Old 08-15-2016, 06:08 AM   #361
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
ARC coil pack cover and HKS oil cap looking really good together. Love how the purple on each part matches up perfectly together. In the picture the purple on the coil pack cover looks lighter, but in person both purples look pretty close.
This weekend I was able to get a lot done...routed the wiring harness, installed the abs and brake lines, a/c lines and a lot of other little things. Most everything that is left is little stuff except relocating the battery and trimming the bumper for intercooler piping.
This is the most ridiculous thing I've ever seen. How did a company like Tomei miss this. This is a JDM chassis too...not sure what to do at this point. It's prob either change to a different design or smash a dent in it to clear it.
Instagram: @garagelu
garagelu is offline   Reply With Quote
Old 08-15-2016, 07:38 AM   #362
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Maybe it's not meant for the s15?
Old 08-15-2016, 11:50 AM   #363
garagelu
Trader Rating: (60)
I just reached out to Tomei USA and they are going to talk to their Japan team to see if they have run into this issue before. I would expect them to refund me money for this part since I won't be able to run it if they can't figure it out.
Old 08-15-2016, 12:07 PM   #364
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
I can't see what its rubbing against? Heater hose? Could be because of the HKS Manifold. For example I know you can't use a PBM downpipe with a Tomei manifold.
Ramonesfreak2010 is offline   Reply With Quote
Old 08-15-2016, 12:54 PM   #365
garagelu
Trader Rating: (60)
But it's a stock location manifold...I wouldn't think it would affect it. It shouldn't be any different than running a stock manifold. And dang I didn't know you can't run a PBM downpipe with tomei manifold. Any reason why?
Its hitting the a/c drain hose. Normally on a USDM car, the drain is on the other side.
Old 08-15-2016, 04:18 PM   #366
Ramonesfreak2010
It pushes the turbo back towards the firewall causing the pipe to hit the transmission. I'm not sure if this issue was fixed, but that was an issue when they first were released.
That is the only thing I can think of with your issue. Hopefully Tomei comes through!
Old 08-16-2016, 08:51 AM   #367
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
I contacted PBM about this back in 2010. When I went to install the Cobra downpipe with Cusco solid engine mounts and a Tomei exhaust manifold, the elbow hit the transmission. I had to heat it up and take a hammer to it to make it clear. I think I am the source of this always being talked about on the forums.
Not sure if they fixed the issue or if it was something isolated with my setup. I am running a Cobra downpipe again now but with a stock turbo manifold this time around.
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 08-16-2016, 01:54 PM   #368
garagelu
Trader Rating: (60)
Hopefully Tomei will refund me money for this crap so I can go buy a cobra downpipe because it looks like tomei extends out further before turning down whereas the PBM one turns down immediately. I would hope the PBM fits better.
Old 08-16-2016, 02:05 PM   #369
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
I am purchasing a S13 Coupe as we speak. I think this is the culprit to the strange harmonics I am getting from under the car. Its related to RPM (2500-3200) in every gear. I see clearance around the firewall and Cobra DP but I haven't looked closely at the relation to the trans housing. I am running the stock mani with GTX2867R turbo btw. Any specific area to look for?
IG: @scotheocelot
scottie is offline   Reply With Quote
Old 08-17-2016, 05:28 AM   #370
soundboy
soundboy is an unknown quantity at this point
This is beautiful.
soundboy is offline   Reply With Quote
Old 08-17-2016, 08:47 AM   #371
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (30)
Nissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura about
Feedback Score: 30 reviews
Wow props good shit, im looking for a s15 right now myself.
Nissan2nr22 is offline   Reply With Quote
Old 08-28-2016, 03:22 PM   #372
turboshoebox
turboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymoreturboshoebox is not welcome here anymore
Originally Posted by MadScientist View Post
Good to see who bought this... I was the other buyer, glad you got it because I still have my Kouki and a Nismo Frontier now.
Oh and so everyone know this is a Grandfathered in U.S. Legal Motorex S15.... and it sold for hella cheep compaired to what some other non legal S15 owners are asking!!!
keep up the good work...
Lucky guy to have this car but I'm confused did Motorex claim they crash tested S15's too and brought this car to US compliance? If that was the case wouldn't this car now have rear reflectors?
I'm not here to start a legality batle but if it's 100 percent legit I'm super jelly
turboshoebox is offline   Reply With Quote
Old 08-28-2016, 10:07 PM   #373
maqshood
maqshood is an unknown quantity at this point
My tomei dump was touching the same hose on my 180sx. I think its due to the actual size of the dump itself. I was on a stock manifold btw. I just trimmed the hose as i dont have working AC atm.
maqshood is offline   Reply With Quote
Old 02-17-2017, 11:57 AM   #374
DrftKingIII
DrftKingIII's Avatar
DrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura aboutDrftKingIII has a spectacular aura about
I know you're having a good time in Miami and all....but it's time for an update!
- このノイズをファック -
DrftKingIII is offline   Reply With Quote
Old 02-17-2017, 10:05 PM   #375
Eric_Conkling
Eric_Conkling's Avatar
Eric_Conkling is a well-known jackass
Just went start to finish in one go! Hell of a car you've got going man! Excited to see some more updates!
Eric_Conkling is offline   Reply With Quote
Old 02-17-2017, 10:25 PM   #376
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
NSX driving
Old 02-18-2017, 12:33 PM   #377
koukimonst3r
koukimonst3r's Avatar
koukimonst3r is an unknown quantity at this point
Originally Posted by rawgarage View Post
NSX driving
More like vacuuming lol
ig : koukimonst3r
koukimonst3r is offline   Reply With Quote
Old 02-20-2017, 05:02 PM   #378
tricky_ab
tricky_ab's Avatar
NSX driving
The perks of the new job for real!
Instagram
Back for round two... 4 doors this time around...
Old 03-27-2017, 07:36 PM   #379
Will.
Will.'s Avatar
Will. is an unknown quantity at this point
Any updates on the car?
Will. is offline   Reply With Quote
Old 03-15-2021, 05:11 PM   #380
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
I'm sad now.
collegekid is offline   Reply With Quote
Old 04-13-2021, 01:31 PM   #381
Persona
Persona's Avatar
Persona is an unknown quantity at this point
I haven't seen car updates from him on IG either for a while. Such a bummer!
Persona is offline   Reply With Quote
