#1291 |
Do an rb25 and 26 have the same bolt pattern and will transmissions swap back and forth? Asking because of this kit http://www.atiracing.com/products/adapterk/akit.htm
It says rb26 but doesn't say rb25, which is what I have..... |
#1293 |
![]() Join Date: Mar 2008
For all the drag forks out there
I have rear drag kits for s13/14/15 cars with this kits has been in the 1.18 .60 ft Come with Afco 2 way adjustable coilvers All of the bracket to bolt together Text me for more info 559-210-4964 |
#1294 |
Can you just post up more info. May be interested for a S14
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
#1295 |
Agreed. I'd like more info and installed pictures. Anything needed to be modified?
#1296 | |
all of the coilvers are custom order comes with -Afco coilvers -springs -mounting brackets Shock mounting bracket allows the shocks to moved two inches out and it allows more Tire clearence no modification is needed it Pm spec of ur car power weight Rear end Tire price for kit is 1450 shipped to your doors |
#1300 |
Unreal's S14 - 7/25/14 @ Atco 14.3@103
Last run of the night. - yes i was sleeping at the light. Wanted to make sure the launch was nice. Ended up being pretty good! Spun 1st a bit. - Boost was at ~8psi - car was sluggish all night as my first few runs struggled to hit 100mph, ended up needing to trim the fuel map a bunch while in the pits. Was getting 10.0 AFRs for some reason. - 60ft was 2.304 (yes it was terrible) - extracting the log data in 4th gear into Virtual dyno gives me 238whp/250tq on Mustang Dyno Setting, Smoothing - 6. Vdyno sheet: https://fbcdn-sphotos-h-a.akamaihd.n...62448128_o.jpg |
#1301 |
![]() Join Date: Oct 2012
have some stuff listed in the FS section that should interest the drag racing crowd
Q45 swap, holeshot wheels, custom QA1 drag coilovers http://zilvia.net/f/showthread.php?p...82#post5693682 |
#1303 |
No this is from another"race" car that me and a budy where working on, it's going straight axle so no need for this stuff, my personal"street" car still has the q45 setup in it
#1305 |
![]() Join Date: Apr 2003
Trader Rating: (33)
![]() Feedback Score: 33 reviews
Well boyz....shameless plug if anyone needs some MT Bias Ply
http://zilvia.net/f/showthread.php?p...03#post5694203 |
#1308 |
![]() Join Date: Jun 2011
Man it has been way too long since I have been on here...I've been running pretty consistently in the mid 12s, with a 1.8-2.0 60'. I got my line lock installed, which has helped with burn outs and traction, now I just need to figure out how to set up the anti lag, to get me out of the hole. I have it set up with the AEM V2 ecu to where I have about 15-18psi of boost when I launch, but as soon as I come off the clutch the car falls on it's face...and then right about the 60' the power comes back in and the car starts doing some work.
So any other guys running the AEM V2 system with anti lag setup, or any anti las setup for that matter, having any success? |
#1309 |
![]() Join Date: Feb 2012
![]() Feedback Score: 17 reviews
Hi guys. I'm new to drag racing. My project is on the dyno and will.be tuned this week.
#1310 |
![]() Join Date: Aug 2013
Dude. You're car needs more attention to the rear diff than some old ass j30 LSD.
It's gorgeous BTW.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | ![]() |
#1312 |
If you want to preserve some of those drivetrain parts you should go with a bias ply tire not a radial for the track.
#1317 |
Ya the price for the tt axle is not going to be cheap. They are pretty rare and most aftermarket manufactures have stopped making the axles. So if you found one you should probably jump on it. Otherwise it might take you another six months to find one. I paid $230 shipped for mine.
Sr22 in the works |
#1318 |
Trader Rating: (33)
Check out the SoCal junkyards. For some reason its like the tribal graveyard for the TT axles. I reached out to a buddy that was working down there and he found 3 for me in about a months time. They are becoming more rare so act quickly.
