Old 07-28-2014, 02:46 PM   #1
tristan582
tristan582 is an unknown quantity at this point
1992 240sx chirp at idle
So i recently joined the 240sx club from being a mr2 guy for while and have a question with this whining/chirping sound. It has the stock ka with nothing but an intake and nice overflow bottle. I looked into the strange noise and most say to remove upper timing guide. So i did that and replaced valve cover seals. (which were toast). I also did a tuneup and the noise is still there. It goes away at about 1500 to 1700 rpms. I don't know what else it could be maybe a bad ac or ps pump. Maybe a harmonic balancer? Sounds more like a pulley. Here is a vid. http://www.youtube.com/watch?v=zGxzI...ature=youtu.be Thanks for all and any help!
tristan582 is offline   Reply With Quote
Old 07-30-2014, 03:52 PM   #2
jim5570091
jim5570091 is an unknown quantity at this point
Remove your belt and see if it goes away. Of it does it's got to be water pump or power steering. I had build up in the serpentine grooves of my pulleys that sounded similar.mine started after I installed a new belt and eventually went away after several hundred miles.
jim5570091 is offline   Reply With Quote
Old 07-30-2014, 03:56 PM   #3
tristan582
I just cleaned out the ac tensioner pulley and greased the bearing and noise is still there. Looks like im a little low on power steering so im going to top it off. I just cleaned the engine and tried to remove all of the grease. Going to try to find out where this stupid noise is coming from. Thanks for help
Old 07-30-2014, 04:16 PM   #4
jim5570091
Remove the belts. Start it an see if it's gone. Replace one at a time. When it returns there you go.
Old 07-30-2014, 04:18 PM   #5
tristan582
will do. Thanks
