Old 01-29-2014, 08:39 AM   #1
IVIcNinja
IVIcNinja is an unknown quantity at this point
P1400 code wont go away!
Hi i have a 95 240sx and I have had the p1400 code since I got the car. I have changed the egr solenoid valve twice already and the code still persists. I dont really want to change it again since its a real PITA so could anything else be causing this code? Im just trying to get rid of my CEL. Any help would be appreciated.
IVIcNinja is offline   Reply With Quote
Old 01-29-2014, 08:54 AM   #2
IVIcNinja
Ok sorry for the double post but the p1400 code reads differential pressure feedback egr circuit low input
Old 01-29-2014, 09:01 AM   #3
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
This may sound like a dumb question, but you never know.
Did you reset the code after replacing the part?
Also, did you make sure the wiring from the sensor to the ecu is in good condition and not effected in any way?
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 01-29-2014, 09:02 AM   #4
IVIcNinja
Yeah I have cleared it a couple of times.
Old 02-04-2014, 11:20 PM   #5
IVIcNinja
Anybody else ever have this problem?
Old 02-23-2014, 05:41 PM   #6
IVIcNinja
Nobody huh?
Old 02-23-2014, 05:57 PM   #7
se7en_
se7en_ is an unknown quantity at this point
i'm assuming ka24de? the egr system could be plugged...try pulling the tube and checking for restrictions. Know anyone with a legit scan tool? not the cheap 3-500 dollar ones, something that can turn the egr on and off while the engine is running to see if the engine stumbles at idle.(signifies whether or not the system is working.
se7en_ is offline   Reply With Quote
Old 02-23-2014, 06:00 PM   #8
IVIcNinja
Unfortunately i dont know any one with a "legit" scan tool. But thanks i will check the lines.
