![]() Join Date: Jun 2010
Planted Low Seat Bracket?
I've been searching for some feedback on these and haven't been able to find much.
I'd like to know 2 things: -Do they put the seat as low as the proven options (Bride FG, Nagisa)? As in bottom of seat on the floor. Can the side-mount brackets be flipped? -Do they mount the seat far enough back for drivers over 6'? At least as far back as the stock seat can go, they don't seem to have much adjustment. Car is an S13, seat is a Sparco Sprint V and I have the Sparco side-mount brackets if I need them. Thanks! Edit: I was able to find some good information on how these brackets place the seat, apparently lower than Bride and Nagisa. That makes sense since there is no sliding mechanism. http://zilvia.net/f/showthread.php?t...hlight=planted, posts 3 and 7. I would still appreciate any other feedback though. |
I'm 6' and have around 6 inches from the top of my head to the headliner. I thought it was too low but I'm slowly getting used to it. Can barely see my hood, basically it feels like I am sitting on the floor.
My setup: Recaro TS-G and Nagisa Dual Lock Seat Rails, highest setting in the back and 2nd from bottom up front. Also, the Recaro I have was designed to sit low but is made for Japan-sized people so it may not fit you. Recaro RS-G is the same but sits more upright than my TS-G. Highly recommend this seat or RS-G to anyone who has a 32" waist or below, beware the seat costs a decent amount of money. |
#5 | |||
One bad thing about the Planted brackets is that they don't appear to have a mounting provision for the belt buckle. However, on my previous custom seat mount, I was able to fasten the buckle to the rear seat mounting stud on the transmission tunnel. I will try this again provided the brackets do not obstruct anything. |
![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
I'm 6'0" but I'm ALL torso so I sit pretty high. I had Bride FG rails with a Bride Zeta III. Swapped to planted and it dropped the seat about 3/4".
You can go literally as far back as you want. There are just 2 pieces of metal that meet together and you have to drill where you want them to sit. Very custom, not adjustable. http://zilvia.net/f/showpost.php?p=5...&postcount=300 |
![]() Join Date: Mar 2009
I'm pretty sure a single lock Nagisa rail can still go lower than this and retain the slider simply because with the individual brackets, you can flip the back ones underneath the rail and get super low. I have my rear Nagisa bracket flipped upside down under the seat rail and bolted at the then highest setting, which is still under the rail, and the front bracket also at the lowest setting but not flipped. Sets the seat leaning back super comfy and the seat touches the floor pan.
These are the brackets I've used
I've had Bestop brackets for my seats for over 2 years now and they ride pretty low.
![]() I actually bought it from ebay when I first got them but I can't find the link to that. Good luck mate. |
![]() Join Date: Jun 2003
Trader Rating: (130)
I have a set of planted seat brackets for sale if you're interested. Check out my threads for info.
![]() Join Date: May 2015
Reviving this. I have some questions in regards to the planted base mount or others like it (sparco makes them too).
So what I want to do is get a planted/sparco base, with sparco rails on top, and recaro side mounts with my SPG on top of that. The problem with the recaro SPG side mounts is that the rear mounting hole is placed so that the bottom of the seat is flush with the bottom of the side mount (L bracket). I realize that with other rails like that Bride FG, the seat can be mounted lower, between the rails. So my question is this:, with the mentioned setup where the seat can't be any lower than the top of rails which are mounted on a flat base mount, will it be low at all? Lower than stock even? Im 5' 6" but I still want to sit lower than stock (S14). Has anyone had any experience with this? Recaro SPG with recaro side mounts for reference: ![]() |
That setup isn't going to be low. Just get the Bride FG or Nagisa rails. Nagisa is now slightly higher due to a design change but still good. More info here: http://zilvia.net/f/showthread.php?t=638880
One thing I really don't like about the Bride rail is how much it leans back. My friend has one on his s14 (Bride seat) and even having it on a lower slot in the front it leans back too much.
EDIT: And they're slightly off center from the wheel which is irritating. |
#14 |
Planted brackets suck. I bought a pair and none of the mounting holes lined up to two of my S13's and these cars were bone-stock. Without drilling ovals on the tabs, the holes were way off.
I would rather have Nagisa, Bride or Buddy Club. |
