Old 10-27-2016, 02:20 PM   #20401
jared420sx
jared420sx's Avatar
jared420sx is on the path to ruinjared420sx is on the path to ruin
Sup dudes, so upon some investigation the previous owner stripped the balls out of the threads on the 3 holes located on top of my valve cover!!!! Yay! So yea i redrill and tap them but what bolts should i use? Just seeing if anyone here has come upon this before i start trying a bunch of different bolt sizes and shit. Any spoon feeding would be greatly appreciated!!!
jared420sx is offline   Reply With Quote
Old 10-27-2016, 02:30 PM   #20402
sentradude
sentradude is an unknown quantity at this point
Next size up? What tap did you use? Though it would drive me crazy that there are two different size on the VC, wonder if you can use heli-coil..
sentradude is offline   Reply With Quote
Old 10-27-2016, 02:42 PM   #20403
jared420sx
jared420sx's Avatar
The threads on the bolts r fine. I dont know how this happened he might of already used a helicoil though :/
Old 10-27-2016, 02:54 PM   #20404
sentradude
Take that bolt to hardware store and tell them you want either heli-coil or next size up and get the proper tap.
Old 10-27-2016, 09:13 PM   #20405
caspa
caspa's Avatar
caspa is an unknown quantity at this point
I have a MAJOR LEAK coming from just behind my crank pulley, the right side (if you were in your vehicle) of your motor. Any suggestion on what my be causing the leak?
caspa is offline   Reply With Quote
Old 10-27-2016, 10:39 PM   #20406
derass
Either front main seal, oil pump/front cover or oil pan. Clean the area with brake clean and a rag to see where it's coming from.
Old 10-28-2016, 12:30 AM   #20407
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
most likely front main seal or oil pan
Old 10-28-2016, 12:52 AM   #20408
Suicunes
Suicunes is an unknown quantity at this point
What is leaking? Oil or Coolant/Water?
Suicunes is offline   Reply With Quote
Old 10-28-2016, 10:20 PM   #20409
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
Can I get a price check.
these parts are used. Grade A+
NISSAN JDM K's Aero Front - S14 KOUKI
HOOD
FENDERS (PAIR)
FRONT BUMPER
HEADLIGHTS (PAIR)
CORNER LIGHTS (PAIR)
FRONT GRILLE
SIGNAL LIGHTS (PAIR)
RADIATOR SUPPORT
BUMPER FILLER
mau5trap is offline   Reply With Quote
Old 10-29-2016, 10:00 PM   #20410
Arrowking
Arrowking's Avatar
Arrowking is an unknown quantity at this point
Can anyone give me the spline and size of both ends of a S13 steering u-joint? And/or point me to an aftermarket replacement?
Arrowking is offline   Reply With Quote
Old 10-30-2016, 12:54 PM   #20411
konstbug
konstbug is an unknown quantity at this point
Hi everyone, trying to find any info about " * " in the end of TE37, see pic
What does it mean?
"konstbug" & "rare.wheels" at Instagram, Facebook and other sources
konstbug is offline   Reply With Quote
Old 10-30-2016, 01:08 PM   #20412
R3b
R3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond reputeR3b has a reputation beyond repute
Any idea why soon as I manual switch on my fans with a switch my car bogs and dies out? Ground, alt or battery? Happens whenever my fan controller hits its temp.
R3b is offline   Reply With Quote
Old 10-30-2016, 08:45 PM   #20413
Young Sileighty Kev
Trader Rating: (22)
Young Sileighty Kev is an unknown quantity at this point
Feedback Score: 22 reviews
White Smoke is coming from o2 sensor/upper down pipe area. It looks like the smoke comes from the o2. My car idles from 900 to 500 vice versa. And also the exhaust (straight pipe) back fires seems like the car is running rich. Any ideas what cause white smoke to appear?
Oil is good, coolant is good, no overheating
Young Sileighty Kev is offline   Reply With Quote
Old 10-30-2016, 10:36 PM   #20414
caspa
caspa's Avatar
What would cause the oil pump/cover to leak, bad sealant?
The oil leak goes all the way to the bottom of my tranny.
I'm leaning towards the the main seal. The oil leak goes all the way to the bottom of my tranny.
