Old 03-03-2014, 03:28 PM   #31
S14DB
AFC #1
S14DB's Avatar
adverse to you does not mean adverse to everyone. the glass was adequate enough at the time when koito or ichikoh (cant recall who made them) at the time of creation, i dont see why they no longer suffice. just because forums are created where people nit-pick cutoff sharpness - that imo, has little to do with actual lighting performance.
imagine if the hellaflush fruits dictated what was right from wrong in terms of wheel & suspension setup. having a sharp and colorful cutoff is the equivalent of driving a slammed car with stretched tires.
the euro-spec mkiv supra and kouki s14 both came with glass headlights. i would pick glass ANY DAY over plastic. simply put, PC lenses require too much upkeep. oh well, what do i know. :-)
Ichikoh made them.
The cut line on them is above the cutoff line on the projectors. You can cover the top part with your hand and see.
I would rather have them any day over some random curve plastic lenses. To expand on all the high end euro brands using glass and Euro Zenkis coming with glass.
The only errant light I have is from the squirrel catcher prisms in the center. I have the slots closed on my projectors so they do help throw some light off to the side.
Old 03-05-2014, 01:02 AM   #32
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Ichikoh made them.
Can you elaborate on this?
Old 03-05-2014, 12:15 PM   #33
S14DB
AFC #1
S14DB's Avatar
on what part?
Old 03-05-2014, 02:11 PM   #34
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
on what part?
You said you have the "slots closed" on what again? I just got my a year ago so I don't quite know what you mean.
Old 03-05-2014, 04:32 PM   #35
S14DB
AFC #1
S14DB's Avatar
Got what a year ago?
On my HID projectors. This tab and slit is to throw errant light to light up signs and small woodland creatures on the side of the road. Bent it down to cover the slot for dat cutoff yo.
The halogens in the Kouki headlights were great for their time but technology has changed. The bowls in most factory projectors the bowl silver coating is faded, foggy or faded. They aren't curved for proper HID bulb parallax. So, I'm not running stock projectors.
Old 01-08-2016, 12:33 PM   #36
Snouki
Snouki is an unknown quantity at this point
Hey guys, sorry to zombify this thread but i didn't figure my question was worth a new thread. You guys have mentioned that the aftermarket plastic lenses are less durable and fade/yellow quicker than oem glass. I'm wondering if clear PPF (paint protection film) will prevent this? I've heard a coat of wax helps but I think this would be a little better for stone chips if it does in fact help fading/yellowing as well. Also, I'm assuming my hid kit for my usdm lights will work in an aftermarket set? correct me if I'm wrong here
Snouki is offline   Reply With Quote
Old 01-08-2016, 02:37 PM   #37
silviaks2nr
silviaks2nr's Avatar
You may get better responses in the definitive lighting thread. Glass lenses will not fade, but they can pit and break. I would not use clear film on plastic lenses if you have a projector retrofit, otherwise it's fine. just know it's a pain in the ass to remove if you ever want to.
'98 240sx 5spd
kouki 2jz t56 swap build
