off. You make sure your crank angle and cam sensors are plugged in?
Follow me on Ig- Andydennington
91ka24 is offline   Reply With Quote
Old 02-08-2014, 07:38 PM   #3483
PoorMans180SX
PoorMans180SX's Avatar
Originally Posted by 91ka24 View Post
I went from sr to 2j and surprisingly i didn't feel a difference. I'm running bc coils with 8k springs too. And this is just my drift car
Originally Posted by di-devol View Post
I am a little worried about it. I dunno how much 200+- lbs in the front will affect the handling. I was thinking of upping the spring rate to at least 9-7.
Originally Posted by xoxide View Post
I jumped from an SR to 1j... definitely a big difference. I am sponsored by Fortune Auto so I spoke to Terry over at FA quiet a bit about it, and ended up bumping from 9k front springs to 11k fronts. Ill know how much of a difference they make next weekend.
Thanks guys, kinda funny that one guy says big difference and the other says he didn't notice, hahaha.
Xoxide, definitely let us know how it goes with the spring change.
I'd like to hear from anyone else as well, especially if they can give specific examples of how it affects things. I have a VQ35 in my car now, and I plan to rock it for at least a season, but I'm going to want more power eventually, and a 1J seems a lot more budget friendly when it comes to making good numbers.
Old 02-08-2014, 07:55 PM   #3484
Night drifte89
Night drifte89's Avatar
Night drifte89 is an unknown quantity at this point
Lol went from a honda 1.6 to a 1j here
Night drifte89 is offline   Reply With Quote
Old 02-09-2014, 04:44 AM   #3485
MR.P
yes they are plugged in. It sound like you say that the timing is crazy. Can I maybe installed the cams wrong or something?
Old 02-09-2014, 05:32 AM   #3486
91ka24
91ka24's Avatar
Well the intake cam looks totally different then the exhaust cam because of the notches for the cam angle sensors, so hopefully you put them in right
Old 02-09-2014, 07:08 AM   #3487
MR.P
yes you are right. I did get it started. I changed the cam sensor wires. the plug is gone so I have two wires. I changed them and tested them yesterday and it did not work. I change place again and it started up.
But it will not start when the ecu coolant temp sensor is plugged in. Unplugged it will start but I must rev a bit to not let it die. Is it just to change the sensor?
I also have some exhaust leak from the exhaust manifold.
Old 02-09-2014, 07:55 AM   #3488
91ka24
91ka24's Avatar
You should be able to start it with the CTS unplugged with no issues. A bad cts usually causes long start up's and can pull timing when making over a certain % in throttle
Edit: first check the ohm reading on the cts, if it's not in spec per the fsm, then replace
Old 02-09-2014, 09:16 AM   #3489
MR.P
okay. but the strange thing is that it will start with the CTS in now. Checked some vaccum hoses and now it runs perfectly (i think). the check engine lamp is now on tho. It didnt work to pull out codes when I connected e1 with te1.
The exhaust leak that i thought I had did not smell exhaust gasses. its maybe some oil or something that i spilled.
I tried to bleed the water system but the lower hose is cold. The thermostat is new.
I took a funnel at the radiator cap place and filled it up. I could see the air coming up and the temperature needle was in the middle. but the lower hose was cold. when I took it to 1500 rpm the water level rised, and when I shut of the engine the water pushed out a bit from the radiator. I didnt raise the front of the car. how can I bleed it correctly so I dont have air in the system and why is the lower hose cold? Thanks
Old 02-09-2014, 04:04 PM   #3490
supercompact
supercompact is an unknown quantity at this point
2JZGTE Swapped S-Chassis thread
Make sure you plugged your coil packs in the right sequence also. Fuel injectors too.
supercompact is offline   Reply With Quote
Old 02-09-2014, 04:21 PM   #3491
Night drifte89
is there a difference in this part? between front sump and rear sump? bolts to the upper oil pan on the turbo side.
Old 02-09-2014, 04:22 PM   #3492
Night drifte89
1j non vvti^^
Old 02-09-2014, 05:19 PM   #3493
MR.P
How do I know if the coil packs are right? Fuel injectors are correct
Old 02-09-2014, 05:22 PM   #3494
93egallmotor
93egallmotor's Avatar
93egallmotor is an unknown quantity at this point
pull out your wiring diagram and check the colors of the wires against the sequence in the diagram. all the grounds are the same so you need to pay attention to the hot side colors
Zenki s14 1 J Z- G T E
93egallmotor is offline   Reply With Quote
Old 02-09-2014, 05:25 PM   #3495
supercompact
On the factory harness, it should be pretty obvious, but if you're on a custom harness, you'll probably have to trace them back to the ECU to make sure you have them in the correct order.
