Old 03-05-2013, 10:36 AM   #181
ballsy240
ballsy240's Avatar
ballsy240 is an unknown quantity at this point
bumping an old thread, but just got my vlsd in today and cracked it open to see what size shim was in there and it appears that the stock one in there is so worn down it has bonded with the metal behind it and is unable to be taken off. has anyone else seen this? could this be from the diff having high miles? and same as everybody, i want an aggressive lock, but no chirping around corners, so i'm thinking that i should add two .8 shims. i have one on its way, but thinking about it now, i don't think it'l be what quite what im wanting. any input?
ballsy240 is offline   Reply With Quote
Old 03-05-2013, 11:17 AM   #182
holslut s13
holslut s13's Avatar
holslut s13 is an unknown quantity at this point
Originally Posted by holslut s13 View Post
I added a .80mm washer to mine, which IIRC is one of the smaller sizes and my j30 is pretty much locked up 100% of the time. Use a smaller washer if you don't want an essentially welded diff.
msgg&hhhggggghgg
holslut s13 is offline   Reply With Quote
Old 03-05-2013, 11:59 AM   #183
240SilviaX
240SilviaX's Avatar
240SilviaX is an unknown quantity at this point
read a bit and you will be more than informed
240SilviaX is offline   Reply With Quote
Old 03-05-2013, 12:01 PM   #184
ballsy240
ballsy240's Avatar
yeah, i read entire thread. been wanting to do this for a while. mainly wanted to see if anybody cracked theirs open and found what i did
Old 03-11-2013, 03:35 PM   #185
ballsy240
ballsy240's Avatar
UPDATE: There was not a washer on the other side as well although it looks like there is a wear spot where there used to be one. I'm wondering if i should add 3 (.8) shims now to get it to where it should be with adding one like the op
Old 03-20-2013, 12:10 PM   #186
ballsy240
ballsy240's Avatar
FINAL UPDATE: since there was no shims at all in my unit when i opened it up, i decided to do 2 (.8) shims and 1 (1.1) shim. I swaped the shimmed j30 unit into my s13 open pumpkin and it feels pretty good. I would maybe want it a little tighter, but for me it works out perfectly for my daily driver/drifter. It basically feels like a brand new lsd. just wanted to add my expirience
Old 05-02-2013, 09:54 AM   #187
MattRose
MattRose is an unknown quantity at this point
Hey guys,
So my r33 has the factory viscous in it and I'm trying to get it to lock up like a two way/welded. I use this for drifting and don't care how it feels on the street, I just don't want to compromise the track performance. From what I've read, the skyline shims are in both sides, so my question is, what size shims are the Gus running that are fully locked up?
MattRose is offline   Reply With Quote
Old 05-02-2013, 09:09 PM   #188
240SilviaX
240SilviaX's Avatar
lol its stated about 100 times on how much shim you need to use to lock up the rear or bind up the rear.. there is also info on how to have a mild rear end.. I recommend reading these 7 pages so you will know everything (or most) about the vsld.. your r33 vlsd is pretty much the same as a J30, S-Chassis, Z32, Q45 ect. with minor differences. they all for the most part have 2 factory shims
Old 05-08-2013, 12:39 PM   #189
MattRose
I read through the entire thread but the answers differed on all accounts. Yes there were many people who said they locked theirs up, but some of the shim thicknesses changed, alongside the amount that were put in depending on which side the shim was put on.
Old 05-08-2013, 12:43 PM   #190
S12 Drifter
S12 Drifter's Avatar
S12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymoreS12 Drifter is not welcome here anymore
you need to pull a micrometer our and ACTUALLY measure. when i was doing my Q45 hybrid VLSD i had to pull it apart roughly 10 times to get it the way i wanted.
S12 Drifter is offline   Reply With Quote
Old 05-08-2013, 01:15 PM   #191
EvilRB
EvilRB's Avatar
EvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond reputeEvilRB has a reputation beyond repute
Send a message via AIM to EvilRB Send a message via MSN to EvilRB
Originally Posted by MattRose View Post
Hey guys,
http://240sxdrifter.tripod.com/writeups/vlsdshim.html
For the R33 specifcally but is the same for all R200 diffs, just add thicker shims and follow the directions. If it's too much add thinner ones...
EvilRB is offline   Reply With Quote
Old 05-08-2013, 01:29 PM   #192
MattRose
Exactly the answer i was looking for! Thanks a lot man!
Old 05-08-2013, 07:48 PM   #193
240SilviaX
240SilviaX's Avatar
, Matt just buy a couple of different sizes and experiment like S12 Drifter said,, It doesnt matter what side you put the shim on, its all doing the same thing, that write up is funny 1.5 , 2 way lol its not a clutch diff ,, its just gets tighter the thicker you go.. by adding more shims you bind the spider gears and eventually get a locked rear end .. as for the measuring, I measured my original shims and went from there cuz I know every diff has different sized shims from the factory or if it has been rebuilt in the past.
bc. wrote; Don't think about shimming as 1 shim is 1.5 way and 2 shims is 2 way!!!! There are like 20 different shim sizes and the smallest one is .80mm and the largest is 1.49, read the fsm for the exact sizes.
DO NOT JUST ADD 2 SHIMS!!! that is not the right way to do it. Take apart your diff and measure what you have and then decide how much you want to increase by.
I just tried to put 2 shims in (both were .80mm) and the diff would not go back together in the pumpkin, so 1.60mm of shimming is too much!!! and that is 2 shims of the smallest size. I ended up just using the one .80mm shim and it barely fit back in the pumpkin, i couldn't imagine going more then .20mm more.
EvoVIII808 wrote;
J30 VLSD
Stock Shim size : 1.27 -1.30 on the micrometer (kept bouncing around, went down to 1.25 once). I picked up the .08 and the 1.01. Tried to put both of them on but the 2 screws didnt seat properly, so i decided to use just 1 shim.
