Old 11-20-2015, 09:13 AM   #1
Mzag
Mzag is an unknown quantity at this point
Purple s14 Kouki 1jz vvti + cd009
Hey guys, Ive been in the 240 community for about 5 years now and had multiple cars but havent done any in depth build threads. Now that I have a project I plan on sticking with for a while I figured its the perfect time to start.
I originally bought it as my first car in 2012. I had all these dreams about what I wanted to do with it but being a 19 year old college student and having it as a daily severely limited me. I had the car for a year and did some minor modifications like coils, brakes, wheels, etc but I got bored of the car and moved onto something newer. A year after selling it I was given the opportunity to buy it back, so without hesitation I was the owner once again.
This time it came back looking a little different, JDM front bumper, grill, and paint matched carbon fiber hood. I bought some varrstoens es2 and the car now looked like this.
After only owning the car for a couple months I foolishly traded it for a rhd rb25 s13 because I had started drifting earlier that year and wanted something for the track. Fast forward to a year later, spring 2015. The s13 was gone and the kouki was back in my garage, this time as a project, not a daily.
When I picked it up the last time, my previous s13 in the background.
This is where the project starts, the car is currently sitting on jack stands in my garage fully stripped to the shell. The progress is slow but this time im not rushing anything and doing it right the first time. I received the motor last week which got the ball rolling on the winter build, more updates to come.
Mzag is offline   Reply With Quote
Old 06-26-2016, 09:07 PM   #2
Mzag
I know its been forever since this thread was started but I now have the car in a shop where I can finally work on it. Basically doing all the boring chassis work leading up to the swap...
Got settled into the new shop and started tearing the car down to a bare chassis
With all the rust repair that needed to be done I got adventurous and started looking for ways to flip the car over, I found the design for these stands online and went for it
Here come to disturbing pictures, the rust was pretty bad
A few weeks and a lot of sheet metal later
And how the car sits now, did the first coat of por15 on the entire underside
Old 06-26-2016, 10:20 PM   #3
tricky_ab
tricky_ab's Avatar
WOW! I love that you're taking your time with this, and doing it right.
Instagram
Back for round two... 4 doors this time around...
Old 06-27-2016, 10:17 AM   #4
alwaysSlideways
alwaysSlideways is an unknown quantity at this point
do it right or dont do it at all! love it!
alwaysSlideways is offline   Reply With Quote
Old 06-27-2016, 08:46 PM   #5
Mzag
Thanks guys, definitely a tedious process but hopefully I wont ever have to do this again.
I also went ahead and modified some stock knuckles and extended/boxed the front lca's. Then of course covered everything in por15.
Old 06-27-2016, 09:32 PM   #6
scottie
scottie's Avatar
scottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nicescottie is just really nice
It's refreshing to see chassis restoration done right. The underside looks brand new and POR15 should keep it that way.
IG: @scotheocelot
scottie is offline   Reply With Quote
Old 07-01-2016, 10:31 AM   #7
Jake S14 kouki
Jake S14 kouki is an unknown quantity at this point
Awesome man! Glad to see these cars being restored and appreciated in a proper way.
Jake S14 kouki is offline   Reply With Quote
Old 08-02-2016, 08:43 PM   #8
Mzag
Im terrible at updating this but Ive made a little more progress. The car is now off the stands with the gas tank and rear subframe back in. I started stripping the engine bay and had to take a little break from the chassis work and got started with the motor rebuild.
All new gaskets, arp headstuds, 2jz water pump, 2jz oil pump, drift motion pulleys, excessive motor mounts and ac delte bracket, and the collins cd009 to jz adapter kit.
I used my brothers motor/trans to test fit since mine wont be here for another week week, in and out twice with lots of pounding and cutting/welding to make that giant transmission fit.
And this past weekend I finished up the engine bay rust repair and painted it gloss black.
Old 08-21-2016, 09:05 PM   #9
Mzag
Another little update. Finally getting down to the little things until it moves under its own power.
I relocated the engine bay fuse box to the passenger side kick panel which isnt too hard, but adding the connections and relays for the engine harness at the same time made for some long days of wiring.
Picked up the cd009 trans from lkq so i could finally put the motorset in for good.
Im using the gktech shifter and it still landed a couple inches behind the factory shifter hole. This is also with xcessive motor mounts all the way forward. Planning on re working the shifter itself with some bends to try and get it in the center.
Made the trans crossmember
And finally the motor sitting in the bay
Old 08-21-2016, 11:46 PM   #10
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Damn great start and attention to detail...
Old 08-22-2016, 06:56 AM   #11
05subysti
05subysti is an unknown quantity at this point
Love the underbody restoration, there was a lot of rust! Any plans to upgrade fuel system/turbo/engine management?
05subysti is offline   Reply With Quote
Old 08-23-2016, 09:05 PM   #12
tricky_ab
tricky_ab's Avatar
Interested to see what you have planned for the engine as well...