Oil
Old 10-30-2016, 10:43 PM   #20415
lunchmeat
lunchmeat's Avatar
lunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond reputelunchmeat has a reputation beyond repute
If it's going that far back, that sounds like oil pan.
lunchmeat is offline   Reply With Quote
Old 10-30-2016, 11:03 PM   #20416
caspa
caspa's Avatar
The area around the main seal on the timing cover has oil build up, and as well as the side of the engine. Also, the right side of the car like the tension rod, tierod, and etc is covered in a layer of oil sludge. I'll thoroughly clean the area and try to source the oil leak. I'm hoping it's the main seal or oil pan.
Old 10-30-2016, 11:09 PM   #20417
lunchmeat
lunchmeat's Avatar
Had to do that years ago when the front main let go. Flung oil all over the place.
Old 11-01-2016, 02:08 PM   #20418
jared420sx
jared420sx's Avatar
Any suggestions for tires? I have 16/18k spring rates and dont like smoke. I need suggestions for front and rear dont mind running two different treads thanks guys.
Old 11-02-2016, 04:30 AM   #20419
I'm Redline
I'm Redline's Avatar
I'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to allI'm Redline is a name known to all
If you can run 17x9+15 wheels, get rid of the inner fender plastic, and run 235-40-17 all around, you will have more than enough grip. I would also suggest single brand, same tread because it works better. For winter, 100 pounds of sand in the back, and regrooved SnowTrakkers work great on black eyes with a similar offset.
You could go 245 in back, but there is something really nice about being able to rotate tires for even wear because saving tire money for car parts is way better
1996 Zenki 'Baraketsu Tenshi', Burst Angel
My work in progress...
I'm Redline is offline   Reply With Quote
Old 11-02-2016, 12:31 PM   #20420
91stockcoupe
91stockcoupe is an unknown quantity at this point
Would anyone know what would cause lots of play on the drivers side rear wheel when it's jacked up? It's an s13, suspension is all stock, also has a lot of wheel hop whenever I hit a bump and I'm giving it gas. I already replaced the wheel bearing but it still has the same exact play.
91stockcoupe is offline   Reply With Quote
Old 11-02-2016, 12:38 PM   #20421
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
Originally Posted by 91stockcoupe View Post
It's an s13, suspension is all stock...
you just answered your own question.
Old 11-02-2016, 01:00 PM   #20422
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
I want to refinish my dull OEM Silvia plastic grille. What's the best way to do it?
Old 11-02-2016, 01:02 PM   #20423
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
buffing compound (REALLY fine, like 1000 grit) and a soft cloth
Old 11-02-2016, 01:03 PM   #20424
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
I have 17x9 rims with 245/40 tires and I don't rub.
Keep in mind that I have coilovers and the stock plastic inner fenders. So you could try that tire size along with Redline's suggestions for a little more grip.
SoundEfx is offline   Reply With Quote
Old 11-02-2016, 01:44 PM   #20425
jared420sx
jared420sx's Avatar
Wet sand and wax
Old 11-02-2016, 02:11 PM   #20426
mau5trap
mau5trap's Avatar
1995 Ka24de manual transmission with 78k.
Old 11-02-2016, 02:17 PM   #20427
jared420sx
jared420sx's Avatar
Buck 25 and a 36 rack of pbr
Old 11-02-2016, 02:19 PM   #20428
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
Wet sand and wax
do NOT sand clear plastics!!! would you sand scratches out of a CD or a headlight? NOPE! the only time plastics should be sanded AT ALL is if you plan on painting over them!
as i said before, extremely fine buffing compound and a soft cloth! circular motions, takes about 2-3 minutes if you put effort into it.
you can pick up a headlight fog repair kit and use the buffing compound they give you in the kit (its the white liquid crap, same thing thats distributed in CD repair kits).
Old 11-03-2016, 01:04 AM   #20429
osk94
osk94's Avatar
osk94 is an unknown quantity at this point
S14 Kouki Wing Trunk
I recently installed a Silvia Ks wing or Kouki wing whatever you wanna call it on my trunk. Originally it was a wingless trunk, now the problem I have is that my trunk wont open now cause of the weight of the wing unless I have a second person lifting it as soon as I pull on the release latch from the side of the seat. Anybody know how to calibrate the release force of the trunk or have any suggestions on how to handle this? I searched on here but everyone has issues related to the cable that releases the trunk. My trunk opens fine but it now requires two people to open it. Thanks
osk94 is offline   Reply With Quote
Old 11-03-2016, 01:13 AM   #20430
osk94
osk94's Avatar
Gotta keep in mind that your fan assembly is spreading that oil all over the place as well. Best bet for you to locate that leak is clean any areas with oil and begin to trace the leak.