I went with the 1.01, on top of the stock. Its not fully locked, but it does skip the tires when turning at low speeds. Havn't done the break in process yet (installed and drove home 5miles.)
Matt, buy a couple of shims, measure your stock shims and decide on how much shim to add also you might want to measure the slack in your diff b4 you start stacking shims like I wrote;
I think every J30 has its own diff sizes from the factory. What I did cuz I didnt want such an aggressive rear end (canyon/mountains) is measured the slack with the stock shims in place with a feeler gauge. so there was .20mm in slack and I added up the 1.13 shim size and added .10 more for stiffen it up and got 1.43... 1.13+.20+.10=1.43 and conveniently there is a 1.43 shim and went and ordered.
Yes I know I didnt want a locked rear end but you should measure and add .30 to .80 of shim to get the feel you want and take note of how much slack there is
Old 04-23-2014, 11:50 PM   #194
2fastandfurious
2fastandfurious's Avatar
2fastandfurious is an unknown quantity at this point
hi sorry to bump this old thread but I was wondering what are the mm suckets you used for doing this? im about to try this on my j30 vlsd just wondering
2fastandfurious is offline   Reply With Quote
Old 06-11-2014, 01:01 PM   #195
jbart003
jbart003 is an unknown quantity at this point
I am having a real difficult time removing the output shafts off my j30. One was able to pop out striking with a hammer in the back 5 times. The other will not at all. I believe its the shorter output shaft. I have been wacking that thing for about 1 week now. Any advice will be appreciated. thanks.
jbart003 is offline   Reply With Quote
Old 06-11-2014, 01:35 PM   #196
Kallixtos
Kallixtos's Avatar
Trader Rating: (61)
Kallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really niceKallixtos is just really nice
Feedback Score: 61 reviews
Don't be scared, grab a brass hammer and smack the living crap out of it.
Kallixtos is offline   Reply With Quote
Old 06-15-2014, 10:13 PM   #197
jbart003
Brass hammer did the trick. Thanks
Old 06-18-2014, 11:29 PM   #198
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
Update:
Mine is nice and broken in. I didnt drive it much last year, but have been driving it daily recently.
Initially the Diff was basically full locked. Now that it is broken in I still get slight tire chirp at slow tight turning, but it is not as bad as a welded.
Mild turns at speed, it does not lock. Tighter turns with throttle it will catch. VERY STREETABLE in WET or DRY (as long as your not at speed and making a tight turn)
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 06-19-2014, 01:07 AM   #199
jamg
jamg is an unknown quantity at this point
how do i break it in?
mine locks like a welded, but it's fairly new.
jamg is offline   Reply With Quote
Old 06-26-2014, 10:33 AM   #200
Kallixtos
Kallixtos's Avatar
Trader Rating: (61)
Usually doing figure 8's in an empty parking lot will help. Eventually the shims will wear slightly after a few thousand miles of driving and loosen up.
Old 07-07-2014, 04:49 PM   #201
slidesquad240
slidesquad240 is an unknown quantity at this point
I'm running a shimmed j30 in my s13 had it for few years now is it possible for it to start slipping or not grabbing posi? I did an event Saturday seemed fine all day came home went to bang out a few donuts and it started as locked but went to one tire fire. I bought it already shimmed not sure how many were used..any ideas
slidesquad240 is offline   Reply With Quote
Old 07-08-2014, 06:46 PM   #202
xaaronx
xaaronx is an unknown quantity at this point
Just thought I'd add that I shimmed my S14 VLSD and it's great. I added an extra 1mm over what was already in there (1.22mm). It's a little more aggressive than I had expected but I'm not complaining. Def feels better than my old welded diff.
xaaronx is offline   Reply With Quote
Old 08-09-2014, 05:48 PM   #203
Juanimeus
Juanimeus's Avatar
Juanimeus is an unknown quantity at this point
240's suck. BMW is #1
Juanimeus is offline   Reply With Quote
Old 08-09-2014, 06:21 PM   #204
Def
Somewhat agree with you after reading some of the shit in this thread dedicated to the most brokedick ghetto mod there is.
Can't believe people still do this shit then act like binding up the spider gears in the diff increases the "lock" - grinding your spider gears away is not "locking" like an LSD does.
DEFSPORT
Old 08-09-2014, 06:24 PM   #205
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
I've had my shimmed j30 vlsd for 2yrs now varying from 350tq-500tq. It def lost its touch. May reshim it again.
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 10-04-2014, 07:11 AM   #206
laurentj23
laurentj23's Avatar
laurentj23 is an unknown quantity at this point
So the output shafts just come out after being knocked by hammer? Does it connected to any bolts?
What do you use to hold the differential to separate ring gear from the differential?
'Born Ready!',LJ
laurentj23 is offline   Reply With Quote
Old 10-26-2014, 06:25 PM   #207
laurentj23
laurentj23's Avatar
Ok. I managed to assemble everything. The one with 3 plates should be on the right correct.? Facing me? I tried to put the output shaft together. I managed to put the left side back in. The shorter one but unable to put the longer one in..on the right? Do I need to hammer it harder like when i remove it?
Help
'Born Ready!',LJ
Old 10-26-2014, 07:06 PM   #208
jbart003
hscalixto suggested me a brass hammer. $20 at HF. It takes a lot of persuasion to put them back on as you did with removal.
Old 10-26-2014, 07:07 PM   #209
laurentj23
laurentj23's Avatar
ok. as far as the sides of the output shaft I'm correct right?
longer on the right facing me and shorter on the left?
'Born Ready!',LJ
Old 10-26-2014, 07:11 PM   #210
jbart003
its hard to tell which direction without pictures.
