Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Engine
Old 12-15-2015, 02:42 PM   #1
phase2
phase2's Avatar
phase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of lightphase2 is a glorious beacon of light
P2M Upgraded Nissan S13 S14 SR20DET Ignition Coil Packs Now Released!
P2M Nissan S13 S14 SR20DET (RWD) ignition coil pack set is a direct replacement over the factory unit with the following improved features:
- Strictly produced via TS16949 certified manufacturing facility
- Top quality high insulation expoxy
- Top quality high voltage di-electric resistant resin
- 15% stronger spark output than factory unit
- Increased winding and improved iron core
- Dyno proven performance (+4rwhp / +5 ft lbs torque peak to peak)
- Compatible with all aftermarket ignition box upgrade
** Dyno graph based on stock S13 SR20DET running stock 8-9psi (0.6bar)
Can be ordered directly through our website or any P2M product distributors:
http://www.phase2motortrend.com/prod...cp50f01-tt.htm
Business Hours: Mon-Fri 10am-6pm (Pacific)
email: [email protected]
phase2 is offline   Reply With Quote
Old 12-15-2015, 07:23 PM   #2
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
count on me ordering a set of these soon! i am quite pleased with your throttle body velocity stack ring and the difference it made along with your side feed fuel rail (especially how nicely it installed). i look forward to running these in the near future!
Old 12-15-2015, 07:40 PM   #3
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
Is that price for all 4?
battery1882 is offline   Reply With Quote
Old 12-15-2015, 07:43 PM   #4
fatduece
fatduece is an unknown quantity at this point
Very nice, but pricey. How does it compare to the splitfire?
http://www.frsport.com/DIS-004-Direc...FUWVfgodzlcM9A
fatduece is offline   Reply With Quote
Old 12-15-2015, 07:44 PM   #5
phase2
phase2's Avatar
Yes price is for a set of 4pcs
Sent from my SM-G928T using Tapatalk
Old 12-15-2015, 07:45 PM   #6
phase2
phase2's Avatar
Thank you for your support [emoji1]
Old 12-15-2015, 07:49 PM   #7
phase2
phase2's Avatar
These are priced 1/3 from Splitfire price as far as I can see. Mainly these serve as OE replacement and an upgrade for people looking to replace their bad coils but instead of shelling out 60-70 bucks for a Genuine stock unit, you get to replace all four with an upgrade.
Watch our release of our stage two ignition upgrade amplifier box next year 2016, it will work nicely with our existing coil packs and still end up cheaper than Splitfires.
The stage two ignition box will be plug and play with Wiring Specialties built Pro harness. [emoji106]
Old 12-15-2015, 08:43 PM   #8
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
quick question, will you sell singles of these incase one burns up? (that common problem that plagued Splitfires)
Old 12-15-2015, 08:45 PM   #9
phase2
phase2's Avatar
Ofcourse we can, but this product is backed by our lifetime warranty we will replace the coils if they happen to burn out.
Old 12-16-2015, 06:11 AM   #10
economix
economix's Avatar
economix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud ofeconomix has much to be proud of
Between the price, increased performance, and lifetime warranty, I don't think I have a reason to buy from another vendor. You guys made this a totally awesome offering!
89 240SX w S14 SR20; 95 JDM 180SX S13 SR20; 09 Acura TL SH; 18 Jaguar XE S
economix is offline   Reply With Quote
Old 12-16-2015, 06:19 AM   #11
vipergtsr1000hp
vipergtsr1000hp is an unknown quantity at this point
Dang my splitfire coilpacks just came in this past week...Why couldnt this be out earlier lol. Also, thumbs up for the great prices and products you guys offer.
vipergtsr1000hp is offline   Reply With Quote
Old 12-16-2015, 09:27 AM   #12
fatduece
I see. Thanks for responding
Old 12-16-2015, 03:14 PM   #13
punkzdriver
punkzdriver is an unknown quantity at this point
Will these work on a VVL head?
punkzdriver is offline   Reply With Quote
Old 12-16-2015, 03:18 PM   #14
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Unfortunately, these will not
Old 12-20-2015, 08:16 PM   #15
SR20DETsilvia
SR20DETsilvia is an unknown quantity at this point
Have you tested these with any sort of ignition amplifier? I'm currently running the HKS Twin Power on my SR with stock coil packs, haven't had an issue but these seem a little "fresher" and wouldn't mind ordering/installing these more for piece of mind.
