Old 02-04-2015, 10:30 AM   #1
asdfghjkl_carlos
asdfghjkl_carlos is an unknown quantity at this point
Clutch and flywheel problems
So I was reinstalling my flywheel and 2 of the bolts dont thread. They're in there, but I can keep using a socket and they don't tighten or loosen what so ever. I am not able to just turn them with my hand but they do turn pretty easily with the socket. What should I do about this ? I don't want my flywheel to come loose and have to drop the trans again to fix this.
Thanks guys !
asdfghjkl_carlos is offline   Reply With Quote
Old 02-04-2015, 08:21 PM   #2
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
They are most likely stripped..can you remove the bolts? If so look at the condition of the threads on the bolt and crank threads..one is messed up.hopefully the bolts are.
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
