08-02-2016, 01:36 AM | #122 |
Absolutely. I wanted to make sure I wasn't missing something. The instructions that he provided did not reflect any changes to the design and said you have to grind down a portion of the starter. Just trying to iron out the details while the engine and transmission are out of the car and everything is still easy to get to.
08-02-2016, 09:08 AM | #123 | |
Its very tight left to right however I haven't driven my car yet My friend Landon said his was very tight left to right too but once he started driving it really acts normal. Ill report back once my car is running |
08-02-2016, 09:29 AM | #124 |
08-02-2016, 01:26 PM | #125 | |
08-02-2016, 02:36 PM | #126 |
The everything cd009 swap thread.
But his adapter also uses a different bellhousing than the Collins adapter so without a measurement of overall length to compare to its difficult.
Sent from my iPhone using Tapatalk |
08-02-2016, 09:30 PM | #127 |
Here's the measurements on my DL adapter I'm running
And the length from the face of the bell housing to the bolt holes for the shifter Sent from my SCH-I545 using Tapatalk
DLG - DIRTYLOVE |
08-17-2016, 07:07 PM | #129 |
Just placed an order from a group buy going on @ cbf performance. This shifter is adjustable fore & aft as well as side to side so it fits many application. Orig price is $350. Group buy is $185.
My setup is a 2J ->CD009 with Collins adapter. Here's the link to his ig page: https://www.instagram.com/cbfperformance/ Link to group buy: http://www.cbfperformance.net/store#...egory=19722030 Sent from my SAMSUNG-SM-G935A using Tapatalk |
08-18-2016, 05:51 AM | #131 |
We just did a cd009 to rb25 in a r32 gts
Collins plate was ruff and no instruction at all . Machined down the bellhousing to accept the plate Put every thing on the engin to figure out that the starter doesnt fit . Bellhousing need more grinding With the rb25 kit . The transmission is clocked like 4 or 5 degre (dont know if its an accident by collins) so shifter is tilting toward the driver(rhd) abit We installed 2 shifter . Firstly the serial nine We liked it because we could fine tuned our shifter position with our tilted problem ... but shift throw is super short and super easy to miss 3rd or 4th for other gears ... Second shifter and the one that is staying in GkTech Shifts are precised and not to short ... realy what i was looking for . Reverse lock out that work 100% Sit abit more back compare to serial 9 but were gona live with it since its a way better unit to our eyes
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
08-18-2016, 11:43 AM | #132 |
08-18-2016, 01:08 PM | #133 |
The gktech is a nice piece I sold mine already because I want to keep oem interior. So I'm going with serial nine. Any one have experience with the cbf?
08-18-2016, 03:02 PM | #134 |
Same here as I just bought an infinity myself. However I've heard it might be possible that the infinity can convert any speed signal internally and would make the dakota converter no longer needed.
08-18-2016, 09:27 PM | #136 | |
It doesn't. I believe he is running the trans behind a Jz or Ls though. Gktech is designed for Sr. Sent from my iPhone using Tapatalk |
08-19-2016, 08:34 AM | #137 |
Right a jz not sr with Collins plate on a s14. It could work but I want to keep it centered as possible and under oem shifter boot.
08-19-2016, 09:20 AM | #138 | |
I know of one, fitted to a 500+ Whp rb25 / ps13 . I think it started to whine a bit, after a couple of year of abuse as a pro drifting machine taking part in numerous european championships. It only needs new bearings. If it can take that kind of abuse (it really IS abused), i cannot see a zilvian user destroy one. Unless it is not correctly installed. Edit: quick question here. I do not like plate adapters for various reasons, and am interested in the JWT kit. There is something i don't quite understand though. It requires an automatic bellhousing; but is it a Z33 auto bell housing, or a SR20 auto bellhousing ? Has anyone here installed one ? Since i am using a CA18DET, i think i am getting in trouble here ... |
08-19-2016, 09:52 AM | #139 | |
Auto Bellhousing from the motor you are adapting to, IE SR- SR Auto Housing. Are the bolt patterns the same for SR/CA?
08-19-2016, 11:07 AM | #141 | |
It uses the auto bellhousing of the engine you have. Idk if they make a kit for the ca18 though. Sent from my iPhone using Tapatalk |
08-20-2016, 12:30 AM | #143 | |
the serial nine cd999 shifter is what you are looking for. i just picked one up myself. i'll snap a few pictures for you when i get a chance. but my buddy has been running one in his 700hp 2jz s14 for a bit now and its definitely the way to go for 2jz+cd into an s chassis. no cutting of the trans tunnel needed. retains reverse lockout also. i know they made a lot on their first production run and they are down to the last hand full already. https://serialnine.com/contact-info https://scontent-sea1-1.xx.fbcdn.net...ae&oe=58493A7A |
08-20-2016, 11:09 AM | #145 |
Everyone checkout my post a couple of posts earlier. Cbf is doing a group buy on any cd009 -> jz/ls/SR to an s-chassis. Pro series utilizes adjustable fore & aft as well as side to side.
08-20-2016, 11:35 AM | #146 |
Jason's pro series will be similar to the serialnine cd999 shifter setup, except it's a fraction of its cost. $185 group buy of 50 vs $450.
08-20-2016, 12:54 PM | #147 | |
Waiting to see how the final product will work out. Sent from my iPhone using Tapatalk |
08-20-2016, 08:06 PM | #148 |
for a jz to cdxxx i would do the speedtek cut and weld bellhousing with the gktech shifter .... with that bellhousing mod you dont need to cut the tunnel ... check them out on Facebook
08-21-2016, 03:22 AM | #150 | |
this looks super janky to me. the collins kit (the cut + middle plate) looks way better to me then this option. now if collins would get off his ass and make a plate compatible with the j3 housing we would all be golden. seems like everyone has a j3 housing kicking around but the j1 is far more rare. Last edited by jackal264; 08-21-2016 at 04:22 AM.. |
