Old 04-23-2014, 07:09 PM   #2011
KGB
KGB is an unknown quantity at this point
Originally Posted by ExtraGoodness View Post
I'm hankook evo ventus v12ankook evo ventus v12lso in the process of stretching federal 225/35 on an 11. we've only been able to get one side to seat using 2 cheetahs. the tires were at 130psi with one side seated only. anyone have any suggestions?
Spray more wd40 inside tire, lips, everything.
KGB is offline   Reply With Quote
Old 04-26-2014, 01:19 PM   #2012
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
215/35 dz101 on a 18x9.5.... If I run -10* of camber in the front, will it be safe? I've never ran that much camber and stretch at the same time so I'm a little sketched out about it debeading.... Any feedback appreciated, I have no idea what the fuck I'm doing
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 04-26-2014, 02:44 PM   #2013
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Haruguchi drifts the same setup on an 18x10 lol u should be good. Maybe run higher pressure like 50 psi just in case, to lower the chance of debeading.
InsTanCeZ is offline   Reply With Quote
Old 04-26-2014, 04:09 PM   #2014
Drama
Drama is an unknown quantity at this point
I run 215/35s on 9.5 with approx. -9* up front and I've been fine drifting it.
Drama
Drama is offline   Reply With Quote
Old 05-04-2014, 09:00 PM   #2015
ExtraGoodness
ExtraGoodness's Avatar
ExtraGoodness is an unknown quantity at this point
anyone know whats the most stretch i can do using the bike tube method? trying to do a 225/35 on an 11 and no shop i've been to were able to do it.
ExtraGoodness is offline   Reply With Quote
Old 05-23-2014, 11:54 AM   #2016
B-rizz
B-rizz is an unknown quantity at this point
Originally Posted by KGB View Post
^Thanks again man! WD-40 and 100psi did the trick for me, even my tire shop guys could not belive it
225/35r18 on 18x11 all around
One of my used rear tires wouldn't strech all the way for some reason, but I drove it from Houston to San Antonio and back yesterday, just got over 500 miles on this set up and it seems to be fine
ExtraGoodness
Feddy are your best bet bro, they run wider than most... throw fire and cheetah at it and be careful
B-rizz is offline   Reply With Quote
Old 09-12-2014, 02:12 PM   #2017
GabeS14
GabeS14's Avatar
GabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfectionGabeS14 is close to perfection
Urgent question, Anyone seen a 295/25 or 285/30 on a 12.5 rim before?
I am buying tires for my E93 today and
not sure if I should go 285/30 or 295/25
on 12.5 inch Ordens..
I cant find any online to see what it looks like.. being an M3 I wanted to have max contact patch but the fitment will be super agressive.
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap.
GabeS14 is offline   Reply With Quote
Old 09-12-2014, 02:29 PM   #2018
OBEEWON
OBEEWON's Avatar
This doesn't help a ton but the homie Glen on 295's on a 13j out back.
Old 09-12-2014, 07:04 PM   #2019
GabeS14
GabeS14's Avatar
It does! Ill probably go 285/30 on the 12.5's...I need my rears too look like his fronts..
what does he run in the front?
Old 09-15-2014, 12:41 AM   #2020
g_mac530
g_mac530's Avatar
g_mac530 is an unknown quantity at this point
Send a message via AIM to g_mac530
Hey Gabe, I run a 245/35 on an 11 up front. I'm using hankook ventus v12 tires also. Before I ran the 295/30 I actually had a 285/30 on the 13 and the tire seated but there was too much exposed lip and barrel for my tastes. And the tire guy I went to didn't feel safe going over 80 psi without a tire cage.But here is a pic of the 295 on the 13
Originally Posted by RoXiE.S14 View Post
Because Jesus himself made the nissan 240, true story
g_mac530 is offline   Reply With Quote
Old 09-16-2014, 07:48 AM   #2021
05subysti
05subysti is an unknown quantity at this point
285/30 nankang ns2 on 18x12.5, was fun to stretch. Make sure tire is heated/warm!
Barrel poke son
05subysti is offline   Reply With Quote
Old 09-18-2014, 03:24 PM   #2022
GabeS14
GabeS14's Avatar
Thanks guys!
I got it to work, I might even try a 275/30 on the 12.5 now. I need more space.
Old 09-18-2014, 04:33 PM   #2023
Juucso
Juucso is on a distinguished road
I have 275/35 on 12" wide and 315 on 13.5".
12"
13.5" Not so extreme..
Juucso is offline   Reply With Quote
Old 05-07-2015, 11:11 AM   #2024
B-rizz
GabeS14, you know who's makin 275/30/18s?
