02-12-2017, 06:23 PM | #1 |
1998 RB25DET Kouki S14
Wanting a Skyline but dont wanna deal with RHD or Skyline problems of finding parts? then this car is perfect for you.
I never thought this day would come but I need to say good bye. I have limited car space and too many projects as well as needing to get a more family friendly car for the long road trips and being able to pull over to an Autozone to get parts in need. Those of you that frequent the Build thread area probably know the car. For those that dont here is the build thread to see all the work thats been put in to it. http://zilvia.net/f/showthread.php?t=332057 Wanting to get $10,000 but price is negotiable When I recieved the engine I tore it apart, inspected it and replaced all the gaskets. Car has been rock solid for me for the 8 years ive built and owned it. Only issues Ive had was the Alt dying and the stater takes a few clicks to start but will replace it before selling. I have driven this car on multiple 7hr road trips and drove it up here from Al with Zero Issues. Mobile 1 10w30 always used with K&N oil filters. Body has a few dents and dings, FL fender has a dent, FR fender clear coat is gone, Hood clear coat has spots from bug guts that ate it away lol No A/C I have custom lines for the R33 comp in the S14 system but the current comp is bad, I have a used one I pulled from a vist to Japan, just need to locate it due to the move. Heat works great though Will come with the wheels now! (They are too small for the G35 lol) Engine Mods Series 1 RB25 with Stock Turbo R33 RB25 Transmission R33 engine crossmber SYKO Engine/Trans Mount Kit with Turbo Elbow Driveshaft Shop Aluminum Driveshaft ISR Short shifter Greddy Style Port Matched Intake manifold Greddy Timing belt New OEM Timing belt pullies N1 Water Pump N1 thermostat Silicone Upper and lower Rad hoses Brand new oil pan New Nissan Oil pump OEM Headgasket ARP head studs Mckinney Intercooler Piping Circuit Sport baided oil and cooalnt Turbo lines ISR FMIC Fuel injectors cleaned and flow tested by Injector Rehab Wiring harness inspected by Wiring Specialties Fidanza Flywheel Exedy Stage 1 clutch Alternator rebuilt 4 months ago ISR turbo back straight pipe blast pipe exhaust Koyo Aluminum Radiator Nismo Rad Cap FAL Pusher Fans DIF PWM Fan controller Koyo power steering cooler Walbro 255 Fuel pump Apexi intake filter Tomei FPR Body/Interior J-Spec Silvia Front Bumper with Winkers RARE Discontinued Greddy Gracer lip spoiler Rear Silvia Kouki Wing Defi Advanced Boost and Coolant Temp Gauges Navan Shift knob Custom PnP cluster harness to be able to swap between a R33 cluster and the S14 cluster 7K HID's Ruff Racing 18x9.5 +20 all around with 215/40 Federal 595 tires all around Suspension/handling Rear inner axle joints rebuilt 4 months ago Energy Suspension Rack bushings Tein Inner tie rods with 5mm spacers and MOOG Outter Joints Z32 Front and rear brakes with Z32 ebrake Agency Power steel braided lines ISR Tension, Camber, Tow, Traction arms Stance GR+ Coilovers Clutch pedal assembly reinforced New Front wheel bearings 5 years ago (4 years of storage time) Probably a few other things im forgetting at the moment though. Engine bay shot, I have the factory coil pack cover for to clean it up more if you wanna cook the coil packs hahha Timing belt inspection
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 02-26-2017 at 08:07 AM.. |
02-15-2017, 12:40 PM | #3 | |
Future Moderator
Wow.
I have followed your build thread from the start. If there was ever a car I would buy from a Zilvian it would be yours. This car has been meticulously built and taken care of. Whoever buys this car rest easy its done right.
02-19-2017, 09:46 PM | #4 | |
haha thanks bro, I wish you could get it.
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
02-20-2017, 12:52 AM | #5 |
+1 I learned A LOT from this build thread
02-25-2017, 10:49 PM | #6 |
Guess I'll post up the things that might need addressing since this is a 19 year old car and not perfect.
