Old 03-03-2014, 02:53 PM   #2971
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Originally Posted by da_crew10 View Post
Elaborate please?
This is the only suspension item I did not change, just changed the bushing out on it. Never really understood what the traction rod actually did.
I am really low, should I buy an adjustable one?
I had this issue on my first S14, car was so low that it was toed in. Adjusted with the toe rod but the stock traction rod was binding and keeping the car from toeing in. Had to upgrade to adjustable traction rod to leghten it, in order to get my toe back to spec.
Originally Posted by simmode1 View Post
^^^I do wanna mention though: It is possible to fit those 18x11's under stock rears with 265/35 rubber, but You might not like the amount of pulling & negative camber required.
It would be harder on an S13. S13 rear fenders like to buckle when you pull them too much.
CLICK HERE!!!
Old 03-03-2014, 03:43 PM   #2972
simmode1
simmode1's Avatar
Yeah, I said that before I knew that his rear quarters were fubar'd like that...
Old 03-03-2014, 09:46 PM   #2973
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
Rb26kouki is an unknown quantity at this point
Feedback Score: 63 reviews
can anyone guess whats the offset on these te37 on this s15
specs are
18x9.5 Front
18x10.5 Rear
Rb26kouki is offline   Reply With Quote
Old 03-03-2014, 09:47 PM   #2974
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
this is my setup
square all around
18x9.5 +12
Tires 235-40-18
future tires
275 35 18 fronts
315 30 18 rears
but want the staggred set
but undecided for +22 or +15
Old 03-04-2014, 08:19 AM   #2975
Matt191
Matt191's Avatar
Matt191 is an unknown quantity at this point
Okay guys, I have a stock s13 I don't mind having to roll fenders or anything, but I really just want a nice mild ride height but if I need to go lower I will and can. But I found a set of 17x9 Varstoen wheels with a +22 offset what do you think about these wheels? What is it going to look like? What kind of tire size am I going to be looking at? Any input will be greatly appreciated as I am having troubles with figuring out just where I need to be for a nice flush fit.
Matt191 is offline   Reply With Quote
Old 03-04-2014, 08:43 AM   #2976
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Please read through this thread, please search through rimtuck, please use the search function for this forum.
17x9 is a common size for the S-Chassis and I'm sure you'll find a ton of answers there.
The possibilities are endless with that size and offset. You can run a bit of meat but you could also get real low and real skinny tires. It's a versatile size.
This thread is about Wheel Fitment Questions, not "feed me info/specs" questions. Learn more about what goes into wheel fitment and then come back with a question regarding the specs you found and the type of alignment you want and tire sizes you want.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 03-04-2014, 10:19 AM   #2977
drgreen
drgreen is an unknown quantity at this point
I tried to search and I can't find anyone with a +47 off set wheel. I bought a set of 17x8F +47..17x9R +47. Work Rezax Ver 1
Rubber is 225f 255r
Going onto a 180 with stock fenders.
Haven't had the chance to put them on because doing my 5 lug conv. in a few months when the snow melts....
So I imagine +47 will need spacers so I don't hit coilovers (Cusco Zero2) but then I will be in the fender...
My question is, do you guys think I can just get away with spacers and roll+pull?
Pic request for any 180 that has a +47 work wheel on it...
drgreen is offline   Reply With Quote
Old 03-04-2014, 02:11 PM   #2978
93_ProjectS13
93_ProjectS13's Avatar
93_ProjectS13 is on a distinguished road
Buying a set of 18x10 +18 for all cornors of my zenki.
Now I've read up and the back should be ok with a 8mm spacer. But the fronts would need a 10mm spacer. Also gonna run 225/40/18 on all 4.
So is the 10mm good? I've read that a 8mm barley clears, why ima grab a 10.
Flip I know you know this!!
93_ProjectS13 is offline   Reply With Quote
Old 03-04-2014, 09:03 PM   #2979
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
^^ Rear will be easy with a roll, & 2ish degrees camber. Can do less camber if you pull the fenders a tad bit. A 225/40 is perfect tire size. The front will be a pain being a x10 with a +8 offset, but doable. Just crank the camber. It all depends on how low you go as well.
Edit: Wait wait, guessing you have an s13. I had a 18x10 +12 with a 225/40 and it was an easy fit in the rear. I was looow so I had a small pull an -4 degrees of camber.
