Old 03-30-2016, 11:15 AM   #19501
wsmiteh
wsmiteh's Avatar
wsmiteh is an unknown quantity at this point
OEM Navan Markets
Might be a fairly obvious answer, but can't seem to find any info in an admittedly half-assed cruise through google/zilvia...
Which markets offered Navan aero, was it Japan only? Came up talking to a couple buddies a while ago, and nobody seemed to know for sure.
Cheers.
wsmiteh is offline   Reply With Quote
Old 03-30-2016, 12:23 PM   #19502
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
^^^ Japanese factory options only
Also, a small amount of Navan interior parts were offered for the S13 in Japan too.
Old 03-31-2016, 12:37 AM   #19503
white95zenki
white95zenki is an unknown quantity at this point
were all 1997 and 1998 240sx in the US market koukis?
white95zenki is offline   Reply With Quote
Old 03-31-2016, 12:40 AM   #19504
wsmiteh
wsmiteh's Avatar
Awesome! Thank you, I was kind of thinking it was a Japanese market option only!
@white95zenki You betcha!
Old 03-31-2016, 01:05 AM   #19505
white95zenki
@wsmiteh thanks man appreciate it
Old 03-31-2016, 01:19 AM   #19506
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
yes... not sure hows there confusion over that
Old 03-31-2016, 10:11 AM   #19507
cyz0r
cyz0r is an unknown quantity at this point
i found the part number 62560-35F00 for the head light brackets for the Silvia front end conversion. Are both the same part number or is theres a left side thats different?
cyz0r is offline   Reply With Quote
Old 03-31-2016, 10:31 AM   #19508
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
I actually have the same question, bought my bracket set and they both look the same, they bolted up just fine, but I have yet to try to put the headlights on em
Originally Posted by bigs View Post
Just get a big sticker that says "copyright infringement"
kashira kureijii is offline   Reply With Quote
Old 03-31-2016, 10:31 AM   #19509
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
both are the same part
Old 03-31-2016, 11:05 AM   #19510
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
Are ISIS a decent option for SS brake lines? I need z32 conversion ones.
Crazyced is offline   Reply With Quote
Old 03-31-2016, 01:17 PM   #19511
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Eyh, I'd look at something Goodrich produced. The last thing I'd ever want to go 'affordable' with are brake lines...
Old 03-31-2016, 01:19 PM   #19512
Crazyced
Crazyced's Avatar
I'd love to, but they don't seem to be doing them for s13 with z32 brake swaps.
EDIT: Nevermind, just couldn't find it on enjuku. I'll go with them thanks.
Old 03-31-2016, 01:23 PM   #19513
codyace
codyace's Avatar
Trader Rating: (58)
http://www.frsport.com/Goodridge-222...X_p_12110.html
Edit: Woops! Didn't see your edit. Cheers!
Old 03-31-2016, 03:44 PM   #19514
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
Is the clutch slave cylinder the same between SR and KA?
Wife told me that the clutch pedal sometimes doesn't come all the way back up, like it sticks halfway. Figured I'd try replacing the master and slave cylinders.
Old 03-31-2016, 04:07 PM   #19515
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
master cylinder is the same, slave cylinder is NOT. i believe you need to use a slave cylinder from a 91-94 KA24de and NOT an 89-90 KA24e (both will work, 91-94 KA slave is whats meant for the tranny though as its slightly larger).
Old 03-31-2016, 04:12 PM   #19516
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Guess I should've specified that this is an S14 with S14 SR. Can I use a KA slave on an SR trans?
Old 03-31-2016, 04:19 PM   #19517
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
yes, just make sure you get one meant for a twin cam KA...
Old 03-31-2016, 05:07 PM   #19518
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Thank you. Both parts are only $28, so cheap compared to my G35 lol.
Old 03-31-2016, 07:40 PM   #19519
Lompang
Lompang is an unknown quantity at this point
If I remove the factory hood anti theft switch for a 1995 SE will that prevent my from starting? Replaced Starter and Ignition Switch my car is getting fuel and spark, but is not cranking at all. Turn the key with no noise bypassed clutch safety as well and does nothing. If I take the key out some dash lights stay on in the same area around the check engine and my power windows will still work for some reason.
Lompang is offline   Reply With Quote
Old 04-01-2016, 05:42 PM   #19520
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
Ok, i know that an o2 sensor is supposed to sweep from 0-1 volt in closed loop.
Is it supposed to still sweep regardless of whether the engine is running lean or rich?