SR20DETsilvia is offline   Reply With Quote
Old 12-20-2015, 10:59 PM   #16
phase2
phase2's Avatar
Our P2M upgraded coil packs will work with all aftermarket ignition amplifier. The iron core and coil has also been improved so in essence they are actually stronger than stock in terms of reliability.
We will also be releasing our P2M plug and play amplifier for 2016 year which will work with our coil packs and stock coil packs, and will offer another ignition combo package for the amplifier + P2M coil packs combined.
Old 12-20-2015, 11:19 PM   #17
Dboyizmlg
Dboyizmlg's Avatar
Trader Rating: (18)
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Feedback Score: 18 reviews
Again, great products from Phase 2.
Quality, price, and lifetime warranty!!!
Will this be fine to use for people that already have Rom tune, PFC, standalone, etc. ?
No need for retune, I'm guessing?
Dboyizmlg is offline   Reply With Quote
Old 12-20-2015, 11:54 PM   #18
phase2
phase2's Avatar
No need for retune, maximize the ignition performance from your existing setup.
Old 12-21-2015, 09:23 AM   #19
fatduece
Wait...so it's $126 for 4 coil packs? I thought it was $126 For one coil pack.
Old 12-21-2015, 03:36 PM   #20
phase2
phase2's Avatar
Price is a set of 4 pcs.
Old 12-21-2015, 09:01 PM   #21
fatduece
Damn that's dirt cheap!
Old 12-21-2015, 09:11 PM   #22
phase2
phase2's Avatar
I guess we should mark it up higher then.
Old 12-21-2015, 09:17 PM   #23
fatduece
Haha! Good thing im about to complete my order.
Old 12-21-2015, 09:44 PM   #24
phase2
phase2's Avatar
I think your order just came in. We will have it ship out tomorrow, thanks for your support.
Old 12-22-2015, 05:27 PM   #25
fatduece
Nice! Thank you for making parts for our old cars.
Old 12-22-2015, 07:08 PM   #26
phase2
phase2's Avatar
More is coming for 2016.
Old 02-03-2016, 03:55 AM   #27
phase2
phase2's Avatar
Good bump
Old 03-28-2016, 03:29 PM   #28
drumnbasslvr
drumnbasslvr is an unknown quantity at this point
what do these ignition coil packs ohm out to as opposed to factory units? any info on dwell you can provide? where are they made? can they take the heat of drifting at 20psi? reviews and knowledge of this parts existence are lacking with its new item status. give us all a warm fuzzy about it and let the product go into back order for popularity sake.
1991 S13.5, 1993 Vert, 1998 180sx
drumnbasslvr is offline   Reply With Quote
Old 03-29-2016, 06:23 AM   #29
phase2
phase2's Avatar
The coil packs were built within the same OHM as stock, however the increased in spark energy and consistency comes within the improved coil pack iron core inside the coil pack. The improvement is consistent spark performance over the weaker factory OEM Nissan coil pack which improves torque and HP power curve.
We've yet to come across any heat issue, but with our life time warranty for P2M products we got you covered if anything goes wrong.
Old 04-03-2016, 09:34 PM   #30
ProjectPanda13
ProjectPanda13 is an unknown quantity at this point
Send a message via AIM to ProjectPanda13
Just installed a set of these on my motor
Quality product and looks awesome.
Latez
ProjectPanda13 is offline   Reply With Quote
