04-26-2014, 12:32 AM | #3091 |
Trader Rating: (38)
Feedback Score: 38 reviews
Will an 18x9.5+12 on a 225/40 clear ? My main concern is rubbing the harness on full lock. Im sure a 215 will clear but IMO its too much of a stretch for me . maybe even 225/35?
04-26-2014, 08:22 AM | #3092 | |
I'm running a 235/40/17 on a 9.5w/+12. It's tight on the coilover but works. Move the harness? |
04-27-2014, 09:21 AM | #3093 |
not sure if this 100% fits this thread, but semi related. i have PBM adjustable spacers on the front. using the 20mm bolt on, and then 7mm slip on (the 5mm and 2mm) with xxr wheels. since the spacer is hubcentric, thats all good. but the wheel is also hubcentric, but the other side of the spacer is not. as i'm sure you guys can guess, bad things happen at speed. is there some fix for this? machine a ring that would center on the spacers?
04-27-2014, 02:17 PM | #3094 |
Man w/ CTSV & a Car Seat
Honestly, I've never used hub centric spacers and have never had any vibration issues. I always just make sure my slip ones are centered by feeling it around the hub. I'm on extended studs and running 2 10mm stacked slip ons.
04-29-2014, 06:34 AM | #3095 |
what would you guys suggest for tires and spacers for a 17x7.5 konig backbone wheel? im not sure what the offset is on the wheel. i want a tire with a little bit of meat on it but not too tall. also dont want to be "hellaflush" just want to fill the wheel well up a bit better and have clearance from my coilovers.
04-29-2014, 07:13 AM | #3096 | |
04-29-2014, 08:06 AM | #3097 | |
04-30-2014, 06:09 AM | #3099 | |
You're kidding me right? |
04-30-2014, 07:21 AM | #3101 |
You Sir, don't make any gaaawdamn sense. So why would you ask about tires and spacers for them if you dont have them already or plan on getting them? If you havent found anything you like, why waste money on shitty ass rims?
05-01-2014, 12:56 PM | #3102 |
Just picked up 18x9 +25 for the front and 18x10.5 +25 for rear. Is anyone running the same or similar set up? What tires are you going with? Thanks!
Sent from my SCH-I535 using Tapatalk |
05-02-2014, 03:39 AM | #3104 | |
05-02-2014, 01:56 PM | #3107 |
Wow my thread got to put in the sticky section!!!
thanks you guys, keep to good info coming. I hope to be back here soon with my BRZ when its ready! If anybody on here has info on the brz/frs it'd be cool if i can get some help fitting my old rezaxll. They're 18x9/10 +14 ima have to get adapters so they will become +4 all around. Ima got with same tire size as my s13 215/35 and 225/40 i think with a roll the fenders should be cool. any info would help im kinda confused with the fitments for this car.
http://thatistupid.tumblr.com/ |
05-02-2014, 06:00 PM | #3112 |
Trying to figure out what tires to run on my new wheels. Ordered 50mm rear overs. 17x10+0 17x11 +6 Would like a stretched tire, but with overs on the rear I don't really need to stretch it I guess. Planning on tucking a little rim out back.
05-02-2014, 10:08 PM | #3113 |
05-02-2014, 10:40 PM | #3114 |
Ya my adapters are gonna me it +4 all around on a brz.
05-02-2014, 11:19 PM | #3115 |
Hey guys, just picked up a set of Fabulous Profounds. They are 18x9.5+18 and 18x11 +24 I'm running Origin 40mm up front and unknown overs in the rear (assuming 30mm?) Both wheels need to be spaced out a bit.... What do you recommend? (for a spacer setup and tires)
How it sits with current eurolines @ 17x8/9 +38 |
05-15-2014, 06:48 PM | #3116 |
going to get tires in my rear of s13 with roll and pull. Wheel size is 17x10 +20.
Currently running 17x9 +12 with 215/45 and i like the bigger sidewall in the rear. Camber is -2.5 and id like it to stay at that. Now should I run 225/45 or 235/40. Tires will be federal 595 as they are my drift spares. |
05-15-2014, 06:57 PM | #3117 |
Trader Rating: (29)
Feedback Score: 29 reviews
I have an s13 with a minor pull. Wheels are 17x9.5 +12 I originally wanted 215 40r17 but I'm thinking about michilen pilot super sports. They only come in 215 45r17 and I'm afraid it may be a little too much side wall. Opinions?
05-15-2014, 07:18 PM | #3118 |
PSS runs slightly larger/taller than other tires I've ran of the same size. I never scrubbed on Dunlop Star Specs, switched to PSS and hello rub-city. Had to bust out the hammer to beat in spots in the wheel well.
05-17-2014, 02:12 PM | #3120 |
Hey I'm super new to fitment and suspension, but I'm getting some weds kranze lxz's and i have coils, no pull or rolls on front or back fenders so i was wondering what i would need minimum to slam on these wheels pretty good,
the specs are 18x11 +11 and 18x10 +14 with tires 215/40 and 255/35 so im guessing 15mm spacers up front and what else? how much fender pull or roll if i need it etc on a stock body? |