Instagram
Old 08-23-2016, 09:12 PM   #13
Mzag
Going to keep it all stock for now and see how I like it. Possibly tomei arms turbo or driftmotion rebuilt/upgraded stock turbo, standalone, and injectors at some point but that wouldn't be for a while.
Old 08-23-2016, 09:17 PM   #14
Mzag
vvti 1jz s14 kouki
Starting the piece everything together. Waiting on couplers to finish the intercooler setup, driveshaft, and power steering line which should all be here by Thursday.
First start up and drive should be in a few days!
Old 08-24-2016, 06:36 AM   #15
EnvisionMore
EnvisionMore is an unknown quantity at this point
Nice start! Definitely interested in seeing how your JZ/CD009 setup comes out. Are you going to run the shifter panel / boot still?
EnvisionMore is offline   Reply With Quote
Old 08-24-2016, 10:04 PM   #16
Mzag
Yea, I'm going to cut and re weld a forward facing angle in the shifter so it moves it forward a few more inches. As it sits, I can bolt the center console into place but the shifter is at the back edge of the opening so an inch or two should do the trick
Old 08-24-2016, 10:08 PM   #17
Mzag
The remaining parts needed to fire it up came in today so here is the first startup video.
https://vimeo.com/180130189
Old 08-24-2016, 11:48 PM   #18
rawgarage
Trader Rating: (75)
Damn starts right up
Old 08-25-2016, 03:38 PM   #19
Nissansota240
Nissansota240's Avatar
Nissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really niceNissansota240 is just really nice
Nice work, a lot of similarities to mine, your shifter sit a bit further back though, I was thinking about looking into flipping the L shaped piece for the Gktech shifter and then modifying the brackets to move it forward and up to work with the new location, so that the whole shifter itself sits about perfect to what OEM is
DLG - DIRTYLOVE
Nissansota240 is offline   Reply With Quote
Old 08-25-2016, 04:33 PM   #20
soundboy
soundboy is an unknown quantity at this point
Very good rust repairs, very impressive work
soundboy is offline   Reply With Quote
Old 08-26-2016, 05:56 AM   #21
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
What engine harness did you go with
corkscrew is offline   Reply With Quote
Old 08-26-2016, 07:02 AM   #22
Mzag
Thanks. That's not a bad idea with the shifter, may have to give that a look.
Old 08-26-2016, 07:04 AM   #23
Nissan2nr22
Nissan2nr22's Avatar
Trader Rating: (30)
Nissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura aboutNissan2nr22 has a spectacular aura about
Feedback Score: 30 reviews
So cool I love this.
Nissan2nr22 is offline   Reply With Quote
Old 08-26-2016, 07:05 AM   #24
Mzag
Thanks!
I used the stock harness that came with the motor and just deleted what isn't used and made my own connections to the chassis harness
Old 08-31-2016, 09:02 AM   #25
tjcbar
tjcbar is an unknown quantity at this point
Awesome build, serialnine has a adjustable shifter for the cd009 gearbox that could fit without any cutting, this build is on my bucket list =D
tjcbar is offline   Reply With Quote
Old 08-31-2016, 09:22 AM   #26
Mzag
Thanks! I will have to take a look at that shifter then. Took this to the track Sunday and the gktech shifter was very disappointing, I'll update with pics later
Old 08-31-2016, 07:30 PM   #27
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
nice to see another Mainer in here, not many Schassis up here that arent just ragged out pieces of shit haha. what area of the state are you in??
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 08-31-2016, 07:59 PM   #28
Mzag
That's too true, I really wish there were more around. I live in Gorham, how about you?
Old 08-31-2016, 08:25 PM   #29
Mzag
vvti 1jz s14 kouki
Here's a small update since its been running and driving. I scrambled to get the car done for a drift event last weekend and luckily made it too the second day to give it a little shake down. The motor ran great and is tons of fun with the cd009. Here's a couple pics of how it currently sits.
I did have an issue with the gktech shifter which was pretty disappointing. First off, they did not include any instructions or even pictures of how it was supposed to look fully assembled, not even on their website until a few days ago when I looked. I wasn't too worried about that since it was pretty easy to figure out and it really can only go together one way.
So when I first drove around it felt and shifted great, no complaints and was pretty impressed with the quality and design. But half way through the day and roughly 20 shifts from 1st to 2nd the shifter between the pivot ball and where it connects to the trans bent so bad I could no longer shift into 2nd, 4th, or 6th.
I know for a fact I wasn't shifting hard enough to where this should have bent so bad and after looking at the design I can't seem to understand why they would make that section of the shifter so narrow compared to the rest. I have contacted gktech and they are trying to resolve the issue so I won't give them any negative reviews just yet, especially since this was part of their first batch to be shipped.
Old 08-31-2016, 09:37 PM   #30
1988montecarloss
Trader Rating: (24)
Bangor area here
IG: @Haley72692
