10-21-2015, 05:02 PM | #40658 |
New daily 96 SE one owner car.
Just plan on respraing the paint and getting suspension and z33 anniversary wheels under it for now.
WTB: zenki hood, passenger headlight!! |
10-22-2015, 11:53 AM | #40665 | |
It's come a long way since it was my daily in college. It was kinda rough when I got it.
'95 240 | @SleepySteve72 |
10-22-2015, 05:39 PM | #40666 |
Dude, what is this? An Evo 9 hood?!? Color me curious.
"Simplicity is the key to brilliance." - Bruce Lee |
10-22-2015, 08:59 PM | #40667 |
its the piece-of-shit-hood type II lmao
it was on the car when i traded my old daily for it. Im honestly not too sure what it is. its heavy as fuck, im assuming he took an evo scoop and molded it to a metal oem hood, bondoed a shit ton, and put a carbon wrap over it haha. the paint and everything else though is pretty nice. ill be getting an oem hood painted soon for it as i dont like the ricey-ness/heaviness of this one. this car still has a long way to go but itll get there in time |
10-22-2015, 09:47 PM | #40668 | |
-splice the OEM turn 12V power wire running FROM the front bumper turn signals -cut and REPLACE the 12V power wire currently going to the corner light with this new wire If you'd like to have the OEM corner lights function as both the marker and turn signals, you would simply: -source a 3 wire, dual-filament bulb base (i.e. 1157 or 3157) and retrofit it to the corner light plastic housing OR find a 194 dual-filament bulb -install a white/amber switchback bulb for the base type -splice the OEM turn 12V power wire running FROM the front bumper turn signals to power the turn signal portion of the bulb -use the existing marker light 12V power wire to power the marker light portion of the bulb Would operate something like this: https://www.youtube.com/watch?v=5i-p8zpB8-A |
10-23-2015, 12:59 PM | #40672 | |
10-23-2015, 02:24 PM | #40673 |
10-26-2015, 07:20 AM | #40679 | |
10-26-2015, 10:00 AM | #40680 | |
You basically switch between the power source for the side bulb between the flash source and regular source with a relay that is activated by the turn signal switch wire for each side. You can do this by installing a 5 post relay on each side with: - cut the side marker bulb positive as the relay output pin 30, - splice into the turn signal switch for one respective side as the relay signal pin 86 (85 to GND), - splice into front blinker positive wire for relay pin 87 (on with relay on), - and the other half of side marker positive as input to 87a (on when relay off). Last edited by zombiewolf513; 10-26-2015 at 12:05 PM.. Reason: Clarity |
