11-16-2010, 04:02 PM | #31 |
anyone have a write up/ wana help me out with flipping the shit for us LHD BROS?
ive been DTMing for about an hour now, flipping this and that, theorizing different cuts and such, but i dont want to start cutting my shit up only to find out i could have done it another way... some one point me in the direction of a write up or PM me and show me how to do it.
RIGHTWHEELDRIVE.com
11-16-2010, 05:42 PM | #32 | |
Just be patient my dude
street dancer. GLEAM |
03-26-2011, 04:20 AM | #34 |
What trimming are you referring to? This is a straight drop in under the radio, just remove the din pocket.
Last time i had this installed in my 14 i never got the boost to work, i was told you need a specific boost solenoid/ controller. But if any one out there can correct me on that please do.
Nissan S14 Navan Zenki |
04-06-2011, 06:38 PM | #36 |
Just wondering if anyone ever got the boost gauge to work, would the part I need come with an S14 kouki swap or front clip? Anyone wana give me more input on how to trim the panel after you flip it for left hand drive so there isnt that gap?
Thanks Alex R. |
08-17-2012, 07:32 AM | #39 |
I love this guys, Im glad everyone is interested in this thread. Lets keep using this as an open discussion on the instal, imagine the info we could gather here.
Anyone ever figure out the following: Trimming the plastic trim for a flip for us USA drivers. What boost solenoid works with this setup? Iv heard only the boost selonoid from a same year and make kouki. What size light bulbs fit the DIN? Thanks Alex R. |
08-17-2012, 08:17 AM | #40 |
Trader Rating: (33)
Feedback Score: 33 reviews
24 iirc, just put leds in mine. you do need a boost sensor from a kouki s14. as far as trimming the plastic i can't really remember. i did mines sometime last year |
11-16-2012, 01:44 PM | #41 | |
the supply voltage of the sensor is 12volt. |
11-16-2012, 01:54 PM | #42 |
oil pressure sensor
05-22-2013, 04:48 PM | #44 |
Oil Pressure Sender Ground
Yes, and hello to you kind sir's. . .
Hold the bottom of the sending unit towards you so the plug part looks like an oddly shaped or fat "T", the prong on your left is the hot lead that you want to run to the gauges. The prong on your right is dead and has no use . . . You don't have to ground the right prong on the oil pressure sender. It is an unnecessary step. If you look on the Z32 harness, there is only one wire leading the the sending units plug. The other slot on the plug is blank (just plastic). Therefore there is no need to ground it. Also, there are three T4 bulbs that illuminate the triple gauge cluster for whoever was asking. Respect |
05-24-2013, 06:39 AM | #45 |
05-24-2013, 07:44 AM | #46 | |
IG @jerry_beans_ |
09-07-2013, 10:33 AM | #47 |
If u guys want I can post pics that I take later today on how to trim the plastic, it took me 10mins with a plastic knife (don't laugh I was in the barracks on deployment and was VERY BORED!!!), I'm going to also contact Nissan about the boost selenoid today...
05-19-2014, 02:59 PM | #48 |
Don't Ground the Oil Pressure Sending Unit
So, I have a 98 Kouki front clip and both pins of the oil pressure sending unit are used. The Z32 has the same sending unit and only uses one pin because there is an actual oil pressure gauge in the 300ZX gauge cluster.
Here's the wire colors on my 98 SR20DET Yellow/Blue Stripe = Stock dummy light switch for gauge cluster Yellow/Red Stripe = "Variable Ground" for the oil pressure Gauge In other words, the sending unit grounds through the engine and there is no reason to ground one of the pins. I've attached a pic of the sending unit and what the pins are for. Now if someone could post pics, or instructions on what to trim to flip the gauge cover, that would be great. Last edited by LoSt180; 09-03-2019 at 02:06 PM.. |
06-16-2014, 08:58 AM | #49 | |
1 - Black w/ pink-ish dots - Illumination Dimmer 2 - Red/Blue - Illumination 3 - Yellow/Red - Oil Pressure(OTM) 4 - Black - Ground(GND) 5 - Black/Pink - Boost 6 - Green - Ignition(IGN) The main difference is that on my harness solid black was ground and black with dots was for the dimmer. I spliced everything but Boost and Oil Pressure into the spare cd changer connections in the dash. Here's a pic of my notes, feel free to PM me if someone finds this and needs clarification. |
06-17-2014, 12:17 AM | #50 |
Would you elaborate more on the 300zx oil sender unit install, why does it need a coupler , why cant I just install it directly since since the 300zx sender unit is 1/8 bpt( I believe) just like.the OEM ka24 .
08-21-2015, 11:21 PM | #54 |
Trader Rating: (25)
Feedback Score: 25 reviews
So I thought I'd bring this up instead of creating a new one. Just picked one of these up and will be installing it as soon as I can locate a subharness. In the mean time, I got to looking at this thread and my gauges. I really don't like the boost being on the far end and the voltage being closest. While flipping the front plate to aim it to the US drivers side, I found that all 3 individual gauges can be moved around to each spot. The original voltage spot has only 3 of the 4 holes opened, but the boost guage uses that hole for a ground. The hole above it is also a ground, so hopefully that will be enough as that hole on the origianl voltage location is for a different function on the plug(ETS?). I know that this will obviously completely change the wiring diagram around, but that should be plenty easy to figure out. Anyways, here's a pic showing that it can be done. Sorry if this is common knowledge, I haven't seen anyone talking about it. Once I wire it up and get everything working I'll be sure to post which boost sensor I use and how I wired it up.
08-24-2015, 07:25 AM | #55 | |
08-27-2015, 12:08 AM | #57 |
I do.
Part Number: 25085-89900 Also found on '91+ Z32 TT models, all R33 turbo models. R32 too, bitch.
08-27-2015, 02:53 PM | #59 | |
Do as you please but I would just make sure to pick up a kouki sensor. |
09-02-2015, 01:20 PM | #60 |
Trader Rating: (25)
Just thought I'd share this tid bit of info I found today:
The J30 gauge cluster has the plug needed for these gauges. Obviously a rewire will be needed, but it would have been needed anyways if you're switching the boost guage to the drivers side.
