Old 06-02-2016, 05:09 PM   #11581
TheRealSy90
TheRealSy90's Avatar
SRDF gets mentioned on DIW...
N***A WE MADE IT!
Such a good signature.
Old 06-02-2016, 05:18 PM   #11582
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
**vapes bravely in the face of haters**
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 06-02-2016, 06:10 PM   #11583
zombiewolf513
Originally Posted by deolio View Post
wheel flying off and pushing the trunk floor up is the freak accident part boss
Not a freak accident when you don't tighten your lug nuts, then it's only a matter of time.
Old 06-02-2016, 06:42 PM   #11584
deolio
deolio's Avatar
that part on its own is not, no, but wheel falling off, pushing the floor in, and ejecting the battery, hitting a spectator would be...
Old 06-02-2016, 06:47 PM   #11585
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
i'd bet 20 year old sheet metal and shitty summit racing j-hooks would result in a similar outcome. you should go out and test it in your car.
I bet the hooks would have held fine through the sheet metal. Look at the pic again. His wheel impacted the spare tire well and made that zone flex upward. It was one hell of an impact, we all get that, but it didn't even hit where the tray was mounted. The impact was more than enough to rip through the plastic tray but the sheet metal in his tray area isn't even mangled, it just got pushed up. We get that you don't get it and that's ok. This topic is getting old anyway.
Why don't you go try it on your car? Clearly my battery is already mounted properly.
Sent from my iPhone
https://instagram.com/e_lemonation/: @e_lemonation
Old 06-02-2016, 08:28 PM   #11586
kashira kureijii
kashira kureijii's Avatar
kashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-knownkashira kureijii is making his/her stupidity well-known
since everyone's so obsessed with trunk batteries here, I'll pose a question,
When I did mine I used a optima gel cell battery, as I was afraid that there would be fumes associated with a liquid battery that would float around in the cab(you know cuz serious battery acid stuffs).Also if your trunk battery randomly leaked, you'd have a more difficult to fix area if it rusted
I've noticed all the pics feature liquid batteries, so is them fuming not a concern of ya'lls?
Is getting battery acid fumes in your cabin DIW? or is it a non-issue?
will be relocating another one soon, so if no one has had serious fume poisoning I'd like to save some money haha
Originally Posted by bigs View Post
Just get a big sticker that says "copyright infringement"
kashira kureijii is offline   Reply With Quote
Old 06-02-2016, 08:37 PM   #11587
shephurd
shephurd's Avatar
shephurd is an unknown quantity at this point
I want to imagine a NASCAR style pit stop resulted in this kids wheel coming off.
shephurd is offline   Reply With Quote
Old 06-02-2016, 08:52 PM   #11588
Mister.E
Mister.E's Avatar
Trader Rating: (53)
My battery box has a vent tube. Go back to the previous page and you can see the little nylon bulkhead fitting near the bottom left corner right by the dangling negative terminal. I will be switching to an Optima as well. I can't tell you much about the fumes because I've always run a red top.
Sent from my iPhone
Old 06-02-2016, 09:58 PM   #11589
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Freak accidents are EXACTLY what standard safety equipment is for. Get that millenial snowflake shit out of here.
God I wish I could negative rep these comments.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 06-02-2016, 10:09 PM   #11590
kashira kureijii
Sent from my iPhone
Ah, didn't notice, my bad.
Old 06-02-2016, 10:21 PM   #11591
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
+ postive rep
Corbic is offline   Reply With Quote
Old 06-02-2016, 10:31 PM   #11592
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
agreed, so lets all write our congressmen and protest this.
lol everyone is an osha inspector all of a sudden.
I didn't know OSHA tech'd race cars Seriously though, common sense is kind of important. I pre-tech our race cars (and customer cars as well) at least two weeks before events, to identify anything that needs to remedied and to allow time to perform preventative maintenance.
Things like chafing AN lines, expired belts, getting the fire extinguishers tested, damaged wiring insulation, leaky fittings, damaged belts, loose suspension components, bad wheel studs, wheel bearings... You'd get laughed out of a serious motorsport event if your car rolled into tech like that. I understand that shit happens, but you can't neglect safety/wear items.
If it was a lead acid battery in that tray, he got LUCKY it exited the car. Imagine if it rattled around in there and got punctured OR got jammed against the chassis and arc'd out on the metal..
There would have been one hell of a mess to clean, and he himself could have p gotten acid burns. And the crowd got lucky it didn't get punctured on the way out, which could have sprayed the spectators with acid.
