Old 02-03-2016, 01:34 AM   #271
jdm14
jdm14 is an unknown quantity at this point
I'm planning on going turbo. So my question is can I make 300HP with this setup and an Enthalpy tune.
Turbo: T25/T28 .64Ar (some aftermarket brand. not oem)
Injectors:550cc
Maf:z32
Thank You for any input
jdm14 is offline   Reply With Quote
Old 02-03-2016, 10:24 AM   #272
KAT-PWR
KAT-PWR's Avatar
Short answer; absolutely not going to happen on a t25 but you don't seem to know what turbo it is?
MRP Manufacturing
Old 02-03-2016, 10:42 AM   #273
Gingersmurf
Gingersmurf is an unknown quantity at this point
Might he be better off with a gt28r? My Sohc is going to get into the 300 range once i swap the t25 with a gt28r
KAs are like Frank's RedHot, Nissan put that shit in everything
Gingersmurf is offline   Reply With Quote
Old 02-03-2016, 10:44 AM   #274
jdm14
Ya. Im not sure what turbo it is cus it's not oem. What specs would i have to know about it?
Old 02-03-2016, 03:07 PM   #275
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
Look at other builds on here and other sites that have your hp goals and see how they accomplished it.
Just remember to use quality parts and get a good tune.
SoundEfx is offline   Reply With Quote
Old 03-01-2016, 04:03 PM   #276
DewMan000
DewMan000 is an unknown quantity at this point
So I'm thinking of building a ka24 just wondering if it would b err better to rip apart and rebuild the ka I already have or buy a block and start from scratch?
DewMan000 is offline   Reply With Quote
Old 03-01-2016, 05:08 PM   #277
KAT-PWR
KAT-PWR's Avatar
That's a question for you to answer. There is no difference. Can you afford not driving the car with the motor in it?
MRP Manufacturing
Old 03-01-2016, 06:31 PM   #278
DewMan000
True. I have another car I could drive in the meantime but it would probably just be better to start from scratch to avoid that
Old 03-03-2016, 08:24 AM   #279
josh_schul
josh_schul is an unknown quantity at this point
From personal experience... if you wanna build a motor... I'd find a spare one. They can be found dirt cheap.
Sent from my SAMSUNG-SM-G870A using Tapatalk
josh_schul is offline   Reply With Quote
Old 03-03-2016, 04:03 PM   #280
jdm14
Could I boost with a t28 and keep using a smic? Im trying to stay lowkey. Just trying to get more hp over my initial t25 setup.
Old 04-29-2016, 05:42 PM   #281
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Best cast KA turbo manifold? Everything I look up is from like 2007 so I don't know what's available now that actually works
corkscrew is offline   Reply With Quote
Old 05-21-2016, 03:49 PM   #282
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Why would you want to use a cast manifold? Is is because of the lower cost of them?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is online now   Reply With Quote
Old 05-21-2016, 06:06 PM   #283
KAT-PWR
KAT-PWR's Avatar
Because they don't crack, usually. Turbo placement is often better than the majority of tubular manifolds.
MRP Manufacturing
Old 05-21-2016, 06:25 PM   #284
FeArZ
FeArZ's Avatar
FeArZ is an unknown quantity at this point
I have a modified sr20 cast manifold with a ka flange for sale. Its a bottom mount. As KA-T said go cast no cracking ever.
Research the sr20 manifolds being used on Ka's its great for a stealth setup.
FeArZ is offline   Reply With Quote
Old 06-04-2016, 11:05 PM   #285
jdm14
Hey. So if any of you have any advice that would be great. Just finished replacing the headgasket on my ka24det. Now the engine wont start unless you pump the gas while turning the key. Any help would be greatly appreciated.
Old 08-05-2016, 03:43 AM   #286
DJ PoW
DJ PoW's Avatar
DJ PoW is an unknown quantity at this point
Send a message via AIM to DJ PoW
Check distributor, check injectors, check maf. You sure the timing chains are in the correct position?
Just double check everything and I'm sure you'll figure it out.
www.PowerAutosports.com
DJ PoW is offline   Reply With Quote
Old 11-20-2016, 07:19 PM   #287
jimbean325
jimbean325 is an unknown quantity at this point
Hey I'm a newb who needs help.
What are some good sites for KA24DE parts, Do you know of any good turbo kits for it and what would you suggest for an upgrade path, I already have new wheels and summer tires as well as coilovers and I upgraded my brakes.
jimbean325 is offline   Reply With Quote
Old 12-19-2016, 05:50 AM   #288
Aftermarke7
Aftermarke7's Avatar
Aftermarke7 is an unknown quantity at this point
I have an obd1 95 Nissan 240sx with a stock ka24de installed. No wideband as of yet, just the 02 sensor. (Wanted to learn the basics before adding the turbo system)
AEM CAS Trigger disk installed.