I Pride myself in being upfront with anything I sell, I do not hide or wait til something to pop up after I sold something to say "oh yeah that happens sometimes". I do not like drama Interior door cards are about what you'd expect for a 19 year old car, has some small tears and fabric needs to be reglude in the Driver and passenger side. driver side electronic door lock actuator needs to be replaced, itll jam if you use the electronic lock. I unpluged the DS and havent had any issues with using it manually. Electronic lock button still works to lock/unlock Passesnger side. Body is in pretty good shape, has some dings, worst spot in right in front of the right rear wheel from the PO, not sure what he hit. not really noticeable or some side skirts would cover it up. Suspension Front coils top hat bushings are wore out had some Energy suspension bushings I had lying around and modded those to work temporarily front windshield is cracked along the bottom, Id be willing to knock off $300 for the replacement of that depending on how much the car is sold for. No major rust. Its lived in the south pretty much all its life. If there is any it would just be surface rust that could be removed with a wire brush. There's no rust bubbles or flaking. When I brought it up here I rubberized undercoated the rear fender wells, frame rails, pinch welds and crevices from the firewall back. it snowed for 3 days up here when I got here and had to drive it to work but when I drove it home I washed the undercarriage everyday til the snow was gone. Engine- as side from the starter needing to be replaced and alt dying (had it rebuilt) I havent really had any issues with it. still has the old A/C comp. I pulled another one in Japan from a sealed system R33. I have it some where.... I think its in my long term storage parts that should be delivered soon. I hope. Would just need the condenser installed and system flushed with a new filter drier. Engine will burn a little bit of oil only during engine braking, any other time it will not. I believe it has something to do with the PCV or VC baffle system, I fished a snake camera in the intake to look at the valves and they didn't look like the typical leaky valve stem seal. I'll post pics tomorrow when I get on my PC.
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 02-26-2017 at 08:01 AM.. |
03-15-2017, 05:54 PM | #9 |
Thanks guys!
Went ahead and did a plug change on it today as well as a compression test for shits and giggles. With pretty good result all cylinders were about 148-149psi normally pretty rare to have all cylinders so close together. Normally the last 2 cylinders are lower than the others
03-15-2017, 08:53 PM | #11 |
Overtime and with OEM Coil Packs it is. Very common the coils will eventually crack and leak spark or just get weak.
Here are the OEM ones pulled from this RB. Old ones on the bottoms, Newer ones on top. These old ones leaked spark.
03-18-2017, 11:32 PM | #13 |
Domo Kind Sir I am Located In Goldsboro North Carolina
03-21-2017, 11:58 AM | #16 | |
Future Moderator
Random true story. I bought my kouki from Goldsboro.
03-22-2017, 04:39 PM | #17 | |
No worries man Damn that crazy, must have been the only one then cuz I've yet to see another around here
03-22-2017, 08:42 PM | #18 |
i just got done going through your build thread. great job btw! now im curious, did you remove the upgraded turbo and coated manifold? and is it tuned on anything at all? glws this is a great example of what an rb25 swap should be!
Instagram : duc_dang |
03-23-2017, 07:38 AM | #19 | |
I did remove the turbo due to the stock ECU pulling timing and dumping fuel when it was set on the lowest setting. Manifold is still the same just the paint has chipped off from sitting for 4 years lol It is not tuned, still running stock ECU, turbo, injectors, MAFS pretty much a clean slate for a new owner.
03-25-2017, 06:04 PM | #22 |
Thanks guys,
Still doing things to it to make it better and clean it up. Did the long over due Battery relocation on it.
04-03-2017, 12:08 PM | #23 |
Well guys I hate to say but the car is now sold and with the new owners now.
Didn't expect they were gonna really gonna buy it, figured they would take a look, kick the tires, and lowball the shit outta me. But they came with a trailer with determination of taking it home, and they did. Really sad but no real regrets thus far. The brick of cash they paid with is helping me cope, lol ;o; Seems like it'll be in good hands though.they said they were gonna paint it white and take it to car shows so good to know I won't see it in a ditch and parted out in the next few weeks.