The front will for sure be a pain on an s13, but again doable, take your time, roll , big pull, and A Lot of camber if your planning on being low. The higher the easier obviously.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 03-04-2014, 09:30 PM   #2980
93_ProjectS13
Nope its a zenki. And I just said fuck it and ordered 2 sets of pbm spacer kits. I'll get them to fit LOL!
Old 03-05-2014, 09:44 PM   #2981
wild7driftboy
wild7driftboy's Avatar
wild7driftboy is making his/her stupidity well-knownwild7driftboy is making his/her stupidity well-knownwild7driftboy is making his/her stupidity well-knownwild7driftboy is making his/her stupidity well-known
Kinda crazy but anyone think I can fit 18x12 -15 wheels on a stock body hatch? I know I need to camber roll and pull big time
wild7driftboy is offline   Reply With Quote
Old 03-05-2014, 10:39 PM   #2982
Bladimir
Bladimir's Avatar
Bladimir is an unknown quantity at this point
Originally Posted by 95KA-Turbo View Post
Fronts will fit no problem with the lip flattened. Rears will need ~-3 camber and a slight pull.
This is ~-2.5 camber with a 255/40/17 BFGs on a 17X11 +12.
Front shot:
The fronts in those photos are 17X10 +7 with 245/40 S-Drives and ~-2.7 camber.
Bro what wheels are those?!
Bladimir is offline   Reply With Quote
Old 03-06-2014, 05:37 AM   #2983
fliprayzin240sx
specs are
18x9.5 Front
18x10.5 Rear
this is my setup
square all around
18x9.5 +12
Tires 235-40-18
future tires
275 35 18 fronts
315 30 18 rears
Don't use S15s as reference for S14 fitments since S15s have narrower body lines than S14s. S15 fitments are more like S13s.
As far as fitting that much rubber on 9.5js. I think those are going to be over kill, specially those 315s are 11j-12j width territory.
Rubber is 225f 255r
You wont, those wheels are too high of an offset. You'd need ATLEAST 25mm spacers to make them look decent without having to do much with the fenders (roll is always a good idea).
All depends on the coilovers/suspension. 18x10 +18 were perfect for my S14 fronts on Topline Aragostas, didn't need any spacers. PM me if you got any other question...
BBS RS, custom re barrel 17x8 +50 to 17x11 +12 all around. And it's your lucky day since he's actually contemplating on selling them for $2300 + sh.
https://www.facebook.com/stephen.knoop.71?fref=ts
CLICK HERE!!!
Old 03-06-2014, 02:31 PM   #2984
drgreen
Thank you very much for the help! I just want to clarify, are you saying with a 25-30mm spacer I could clear coils and stay within the fender or be able to roll if necessary?
Or "you won't" as in, you won't be able to make them fit on OEM fenders?
Side note... you sold a turbo set up a few years ago Gt3071r, HKS EX MANI, HKS actuator... to a guy in Winnipeg, Canada. I'm thinking about buying that set up from him. Any comments? I don't mean to be off topic so pm me if it doesn't belong in thread. Thank you once again for your valued advice.
Old 03-06-2014, 02:42 PM   #2985
fliprayzin240sx
You wanna get the offset down to atleast the mid 20s to make it look decent. Bigger the spacers, the smaller that +47 offset will get. If you get a 1" spacer that equates to about 25mm spacer.
As far as the turbo, sold it to him since it didnt work out for. My EGT was too damn high for some reason and ended up bumping to a GT3582R pushing 500whp.
CLICK HERE!!!
Old 03-07-2014, 06:10 AM   #2986
juhaaan
juhaaan's Avatar
juhaaan is an unknown quantity at this point
Hi! I wonder if this will fit to my s14: 18x10 ET12 offset 12
juhaaan is offline   Reply With Quote
Old 03-07-2014, 11:13 AM   #2987
zooopreme
Trader Rating: (38)
Yes msglngth
Old 03-07-2014, 11:22 AM   #2988
S14_kouki504
S14_kouki504's Avatar
S14_kouki504 is an unknown quantity at this point
Send a message via MSN to S14_kouki504
What kind of spacers would i need for a set of konig Lace Wheels to fit on a Kouki S14. They are 17x8 35 offset. My car isnt slammed. I want the wheels to fit nicely without too much modification to the fenders.
