Old 07-28-2014, 05:25 AM   #1
anthonys131997
anthonys131997 is an unknown quantity at this point
KA my 5 speed swap problem engine won't start
i really need ur help i bought my 240 from this guy that dint have time to fix it so i took on the project well
first of all the fuel pump was bad so i replace that then a good buddy from Facebook came and help me but he could't find the problem so i look it up and i found this forum where it sed i had to jumper some wires near the fuse box but i bet y'all know witch so i connected that and my engine turns over but it dosnt' start any help or suggestion pleas help
anthonys131997 is offline   Reply With Quote
Old 07-28-2014, 06:30 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
wow. you need to
A: consult a real mechanic
B: brush up on your grammar and punctuation so we can actually understand what you are talking about
C: just go jumper some wires and see if that works :smh:
Old 07-28-2014, 06:32 AM   #3
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
You shouldn't have to hotwire your fuel pump to get it to turn over, click HERE for a tutorial on how to do it.
Although a worthy modification, I don't think that will solve your starting issues. Are you sure the basics are covered? Fuel pump fuse?
Edit: And how is this related to a 5 speed swap? haha
bmaddock is offline   Reply With Quote
Old 07-28-2014, 10:29 AM   #4
ixfxi
ixfxi's Avatar
where the fuck is saginaw, texas?
i mean, do you guys have schools there? look at the grammar on this one
Old 07-29-2014, 11:42 PM   #5
arty
arty is an unknown quantity at this point
Was the car auto before? Check neutral safety switch.. Is your fuel pump getting power? If not check fuses and relay as well.
arty is offline   Reply With Quote
Old 07-30-2014, 03:04 AM   #6
anthonys131997
Hello arty thanks for your Reply in a good way not like other People but I checked all fuses and relays
It was a automatic I did a 5 speed swap
I fallowed this steps and videos on YouTube
http://www.nicoclub.com/archives/aut...nual-swap.html
And the fuel pump was bad so I changed it
Today I worked on it and like I sed there's brown fuel in the spark plugs so I don't know what to do I'm just going to take the spark plugs out and turn the engine on so I can burn some fuel but I'm going to disconnect the fuel fuse first and thanks arty for the reply
Old 07-30-2014, 03:07 AM   #7
anthonys131997
Ooooo and the fuses and relays are good. The fuel pump is new. I haven't checked the neutral safety switch I'll Check it today
Old 07-30-2014, 10:50 PM   #8
arty
Thumbs up
Yea it could be something simple like the neutral safety switch.. As for brown fuel you kinda lost me not unless your leaking oil from your valve cover and its mixing with the fuel.
Good luck!
Old 07-31-2014, 07:24 AM   #9
anthonys131997
I fixed it the timing was off
Old 08-01-2014, 09:24 AM   #10
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
Kuma is offline   Reply With Quote