Old 03-04-2017, 06:41 AM   #2025
starfireS14
starfireS14's Avatar
starfireS14 is an unknown quantity at this point
Stretch experts need some help need to stretch 245.35.18 on 18x10 I know it's not a big stretch by any means just need something with semi soft sidewall trying to avoid fender work on front of Supra. Will be a temporary setup until I order new wheels with higher offsets and can run 265.35.18. Looking for W rated tires at a minimum. The Federal 595 RS-R looks decent not sure if they run big though or true to size.
95 HardTop MKIV
starfireS14 is offline   Reply With Quote
Old 03-04-2017, 11:39 AM   #2026
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
Anyone, correct me if I am wrong but the smaller profile you choose, the stiffer the sidewall so I am not understanding the "semi-soft sidewall" part.
As for fitment, your best bet is to read this thread on supraforums regarding fitment; http://www.supraforums.com/forum/sho...h-here!/page51.
instagram
1on1 is offline   Reply With Quote
Old 03-04-2017, 02:54 PM   #2027
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
245/35 will go on an 18x10 no problem, just put the black rubber bead sealer on it and inflate it and itll probably seat on its own, just get whatevers cheapest if its going to be temporary
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 03-10-2017, 03:53 PM   #2028
GabeS14
GabeS14's Avatar
Originally Posted by Juucso View Post
315 on 13.5".
What brand is the one on the 13.5?
I am looking for pics of a 315/30 on a 14.5" rim...
I thought 305's would work but it had more than an inch gap lol
worse case I will run 325/30 on the 14.5 but I was wondering who has experience with
-Bridgestone Potenza RE11
-Good year Eagle F1 supercar
-Ventus V12
which runs wide or smaller?
Any help is appreciated!
Old 03-11-2017, 11:47 AM   #2029
1988montecarloss
Trader Rating: (24)
michelin pilot sport on the yellow 13.5" equips ^^^^
IG: @Haley72692
Old 03-15-2017, 07:03 AM   #2030
starfireS14
I'm very familiar with Supra offsets, I've helped several people with ordering wheels for Supras and SC's. The wheels I have were spec'd for a Z32 which I sold and kept the wheels, rear is fine front is semi-aggressive, currently running 255.35.18 R888's which rub on dips. I will be ordering proper fitment later this year, just looking for a temporary solution tire wise so no rubbing and not familiar with what tires stretch better, need to run 245.35 on 18x10. The 255.35. R888 is oversized more like a 265.
Thanks, looks like Hankook Ventus V12 Evo will fit the bill, I need a Y rated tire and based on research and pics etc...this will work on 18x10. Only need it until end of year or early Spring next year.
95 HardTop MKIV
Old 06-12-2017, 01:07 PM   #2031
1on1
1on1's Avatar
GT Radial Champiro UHP1
Bumping an old thread, have any of you experienced this tire for stretching? I want to try and stretch 245/40 on a 18x12, and I am wondering if I will have issues with this tire. Feedback on this tire would be great since I can source them for $60 each.
instagram
Old 06-12-2017, 01:14 PM   #2032
RB25GUY
RB25GUY's Avatar
RB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to allRB25GUY is a name known to all
Originally Posted by smellslikecurry View Post
Its not like you're putting a safc in a fucking Tesla.
RB25GUY is offline   Reply With Quote
Old 06-12-2017, 02:13 PM   #2033
1on1
1on1's Avatar
The photo you posted are nexens, I am referring to GT Radial Champiro UHP1 (listed as the topic) on my post on how they stretch.
instagram
Old 06-12-2017, 02:31 PM   #2034
RB25GUY
RB25GUY's Avatar
Considering the nexen has nearly identical ratings as the champiro you wanted info on i didnt think it would matter....butttt Good luck
nexen tire
500AA 97H 8 - 9.5 50 1609@50 9
245/40/18
GT champiro
245/40ZR18 97 W 280 AA A 8 1/2J 1609 25.7 9
Old 06-12-2017, 03:02 PM   #2035
1on1
1on1's Avatar
Ahh, I should've look into that. Thanks man and I'll be trying these out on my next event.
instagram
Old 06-19-2019, 11:13 PM   #2036
jays_240
jays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choicesjays_240 has made poor choices
Anyone here know or have experience stretching 255/35 or 265 michelin PS4S on 18x11
jays_240 is offline   Reply With Quote
Old 06-20-2019, 03:28 PM   #2037
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
Originally Posted by B-rizz View Post
ExtraGoodness
Feddys 225 is more like a 245. Should try it on. Tire that runs true to size
turboshoebox is offline   Reply With Quote
