#32 | |||
![]() Join Date: Jul 2005
2. How is there crap coming out of your engine? Is it liquid crap? or solid crap? 3. Why doesn't the factory feel the need to put a can on the engine to catch "crap that you drain out later"? If by crap you mean oil, then just say oil. Which by definition should be coming out of your valvecover clean. Which is why it returns to the oil pan on a factory setup, and does not require "to be drained later". Quote:
I hope that makes things more clear for you. Quote:
#34 | |
Unfiltered air from the crankcase frequently contains carbon, oil, moisture and other harmful substances, and therefore requires filtration. The air passes through a tube-shaped mesh filter, which creates a coalescence effect (science). Here bigger particles are adsorbed on the filter and the water and oil will condense into larger droplets, which can then fall down to the bottom of the can. Basically, the air is slowed down, which makes the particles condense on a mesh or foam like pad, allowing the water droplets to travel to the bottom of the drainage system and await discharge. In the filtration stage more than 95% of the water droplets, oil and large particles are removed. The rest are burnt off by the engine. Without a catch can, that 95% of contaminates, "crap" and "shit" will be routed directly to your intake. Idk about you but I like my engine. This is an aftermarket UPGRADE to an already functioning factory PCV system. ![]() |
#35 | |
Again, there is a NON filtered tube, connecting the intake manifold directly to the valve cover on all engines. Completely bypassing the catch can. Having a can on the other side of the engine does not help this fact. How are you claiming it does? |
#36 | ||
1. Carbon chains IS oil. Just say oil. You can say Alkanes if you want. Be specific. 2. Oil, IS carbon chains. Way to list the same thing twice. Why dont we just say Alkanes? 3. Moisture... Is water molecules, as a vapour/GAS when oil is over 212*F at sea level. Which again, will not get caught in a catch can. And furthermore, can not be filtered out by any catch can produced by any manufacturer. Water is a non issue for a running engine once the engine hits operating temperature. Have you ever drained your catch can and found water? LOL! Quote:
So far the only two things you mentioned coming out of the valvecover are: oil and water. Still dont see "crap". |
#38 | ||
#39 |
It seems catch cans absorb particulates from combustion on a mesh and let's it condense.
Its an extra preliminary step before stock systems to remove more random particles that's not gasoline. Dunno why that's so hard to get. Sent from my Nexus 4 using Tapatalk |
#40 | ||
![]() Quote:
I told you how water and oil vapors get trapped in the can in the last post where I explained how a catch can works "scientifically". How do you think water gets separated from air coming from air compressors? Same principal is applied to this. |
#41 | |
Well thanks for trying at least. Consider this, then, #1 there is a hose connecting the valvecover directly to the intake manifold. Regardless of whether you have a catch can or not, the engine has direct access to the valvecover, and all of it's "particulate, crap, debris, oil, carbon, water, etc..." #2 anything particulate based in the engine oil is filtered out by the oil filter (that's its job). Anything else found particulate based in engine oil, by definition, could not "condense" since it is a solid and stays that way. Furthermore, anything particulate based in the engine oil, is fully distributed to ALL of the engine oil evenly. Particulate does not concentrate in one specific place, right next to the valvecover exit point leading to the catch can, that would be against the laws of physics. |
#42 |
I'm not here to argue what "crap" is when I've explained what I mean when I say "crap in multiple posts. Go back and read.
I refer to it as crap because it's unwanted. No one wants crap hence the reason we are trying to contain it and dispose of it. |
#44 |
you keep missing the fact there is a non-filtered tube connecting the intake manifold to the valvecover. Yeah you can filter it; but nobody ever does. I bet you dont either. Picture of your engine with a filter on that specific hose please. Yeah didnt think so. Furthermore, water can not be found in engine oil once the engine oil is operating temperature. It will have boiled off. further FURTHERmore, water is not harmful to the combustion process. In fact, water entering the engine to be burnt, will tend to CLEAN the engine. I typically run a gallon of distilled water through my engine per week. |
#45 |
It separates the oil FROM the crank case vapor... VERY GOOD... now WHY?