S14_kouki504 is offline   Reply With Quote
Old 03-07-2014, 11:53 AM   #2989
zooopreme
Trader Rating: (38)
10mm slip on's with extended lugs but 15-20mm would look just right but they are usually bolt on. Seen some unfortunate incidents with people I know with bolt on spacers even when the spacers were hubcentric.
The less flush your wheels are with your fenders, the more room for alignment adjustment and tires.
Old 03-07-2014, 11:58 AM   #2990
S14_kouki504
yea i am not over concerned with being hella flush. i am a total noob when it comes to spacers. does anyone suggest a certain brand or type of spacer?
Old 03-07-2014, 01:06 PM   #2991
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
You shouldn't need spacers to fit those wheels on. It won't be flush, but should mount just fine.
VNG704 is offline   Reply With Quote
Old 03-11-2014, 01:58 PM   #2992
ZenkiDeven19
ZenkiDeven19 is an unknown quantity at this point
Ok question guys! I just purchased my s14 sunday, It came with the 370z touring wheels 19's. I want to run a smaller wheel something like 17's, what im wanting is the xxr 530's. Can someone suggest specs for the wheels, for example should I run 17x9's in the front and then something bigger in the rear or what? Im a noob when it comes to wheel fitment, so any help would be great!
ZenkiDeven19 is offline   Reply With Quote
Old 03-11-2014, 08:32 PM   #2993
fliprayzin240sx
^^^How about you read some of the posts in here and atleast attempt to figure it out?
CLICK HERE!!!
Old 03-14-2014, 08:01 PM   #2994
1fastsil80
1fastsil80 is an unknown quantity at this point
It want let me search but does anyone know what the backspacing would be on 15x10 and 17x4.5 racestars? Also will have to roll fenders or can I get by without them rolled? Pics would be great even if it isn't racestars maybe welds or some sort. Also this is going on a s14. Thanks
1fastsil80 is offline   Reply With Quote
Old 03-15-2014, 09:51 AM   #2995
da_crew10
da_crew10's Avatar
You can make anything fit with fender re-modification. But I doubt you'll be able to fit them even with a huge pull, stretched tires and max camber. Go wide body 50mm and you'll be fine.
Old 03-18-2014, 10:57 AM   #2996
kamilitaryman
kamilitaryman's Avatar
kamilitaryman has a little shameless behavior in the past
Ok, I'm starting to lose my mind with all the numbers in my head. I'm hoping some staggered setup OGs could chime in and help me choose a wheel setup.
Current setup on my S14 Zenki:
-stock fenders
-stock A-arms with ES bushings
-stock camber bolts
-K-Sport coil overs (not sure which model, but they look like their basic coilover)
-300ZX calipers in the front, stock caliper in the rear
What I'm trying to achieve:
A staggered setup with a 17x[9-9.5] in the front and 18x[10-10.5] in the rear...not sure which offset to choose though.
I'm trying to keep the rolling/pulling to a minimum, hence why I'm really scratchin' my head here. I'm not a fan of stretched tires either, so that's out of the question - please help a fellow Zenki owner out!
Also, where do you guys buy your wheels?
400HP KA24DET in progress
kamilitaryman is offline   Reply With Quote
Old 03-19-2014, 09:50 PM   #2997
da_crew10
da_crew10's Avatar
Dude look through this thread and you will find your answer. I mean what kind of question is where do you guys buy your wheels?
Old 03-20-2014, 08:25 PM   #2998
fliprayzin240sx
-stock fenders
-stock camber bolts
First off, figure out how much poke you want, that will dictate pretty much everything from offset to tire width to how much roll/pull you'd need or how much camber or even how low you can go. Since you said you don't want the stretched look, go look thru this thread and see if you find anything you like. If you do, just see what their specs are if its not listed already...PMing the person who posted it up never hurts...
http://zilvia.net/f/showthread.php?t=166563
CLICK HERE!!!
Old 03-21-2014, 07:17 AM   #2999
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
C4 Sawblade Corvette Wheels on a S13 coupe? Will edit my post later on with wheel specs.
tootall4la is offline   Reply With Quote
Old 03-21-2014, 07:47 AM   #3000
EmperorX
EmperorX is an unknown quantity at this point
Can anyone tell me the wheel and tire sizes on this car is?
EmperorX is offline   Reply With Quote
