#368 | ||
I wish my garage was wider as well. They consider it a "two car" garage, but I honestly am convinced it's an oversized one car. As always, I could use more space. My Rents had enough space for another car to be parked along side of my 40 and I still had enough room to work on my car. It's a bit of a squeeze with two cars in the garage, fortunately, my girl doesn't mind parking her car outside nor has a problem with me taking the entire garage, but she knows it's my "space". I move the car over for her when I'm out of town so she can pull in into the garage at night though. Quote:
So, I know it's been a hot minute with updates and I really don't have anything more on the progress of the car. Once I brought it down to the house I found a small coolant leak, or what I thought was one and it just ended up being the air bleed screw loose. I also pulled my turbo blanket and installed my Stage 8 locking hardware. I have had issues with the hardware coming loose from heat cycling in the past and I felt this was the best solution, time will tell. ![]() A few weeks ago I was sent to Bermuda on business( I know bummer right?). Let me tell you right now, if you have an opportunity to go, please do. There is so much to see on that little island. I killed my Canon batteries in one day taking pictures of this place. It is so rich in culture and history. However, you should be prepared for sticker shock. It is extremely expensive over there. ![]() ![]() That's me checking this random passage out. We hiked and climbed for 6hrs the first day on the island. ![]() ![]() ![]() Gunpowder cavern was built in the 1600's. History states that there use to be a moat around this man made cave, carved into the rock face here. The British use to store gun powder inside when the actively occupied the island. Apparently, this place has been shut to the outside world. We found a way inside and it was an amazing experience. ![]() This is the main entrance/hallway into the cavern, which is the other side of that first picture. Some time in the late 1900's it was turned into a Restaurant/Bar. A lot of the bar area items were still in place. ![]() ![]() ![]() ![]() Before I left for Bermuda, I had to pull my harness. So I spent part of Memorial day weekend pulling that out and getting it boxed up for the trip BACK to ChaseBays, which I hope is for the last and final time. They have been "looking" at it for the better part of two weeks now, I'm hoping to hear back from them any day now. I find myself a bit frustrated at this point with them. I can understand a few issues here and there. No one is perfect and there is ALOT that goes into these harnesses, but continuing to have issues and not having them sorted is getting tiring. Another issue is lack of communication. I don't like having to email someone and helplessly wait for a response. I like the luxury of picking a phone up, pressing a few buttons and getting a response immediately, especially after so much time. Perhaps I've been too forgiving and patient, I just hope it works in the end. Once the harness comes back, I'll have another update and hopefully a dyno date.
#369 |
BEAUTIFUL. just read your entire thread. you've done an amazing job with quality work and its very inspirational. are you planning on keeping the OEM SE front lip with the skirts and rear spats?
HIGHWAYSTAR/TeamSUN*WORKS @HighwayStarJC_sunworks #HSGS14 |
#370 | |
I finally received my wiring harness back from ChaseBays, which I hope is the final time. I went through the harness this time and pinged everything out. All seems as it should, but the real test will be once I get it back into the car. I've slowly been doing that. I have my Harness bar sitting in the spare room. I need to find the time to modify my B-pillar plastics to accept the bar and still look clean, this will take some patience and finesse. I am modifying my catch can setup slightly. Right now my valve cover lines run to the top of the can with the exhaust e-vac plumbed center above them. I want to move them down and add some stainless steel scrub pads to add surface area and collect more oily vapor than the empty can would. I also need to get my exhaust housing blanket secured, but this requires removing the down pipe inorder to get my hands in there. Other than the few items listed above, the car is ready to get to the dyno. Hoping this will happen with in the next month or so, who knows. I will post video and results immediately.
#373 | ||
!!!Update!!! -The harness is back in! I finished the install up sometime during the week. I added an Innovate LC1 wideband and wired that into the EMS for a permanent 02 sensor option. I had an LM2 but that thing is too big and complicated for what I was looking for and couldn't be integrated into the car for a permanent solution easily. Once everything was back in, I secured the Haltech in it's respective spot. -I reinstalled my Intake manifold and associated items along with it. I verified I had no fuel leaks and cranked the car over. She fired right up, so it seems like all is right at this point. I'll hook the laptop up this week sometime and go over all the sensors and settings. -I managed to get my turbo blanket in as well. Securing that thing with the safety wire is a nightmare. There has to be a better way of securing it or maybe I was doing it wrong. Either way, it's done and shall not be removed. -Years ago(because that's how long ago this build started) I ran a Cusco 40D strut tower bar. When I purchased my Shakitto plates, the bar end plates would no longer fit, so it was removed. I like the look of a high quality polished STB residing over the motor. So, I modified and painted the end plates to fit along with the Shakitto plates. I also took the time to polish the bar. Over the years I had "preserved" it's finish with Mother's metal polish. However, it was time for some Rouge polishing compound and a high speed wheel. Results are below. ![]() ![]() The bar pre polish... ![]() The bar post polish... ![]() ![]() ![]() Stay tuned, more updates when I get the chance.
*My SR20VET* Does your VTC gear rattle in your S14/15 SR? PM me. Last edited by jr_ss; 08-24-2014 at 09:25 PM.. |
#380 |
Thanks for the kind words guys, appreciate it.
First off, thanks for taking the time to read through the build. Second, I've run into a few hiccups throughout it. Obviously, the main one being the wiring harness. Now that it's sorted, it should be good to go. The other things that have prevented the tuning of this car were the purchase of a home/minor remodel and now the purchase of an engagement ring. All of these tend to cut into my funds pretty hard. Hopefully, by the beginning of Oct I'll have a date pinned down to get her tuned. Until then, I have a few things to do which I will update as they happen.
#381 | |
![]() Join Date: Mar 2013
![]() good luck man.
My Build |
#382 |
apexi head gasket
Hey man! this looks so good! if you don't mind me asking what apexi head gasket did you get? can you just get an det head gasket? forgive the stupid question...
#383 |
A DET headgasket will work. You will have to modify one front cover bolt hole though, which isn't a big deal.
#385 | |
S14/15's have variable intake cam timing only.
#386 |
![]() Join Date: Dec 2003
Trader Rating: (22)
Love it! Excellent work and great attention to the details. Sub'd for updates.
#387 |
my setup seems to be quite close to yours jr...with less clean details mind you, but the basics are quite similar....I'm still debating the VE(t) head swap. It seems quite early in your driving of this setup process (if much at all, idk), but other than the more reliable valve-train and higher potential for big power, I know it's not a stroker kit, but did the VE give u noticeable gains early in your powerband or is it all gonna translate to more top end...not that a bunch more top end is a bad thing lol.
#388 | ||
Another problem is, I've forgotten what it was like to drive a BPU'd SR vs my built SR. My BPU'd SR was fast but over 6years ago. The built setup was faster, but again, it's been some time. The comparison would be a bit muddled as I'm past the 4year mark of this thing being down. Hopefully in the next month I will have this driving, atleast to shake out the bugs. I'll be getting the harness bar in asap now that I know my issue doesn't lie in the ECU harness.
#389 |
Glenn, WTF is BPU'd?
dang I am a noob apparently.
@UpshiftEngineering |