WHY Does it separate the oil from the vapour? Answer: Because there is a tube connecting the inlet of the turbocharger to the valvecover, and we do not want a significant amount of liquid oil entering the compressor side of the turbocharger. NOT answers:to Filter the oil, for filtering out "crap", filtering out "debris" these are imaginary reasons for people who claim there is "crap" coming out of their engine yet have no clue what "crap is" nor data to back that up. |
#46 | |
#47 | |
To filter "air" you would need an "air filter". |
#48 | |
![]() Join Date: Aug 2010
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
#49 | |
Engine has 13,000 now. I keep it clean, dont you worry. Yeah theres a catch can on it, a greddy can. I never said it was a bad idea. Only un-necessary, and detrimental to the overall pressure drop experienced at the turbocharger inlet, due to the additional volume of plumbing. It was important, on a clean, highly modified engine, for keeping that much more liquid oil away from my compressor. Repeat: for keeping liquid oil away from the compressor. not for filtering "crap". lol... And I would not have bothered if I was using an S14 cover. Its just the S13 covers have a tendancy to dribble a bit of liquid oil. Which is why there is the factory hose returning oil to the pan. |
#50 | |||
I run LSx motors but please explain to everyone why those same principals of filtering the air coming from the crank case to the intake don't interchange between Nissan motors and LSx motors. I'd be very interested to read that logic. Condensation is found in motors due to the difference in temperature from the inside of the motor to the outside air temp. After the motor is run for a while it turns into vapor and guess what, we are catching that in the catch can! If you're reading this, DO NOT run water through your intake. Water does not compress and you can hydro lock your engine and cause internal damage. Common sense tells you this. If water doesn't hurt the combustion process then why do engines produce less power when it's humid outside? BECAUSE YOU CANT BURN WATER!!!! Quote:
You're clearly losing this discussion. |
#51 | |
http://www.xtremediesel.com/Snow-Per...Fa47OgodPwIAXw http://www.fcpeuro.com/products/aem-...FUuXOgodMh8Apw Oh NOES! Nobody use those water injection system! They R bad! I think at this point its pretty obvious you lack experience with high performance engines and should not be giving advice. |
#52 | |
I had a water meth injection on a procharged LS1. Alkycontrol built my kit. I know a lot about it. Fact is that water/meth injection works but it's a bandaid to a problem of not enough octane in the fuel. Common knowledge. I'm not here to talk about water/meth injection, I'm here to talk about catch cans. |
#53 |
Don't turn this into an argument about water injection lol.
Catch cans are the topic here, properly ran PCV systems are the topic here. Not why you should run water through your engine. |
#54 | |
furthermore PCV, again, has no catch can in it. that is something you are adding to it. PCV has nothing to do with catch cans. You are all over the place with the terminology, and you lack fundamental knowledge of chemistry. |
#55 | |
Just because you add a catch can to a PCV system doesn't turn it into something other than a PCV system. It's still a PCV system but it now has a filter integrated into the system. I'm sorry you ran into someone who knows what they are talking about. Haha. It's just not your day today. I've explained how it works, why it works and why you should use one. At this point you're trying to dissect my posts and twist words around. Not gonna work man. Catch cans are used and have been used on high performance cars for decades. Why? Because they work. Nothing you can say or do to refute that. This discussion is over. People, you have the facts. You decide if a catch can is right for your setup. |
#56 | |||
People sometimes use a sock to filter air. So that is an air filter? Just because I use it? You consistently make the erroneous claims of someone without any scientific background. What you did there, is called non-scientific coorelation. http://en.wikipedia.org/wiki/Correla...mply_causation Quote:
2. You, and everyone else, has ZERO data about "air filter" capabilities of any/all catch cans available. Most do not contain ANYTHING. The ones that do contain a large wirey mesh, incapable of filtering air particulate. 3. The materials that compose common metal-mesh inserts of catch cans provide a reaction surface (catalyst) for potentially hazardous side reactions for the truly (un-named as of yet) harmful partially de-hydrogenated/oxidized carbon compounds (the ones I was hoping you would mention but failed to) Making the catch can a potentially harmful addition to the PCV system, besides the obvious draw back of the additional length (#1). Quote:
#59 |
![]() checklist: 1. intake manifold routed to factory PCV valve 2. S13 cover returns liquid oil to pan 3. Compressor inlet uses proper angle fitting to promote PCV 4. S13 cover receives PCV signal during boost from compressor inlet 5. Catch can receives any liquid oil that does not return to pan (just in case any liquid oil makes it- but none ever does) 6. Catch can never "fills up" with oil because that would indicate an issue with crankcase pressure 7. Crank case is fully sealed, maintains a vacuum while engine is running bonus points: 1. bypass is on the hot-side, as close to the compressor as possible. 2. Stock clutch fan / shroud for reliability 3. proper heat management to prevent engine bay fires 4. bottom mount configuration for style |
#60 | |
Kingalton, I think you read too far into things and miss the point sometimes. You don't know everything and at times you come off as an arrogant fool and others you have valid points that aren't in outer space. There's more than one way to skin a cat. A catch can is nothing more than a means to remove the oil vapor from inside the engine. As someone stated, there are contaminants in said vapor that some prefer not to have redirected back to the sump. Oil changes are needed because there is "crap" in it, among other reasons, as you know. A valve cover, such as the S14 with internal baffling collects these contaminants and over time they get gummed up with the "crap" that was filtered out. Next time you pull your VC off, remove the baffling and tell us what you find.
