Old 07-11-2014, 07:05 PM   #3181
gman-s14
gman-s14's Avatar
gman-s14 is an unknown quantity at this point
Originally Posted by fliprayzin240sx View Post
+20 up front and I'd go mid +20s to 30s for the rear. Fronts, personally, 225/40-18s.
I was close. I went +22 front and +20 rear. Might have to do some pulling on the quarters.
Thank u for ur info....
gman-s14 is offline   Reply With Quote
Old 07-15-2014, 08:29 AM   #3182
GU40sx
GU40sx is an unknown quantity at this point
Does anybody know the specs of these wheels?
I've been searching through threads because i know it's been posted on this site but I can't find it.
http://imgur.com/a/3Q7Ts
GU40sx is offline   Reply With Quote
Old 07-15-2014, 09:05 PM   #3183
jlsports23
jlsports23 is an unknown quantity at this point
Looking to fit some work wheels on my s13 coupe
Car: s13 coupe
Wheels: work vs-xx FRONT: 17x10j +6 REAR: 17x11 +11
Front fenders: 20mm wide fiberglass Silvia front
Rear quarters: stock metal with rolled inner lip.
Ideal camber: Front-5.0 Rear -2.5
Will it be possible to make this set up work without buying overfenders for the rear? And still have full steering lock in the front. Also what size tires do I need to make this happen. I was thinking 255/35 rear and 225/45 in the front.
Any help would be great. Thanks
jlsports23 is offline   Reply With Quote
Old 08-03-2014, 05:09 PM   #3184
Soilsack
Soilsack's Avatar
Soilsack is an unknown quantity at this point
Alright. Things have changed since I was last looking at this thread.
I picked up a set for G35 wheels on the cheap so I am rocking those for now. Regular coupe 6 spokes. 17x7.5 +30 in front and 17x8 +33 in the back. They fit a lot better than stock SE wheels.
Due to some other expenses I won't be able to get a better set of wheels for a bit.
Anyway, to make em look good (better) what I am looking at is Fortune Auto 500 Coils just to drop the wheel gap a bit. (I have to replace some blown shocks anyway) Right now I am looking at about 2 inches gap on all four corners. Will these wheels clear these coils? Also with about a 1.5-1.75 drop are the toe rods and RUCAs needed?
Soilsack is offline   Reply With Quote
Old 08-03-2014, 05:58 PM   #3185
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Use a wheel calculator. Input the numbers of SE wheels and then the G35's, see how much space loss or gained. If you use a good calculator, you'll find out just how much spaced in you need and that'll determine how much of a spacer is needed.
When I was running Tein S-Techs, my alignment shop couldn't get back to stock specs using stock arms. I always tell people that if they need adjustable RUCAs, they'll probably need toe rods too but if the toe change from the drop is minimal, you could get away without it.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 08-03-2014, 11:25 PM   #3186
Soilsack
Soilsack's Avatar
How low were you sitting on the s techs though? I can't find any info as to how much of a drop the stock components can handle.
Old 08-04-2014, 10:00 AM   #3187
zooopreme
Trader Rating: (38)
You really couldn't find this information? I literally typed in "Tein S-Tech 240SX"
Tein S-tech for S13
Rates: 3.7kg/mm F / 3.2kg/mm R
Drop: 1.5" F 1.2" R
Now you try it, "240SX Tein S-Tech alignment issues"
Old 08-04-2014, 11:19 AM   #3188
Soilsack
Soilsack's Avatar
Advertised spring rates and estimated ride height adjustment aren't always accurate but thanks anyway.
Old 08-04-2014, 11:36 AM   #3189
zooopreme
Trader Rating: (38)
If you're on coilovers, what's "estimated ride height of a spring/shock combo" to you? Anytime you lower a car, alignment will change. That's a given.
If you took the time to look up information and stop asking to be spoon fed and didn't want to take my word for it, you would have found a post long ago that says that you can't achieve stock alignment specs with stock arms on Tein S-Techs.
So let's take advertised drop height: 1.75" and 1.25", the car cannot be brought back to stock specs without adjustable arms. If the springs drop the car lower than that, you now know that at 1.75" and 1.25" you will not achieve stock specs with stock arms.
Putting two and two together, you'll find out that you will need adjustable arms. Is this not blatantly clear?
Old 08-04-2014, 07:02 PM   #3190
Soilsack
Soilsack's Avatar
I am not sure how the connecrion is being missed but, whatever.
The reason i asked is because generally the advertised drop is actually more than what is achieved. For example, Eibach Sport lines are advertised at -2.2 front and -2.1 rear but in tests they are -1.75 all around.
So basically, I was searching for what point the stock arms begin to run out. Obviously somewhere between stock and -1.75 (at least)
Now with that said, THAT is the information that can not be found. Where the stock components run out. The information could be useful if, say, you found out it only dropped -1.0 and stock components ran out.
Not sure what the grief is about when this is supposed to be a question thread as it is. I could have easily mad another thread but instead I put it in the correct place.
Old 08-04-2014, 08:22 PM   #3191
zooopreme
Trader Rating: (38)
Why not conduct a test yourself? If you've got at home alignment measuring tools, you can check or head out to an alignment shop. If you've got an iPhone you can already check camber. Measure your car at maximum positive and maximum negative camber, toe, caster, etc.
The "grief" from members like me is when it seems like you're just sitting on your computer barely using your brain to think. Thank you for trying to do some research and posting in the right thread but if there is no info on what stock arm limitations are, why not get your ass up and find out?