Bingo! My business and its reputation are based on the level of safety and reliability we incorporate into our customer's cars. Safety of the drivers, accessibility for first responders, reliability of the turn-key package. Accidents happen, and thats exactly why you try to build a safe car; to mitigate the damage as best as you can. Mishaps like what happened to that S14 are inexcusable at any level of racing. I sincerely hope that he wasn't paying anyone to put that car together for him before the event.
Originally Posted by GTR-Garage
Handling, power and style must be in harmony.
bataangpinoy is offline   Reply With Quote
Old 06-02-2016, 10:45 PM   #11593
bataangpinoy
1) Gel cell and AGM batteries do not produce gas like a lead acid battery, thus not requiring the use of a sealed & vented box. Don't forget cover the positive battery terminal with some kind of rubber or plastic shroud. Cheap insurance.
2) The fumes are a very valid concern. Don't compromise your safety for the sake of saving money.
I tell people with street cars to leave the battery in the engine bay if you can, even if you have to get a smaller AGM unit. Keeps the wiring nice and short, and reduces the chance of the positive lead getting pinched/frayed in the case of an accident.
Old 06-02-2016, 11:28 PM   #11594
Mister.E
Mister.E's Avatar
Trader Rating: (53)
No worries dude, you don't have to apologize. It was a very valid question.
Sent from my iPhone
Old 06-02-2016, 11:51 PM   #11595
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
This battery tie down and tech inspection talk is getting repetitive... But since we're on the subject. How about Dave Comstock's nitrous bottle rocketing out of the car. Jake's an e-thug, he throws fits when shit gets real, he wears flip flops on the track, and has a nice rack.... But freak accidents happen. Lets try to move on.
http://www.youtube.com/watch?v=r7STt_6I5Dw
PS is that blue miata kid that got arrested one of the haggard garage kids? The video was removed from the news site that was linked.
Kuma is offline   Reply With Quote
Old 06-03-2016, 12:17 AM   #11596
deolio
deolio's Avatar
ok so then we shouldn't even step outside our front doors or even have electricity in homes. where does it stop?
would rather hang out with jake and risk my life every day than abide by every fucking rule you pussies feel is necessary.
Old 06-03-2016, 12:18 AM   #11597
zombiewolf513
Originally Posted by Kuma View Post
WOAH. Is that dude alright? That's like that scene in Taladaga Nights
Old 06-03-2016, 12:30 AM   #11598
derass
Here's my take: if you don't torque your wheels at a track day, you're a moron who has no business being out there, or working on cars in general for that matter.
Old 06-03-2016, 12:38 AM   #11599
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
No tech track days sound like fun, it could be like Mad Max.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 06-03-2016, 12:42 AM   #11600
Kuma
Kuma's Avatar
yeah, that was daddy Dave from street outlaws. He's already built goliath 2.0.
Bad wrecks happen all too often at no prep events.
Old 06-03-2016, 01:03 AM   #11601
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
People have a point about the inspection at Final Bout being weak. This is such a peasant trunk. I thought minimum pass requirement was color-matched metal with Persian rug cushioning.
Old 06-03-2016, 01:17 AM   #11602
deolio
deolio's Avatar
i like it! but with less dust
Old 06-03-2016, 01:29 AM   #11603
zerodameaon
Ride along strapped to the hood.
Old 06-03-2016, 05:35 AM   #11604
7evil
7evil's Avatar
7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough7evil is a jewel in the rough
七転び八起き
7evil is offline   Reply With Quote
Old 06-03-2016, 05:38 AM   #11605
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
Why is there playground equipment strapped to the back of that car?
lunchmeat is offline   Reply With Quote
Old 06-03-2016, 06:48 AM   #11606
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Lol either you're blind or you're blind. The impact was pretty much EXACTLY under the battery tray. Can you not see how now the floor on that side is like 45* canted upwards?
Old 06-03-2016, 07:16 AM   #11607
jaysgottaredtop
jaysgottaredtop's Avatar
jaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enoughjaysgottaredtop will become famous soon enough
Now back to gaudy stuff
jaysgottaredtop is offline   Reply With Quote
Old 06-03-2016, 07:17 AM   #11608
Corbic
Corbic's Avatar
Old 06-03-2016, 10:25 AM   #11609
kingkilburn
Philosopher King
By all means, be a bunch of idiots and kill yourselves(doing some obviously sketch shit). Do it away from others that don't wish to trade safety equipment for hoonigan stickers .
Old 06-03-2016, 10:29 AM   #11610
kingkilburn
Philosopher King
You guys couldn't even bother to clean the damn trunk and properly wire in the sub. Never mind that that big speaker shouldn't have been allowed on the track to begin with. I'm surprised someone in the crowd didn't wear it home.