Im having a misfire issue at idle and noticed that when it starts missing, the o2 stays pegged at 0 volts. My afr goes full lean as well. Its not a constant misfire either, just a hiccup if you will.
Javi802 is offline   Reply With Quote
Old 04-01-2016, 08:55 PM   #19521
Kadeisaboss
Kadeisaboss is an unknown quantity at this point
I have a question, in my neighborhood there is a lady who has a 280zx and it looks like it is mint condition and it is a 1979, I was just wondering what a good price for that would be.
Thanks
Kadeisaboss is offline   Reply With Quote
Old 04-01-2016, 11:20 PM   #19522
Mattpaul876
Mattpaul876 is an unknown quantity at this point
Okay I have a 89 hatch with a sr20 body harness in it. I have a KA that I want to put in it because I have no access to a sr. What modifications need to be made someone please help me out
Mattpaul876 is offline   Reply With Quote
Old 04-02-2016, 12:26 AM   #19523
derass
I highly doubt anyone swapped the body harness of a 240SX to that of an SR powered car. There's simply no need, unless it was a BARE shell with no wiring at all. How do you know the car has an SR20 harness?
Old 04-02-2016, 09:12 AM   #19524
codyace
codyace's Avatar
Trader Rating: (58)
Are you getting 12 to the starter? Are you getting 12v to the starter signal wire when you key over? First two places I'd check.
The o2 should always 'sweep' back and forth, regardless of closed or open loop. Now with that said, obviously only in closed loop operation does the ECU utilize the O2 for actual air fuel
With that considered, at idle, the ECU does not utilize o2 sensor, as it's in open loop. Even if warm, at idle, (if the TPS shows off) it doesn't use the o2 for anything.
As far as activity, You should see it swing back and forth pretty actively...it it only swings 5 or 10 times a minute then the o2 is starting to fail, and closed loop operation will suffer.
With all of this considered, you can also run the car in total open loop by disconnecting the o2 sensor. May be worth it just to try something.
Thanks
Whatever you want to pay. It's up for the owner to decide if your offer is what they want to sell it for.
Agreed
Old 04-02-2016, 12:13 PM   #19525
JayJay240sx
JayJay240sx is an unknown quantity at this point
s13 s14 clutch master cylinder in an s13
Will an s14 clutch master cylinder fit an s13?
JayJay240sx is offline   Reply With Quote
Old 04-02-2016, 02:44 PM   #19526
LoSt180
LoSt180's Avatar
Trader Rating: (18)
The Centric replacement has the same part number for S14 & S13, so must be the same.
Old 04-02-2016, 03:52 PM   #19527
JayJay240sx
Whenever i look up the part it always says s13/s14 but when i called the nissan dealer they said they dont make parts for older than 94, so i asked if the s14 one would fit my s13 n he said no, i wanna get the dealer oem one because i just put in a duralast n the shit messed up already, so i guess what im saying is r u sure lol?
Old 04-02-2016, 06:21 PM   #19528
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
How does one test the dual pressure switch on the S13 KA AC system?
The system is recharged. The relay is good. It blew cold before sitting for a while.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 04-03-2016, 12:00 AM   #19529
cyz0r
are silvia s13 OEM fenders around 10 pounds each? i found a post saying s14's were 8. im trying to get some shipped and just said 10 to be safe but now im second guessing myself if thats too light.
thanks in advance guys.
Old 04-03-2016, 07:10 AM   #19530
I'm Redline
I'm Redline's Avatar
I'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to all
From the Centric/Stop Tech tech:
For your 240, there are basically only a few brake parts. 4 lug, and five lug, pre '96 ABS and Non ABS, and 96 forward since Nissan used ALL ABS sized brake parts post '96. Now I have not personally tested this, BUT, my '96 SE, manufacture date July '95 uses all 'ABS' rotors and parts, as does my son's '97 kouki, neither car being an ABS car. The rotors, Master and slave cylinders, calipers, are all the same.
My first zenki, an auto SE, manufacture date July '94, non ABS, five lug used the slightly smaller '95 non ABS parts...until it got totaled 3 weeks after I bought it.(Lesson here, never let your ol lady take your car to work, because idiots making left turns into oncoming cars will hit it. She was just sitting there when the big caddie SUV caused the destruction of a rental Sentra, my 240, and frontal/right front damage to her own SUV. Wait, bigger lesson...women should simply NOT drive. This is why they invented busses and taxi's)
1996 Zenki 'Baraketsu Tenshi', Burst Angel
My work in progress...
I'm Redline is offline   Reply With Quote