Old 08-06-2014, 03:04 AM   #3192
livelovesole
livelovesole is an unknown quantity at this point
Work XD9 on S13. Trying to avoid overfenders, but have no problem pulling/ rolling stock fenders
Front: 18x9 +20
Rear: 18x10 +18
Is this possible without crazy amounts of camber on stock fenders ?
livelovesole is offline   Reply With Quote
Old 08-06-2014, 11:47 AM   #3193
zooopreme
Trader Rating: (38)
Front: 18x9 +20
Rear: 18x10 +18
In the rear, depending on much tire you run and how low you are will dictate your camber and fender pull. A pull is a must even with a mild stretch.
Old 08-06-2014, 03:08 PM   #3194
livelovesole
Planning on running 225/40 in the rear and low enough to flush it thats about it. Do you think I'll be good up front ?
Old 08-11-2014, 04:51 PM   #3195
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
even though ive searched a lot i cant seem to find a definitive answer. 18x10 +15 on an s13 stock body with stance coils... Not trying to pull any fenders. i was thinking maybe a 225/35 front but I feel like unless im dumped it wont tuck tire, but at the same time a 225/40 will rub everywhere like it does on my s14 which has bigger tubs to begin with.. i know I'm for sure going with a 225/40 in the rear. How much camber you pros think ill need to have without having to pull fenders? thanks in advance
Originally Posted by xoxide View Post
Gun it towards the nearest mailbox, rip the ebrake, countersteer.
vJilly is offline   Reply With Quote
Old 08-13-2014, 04:34 PM   #3196
[email protected]
Paul@mastermindna.com's Avatar
Paul@mastermindna.com is an unknown quantity at this point
I'm trying to figure out what tires I should run on my new setup for my S13. Widebody specs are 55mm up front and 85mm rear. Wheel sizes are 18x10-26 & 18x13-6 Work VS-KF
Paul@mastermindna.com is offline   Reply With Quote
Old 08-13-2014, 07:53 PM   #3197
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Put a jack under each wheel and take a picture so we can see how much poke you have.
I'm thinking 225/40-18 and 275/35-18.
CLICK HERE!!!
Old 08-14-2014, 12:33 PM   #3198
[email protected]
Old 08-14-2014, 04:01 PM   #3199
StuckeyOG
StuckeyOG's Avatar
StuckeyOG has a spectacular aura aboutStuckeyOG has a spectacular aura aboutStuckeyOG has a spectacular aura aboutStuckeyOG has a spectacular aura aboutStuckeyOG has a spectacular aura aboutStuckeyOG has a spectacular aura about
Hey I have a S14 lowered a good amount, enough that my alignment is about 4 degrees out on the rear driver side. Stock exhaust was scraping so I raised it just enough that it doesn't as it's my daily, not sure if that gives you a better idea of where it's sitting at.
I'm trying to get a clean fitment on my new wheels though. I'm ordering some 4 lug 18x9.5 +12 offset wheels. I was wondering what would be a good size tire to run on it? I don't mind getting a roll and pull.
StuckeyOG is offline   Reply With Quote
Old 08-14-2014, 05:11 PM   #3200
zooopreme
Trader Rating: (38)
Originally Posted by Pedobear Run Kids View Post
He meant bring the wheels to the position they will be in when the car is on the ground
Old 08-16-2014, 05:51 PM   #3201
Juucso
Juucso is on a distinguished road
Hello! I am buying new wheels for my s13 200sx. I have been looking for these work equip 05's and this are the specs -> Front 18x12" et23 and rear is 18x13.5" et16. How wide fenders will I need?
Juucso is offline   Reply With Quote
Old 08-17-2014, 06:30 PM   #3202
zooopreme
Trader Rating: (38)
A different car.
Old 08-18-2014, 11:16 AM   #3203
Juucso
A different car.
May I ask why?
Old 08-18-2014, 08:12 PM   #3204
fliprayzin240sx
May I ask why?
Because it wont fit. Well, you can make anything fit, just dont expect to make left turns or right turns and kiss making u-turns good bye.
But hey, atleast those front wheels will be perfect for your rear wheels with 50mm fenders bowed out.
CLICK HERE!!!
Old 08-18-2014, 09:04 PM   #3205
Juucso
O Shieet.. I did buy those wheels yesterday. Well, new innerbarrels and then they maybe will fit.
Old 08-18-2014, 09:54 PM   #3206
fliprayzin240sx
Yah, good luck on that one. Front's actually not stupid bad for S13, the outer edge would sit similar to a 10j -2. Take 2" off the inner barrel to kick it down and its manageable.
CLICK HERE!!!
Old 08-18-2014, 10:53 PM   #3207
Juucso
Thank you very much! Do you have any idea how much front wheels will stick out of the fender?
Old 08-19-2014, 08:49 AM   #3208
fliprayzin240sx
Fenders the least of your worries, you better start thinking about tubbing the front wheel well.
CLICK HERE!!!
Old 09-08-2014, 03:35 PM   #3209
Jamie.y22
Jamie.y22's Avatar
Jamie.y22 is an unknown quantity at this point
Trading my wheels for some 17x9.75 +20. I'm currently running Tokico blues and tanabe springs. Will they rub at all? My fenders are already rolled so not worried about that.
Jamie.y22 is offline   Reply With Quote
Old 09-08-2014, 06:14 PM   #3210
_rods13
_rods13 is an unknown quantity at this point
s13 Square G6 wheels
Ok so i'm getting the square g6 wheels 17x9 with +15 offset. So my question is what size tires would be best i'm looking for just a little bit of stretch not too much. Also it is on stock fenders on an 89 s13 coupe and same size all around unless different tire size would work better on front or back. Also I don't want skinny tires I like them wide
_rods13 is offline   Reply With Quote