Here's the deal, I'm using the calibration file that matches the number that's on the sticker on the EMS.
The car barley starts and runs VERY VERY rich, won't rev smooth ,and by that I mean it studders while revving sometimes, other times it rev's a little better but still not as good as stock. If left idling it will idle low, around 500-700 rpms and will randomly stall out maybe in 1 minutes or 30 seconds. Its random.
If i rev, black smoke. If I hold my hand in front of the exhaust, its covered in black soot particles in seconds.
Obviously there is way to much fuel. However on the base map shouldn't this run the car somewhat normally?
I have plugged the stock ecu back into the car and it runs 100% stock.
All sensors are connected, Stock MAF, Stock TPS,, Stock CTS, Stock 02,.. etc
Is it because the aem needs a wideband and the 02 sensor voltage is throwing it off?
I can't set timing on the aem to the car because it won't stay running long enough with the base map. I have tried ALL the relative stock calibrations for this car, only one starts it.
I also have tried this with the aem ems throttle position settings synced to the car and the way the base map came.
ANY HELP IS APPRECIATED!
Really looking forward to your response.
Thank you.
Aftermarke7 is offline   Reply With Quote
Old 12-29-2016, 02:44 PM   #289
KAT-PWR
KAT-PWR's Avatar
You jumped into the deep end.
You need a wideband to trim the fat from the fuel table. Base maps are usually a very rough tune. Unless some other value is also changed effecting the ecus interpretation of fueling
MRP Manufacturing
Old 01-18-2017, 02:50 PM   #290
s13alltheway!
s13alltheway! is an unknown quantity at this point
I just did my Kat with a t4. It wasn't running or idling smoothly and would cut at 4k rpm. Thought it was my tune but ended up being my pump. Big shout out to garage life in elmonte. I thought it Was going to cost me 500 for a dyno tune which was a great deal but they were honest and installed aem fuel pump instead. Thanks for the savings!
s13alltheway! is offline   Reply With Quote
Old 02-28-2017, 04:48 PM   #291
SolTNtuz
SolTNtuz's Avatar
SolTNtuz is an unknown quantity at this point
Hi there, I am looking for a place to dyno tune my 89 240sx KA24DET.
Live in Drummondville, will never return to Total tuning again as I was not pleased with the service last year. I am having a hard time getting a hold of Robin Almasi ( I think he goes to China until late spring early summer ).
Is there anyone else that that is good in Montreal area.
Thanks in advance.
SolTNtuz is offline   Reply With Quote
Old 03-05-2017, 06:40 AM   #292
hatch4life
hatch4life's Avatar
hatch4life is an unknown quantity at this point
Anyone have experience with the new tomei ka poncams? can't find any reviews on them
hatch4life is offline   Reply With Quote
Old 08-18-2017, 11:50 PM   #293
jdm14
Hey guys. I was wondering if you can offer any help on my friend's ka24det. We're having problems with the afr's at WOT. When you first step on it it goes to 9 then it gradually goes up to high 12s-13 and stays there. What do you guys think is the problem?
Old 11-09-2017, 12:09 PM   #294
Flynbrick
Flynbrick is an unknown quantity at this point
Lots of fuel, also where are AFRs being measured?
Sent from my SM-N910T using Tapatalk
Flynbrick is offline   Reply With Quote
Old 11-09-2017, 12:25 PM   #295
jdm14
Its on the downpipe before the catalytic converter.
Old 12-22-2017, 09:51 AM   #296
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
I went through this on my Ka-t and it was pretty terrible. It would go way too rich in the low end, then lean out. I turned up the fuel map thinking it was tune related, but really my fuel pump was just dead and couldn't keep up. The first thing to do is figure out whether this is a tuning issue or something related to the actual mechanical engine. What are you using to tune?
apex128 is offline   Reply With Quote
Old 12-24-2017, 09:45 PM   #297
jdm14
Enthalpy ecu. Just replaced the fpr with a tomei thinking it would help. No change.
Old 12-24-2017, 10:34 PM   #298
apex128
Could be a faulty maf sensor. Are you sure the injectors and maf match the tune also?
Sent from my 831C using Tapatalk
Old 12-24-2017, 10:35 PM   #299
jdm14
Ya. Im sure. How do you suggest to troubleshoot the maf?
Old 12-24-2017, 10:44 PM   #300
apex128
You can measure the signal to make sure it's in the right range at idle. Obviously swapping it out is an option but that could cost money. Does the car idle at the right afr?