Old 02-09-2014, 05:25 PM   #3496
MR.P
Ok will do that thanks!
Old 02-09-2014, 07:54 PM   #3497
RickS14
RickS14's Avatar
RickS14 is an unknown quantity at this point
Originally Posted by CooleyXXXIII View Post
Yeah I'm having the same problem Attachment 66595
Damn I have zerolift mounts also.did you follow instructions that came the mounts cause that looks way off?!?!man call zerolift cause that doesn't look good at all.
RickS14 is offline   Reply With Quote
Old 02-09-2014, 08:08 PM   #3498
CooleyXXXIII
CooleyXXXIII is an unknown quantity at this point
Yeah I've have a bunch of
Issues with these but it's alright my friend bought them from me
Insagram: CooleyXXXIII
CooleyXXXIII is offline   Reply With Quote
Old 02-10-2014, 05:02 AM   #3499
kenarm88
kenarm88 is an unknown quantity at this point
my swap pixs. you can see the motor slitly off
kenarm88 is offline   Reply With Quote
Old 02-10-2014, 07:16 AM   #3500
RickS14
RickS14's Avatar
Wow that's not right..do you have the v2 mount cause i thought they changed a couple things.Is anyone else having this problem?i haven't used mine yet I'm supposed to set my engine in next month.
Old 02-10-2014, 08:18 AM   #3501
kenarm88
I'm not sure if I do or not. I'm thinking I need to change my ka motor mounts out to a fresh set and maybe that will help some.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Old 02-10-2014, 08:46 AM   #3502
RickS14
RickS14's Avatar
I went with a solid mounts. I will post pics when mine goes in. Also I went with xcessive Trans mount I had to notch the rear of the zerolift Trans bracket.
Old 02-11-2014, 03:11 PM   #3503
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
Originally Posted by PoorMans180SX View Post
Have any of you switched from an SR or KA to a 1J or 2J with the same suspension setup and can make some comments on how the handling changes?
I noticed a difference. With my car being as low as it is my tires would rub my fender wells when hitting a bump on the highway. When I had my ka-t at the same height I never had "rubbing" issues.
Took it to a drift event and I would keep spinning out on a 3rd/4th gear sweeper. Granted I DIDNT have a front sway bar.
Think I have 8k spring rates in the front, cant recall
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 02-11-2014, 07:09 PM   #3504
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
so, is anyone interested in some 2jz-gte 550's injectors??
http://zilvia.net/f/sale-items/55482...-resistor.html
supersayianjim is offline   Reply With Quote
Old 02-12-2014, 07:31 AM   #3505
kaking
kaking is making a name for him/her selfkaking is making a name for him/her self
if anyone is in the market for a stock 2j into s14 wiringspecialties harness let me know. Its brand new. I'm getting rid of my 240/2j stuff to focus on bigger goals
kaking is offline   Reply With Quote
Old 02-12-2014, 08:25 AM   #3506
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
here is a video of me at our local track holding an drift event for the first time in about 5-6 years, running on a single turbo setup now.
completely stock 2jzgte vvti ecu and injectors (440cc) at 12psi on a 62-1 with a .68ar car feels amazing and faster than it did with the twins at 15psi.
Brohan at Three Palms Speedway - YouTube&fs=1" width="644" height="390">Brohan at Three Palms Speedway - YouTube&fs=1" />Brohan at Three Palms Speedway - YouTube">http://www.youtube.com/watch?v=Brohan at Three Palms Speedway - YouTube
http://www.youtube.com/watch?v=Z59xYN0m1uk
JohanM is offline   Reply With Quote
Old 02-12-2014, 10:56 AM   #3507
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Damn what a nice smoke show!
BiG MiKE86 is offline   Reply With Quote
Old 02-12-2014, 02:32 PM   #3508
ATLspeed
ATLspeed's Avatar
Does anyone have the the 6sp trans in a s13 (or s14, but I'm sure they may differ). Did you have to do any hammering/massage the transmission tunnel at all? Thinking of selling my r154 setup for my s13. Would like to do some of the hammering now before I get my bay painted if necessary.
95 Supra Turbo
Old 02-12-2014, 02:46 PM   #3509
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I don't think very many are running the getrag trans, it's spendy as fuuuuuuuu
di-devol is offline   Reply With Quote
Old 02-12-2014, 02:47 PM   #3510
supercompact
The clutch setups are expensive as well.
