#871 |
It's really not so bad unless you're running super heavy wheels or have bad offset (which might make you rub all over the place). I've done 18*10J front (in positive to negative offsets, Minerva, GT-P, and 17" VF-1R) with a dying PS pump with absolutely no problems on 225/40/18 and 225/45/17.
215/40/18 would probably feel better, but not by much. Swapping from heavy-ass 3 piece wheels to single piece forged (i.e. LM-GT4 in 9.5j for example) feels like night and day, though. Edit: to be fair I've never done a track day with 10" fronts, but I imagine it must be harder to maneuver... |
#872 |
![]() Join Date: Feb 2013
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Any one kno if Weds Cerberus II lips and weds lxz lips are the same? They look really close but some look sight off. Just what to be 100% cuz to me it looks like it won't work. Thanks for any input.
#875 |
odd question for those with blitz 03s? Was it difficult to reseat the faces into the lip/barrel. Mine are stock welded barrels and I want to refinish the faces. Do i need to hammer them in to get this to sit flush with the barrell/inner lip?
#876 | |
![]() Join Date: May 2012
To avoid messing up a refinished surface, just get the face close enough for the nuts to thread on the bolts and tighten. That will pull them all the way through if they don't sit flat immediately. If you really don't what to hammer at all and the Blitz hardware is too short, you can grab some longer hardware from Lowes or whatever. Then tighten those and replace them with the Blitz stuff when the face is flush.
Follow me on Instagram or don't @cason880 |
#877 |
How I do it, have all bolts in and started. Faces level/best as possible and star pattern, I do 3 step your spec tq for bolt size. Painters tape is your friend
#878 |
Anyone have any tips on removing the old silicone quickly from the barrel when rebuilding vs-xx wheels? Thanks in advance!
Website Hosting by GlobalHost.com |
#879 |
I always just use a knife to get the big chunks and a piece of softer steel wool to get the last bit. Removing the old silicone is probably the most labor intensive part when rebuilding any wheels.
#880 |
use a straight razor blade and bend it around the rim parts. after that you can stand the razor blade straight and scrape with it left to right. worse comes to worse wire wheel.
#881 | ||
is there a wheel attachment that I can use that will be faster?
#882 |
You could use an eraser wheel. Its basically a gum wheel that I've used in the past for removing decals/vinyls. I haven't tried it with the wheel silicone but I'd imagine it would work fairly well.
#883 | |
everyone has been mentioning this: ![]() but it seems kinda of harsh?
#884 |
![]() Join Date: Feb 2014
So I am looking to have my 18in LMGT2's resized, but since they are not a common wheel none of the major lip makers can easily make me lips/barrels. Who do you guys use when you need oddball custom stuff?
![]() Also, I have been playing around with how I am going to strip my faces. Tried some paint stripper on a set of WORK CR KAI's I have and it seemed to work okay, but left some nasty residue. Is there something else I can do to make the paint stripper more effective? Should I just have the wheels media blasted and save the headache? ![]()
#885 | |
![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Video I found for ya for example... https://www.youtube.com/watch?v=KKthFTq2XSk I buy boxes of the aerosol cans. If using the jugs you need to place the object into a sealed container of sorts to allow it all to fume up & eat away @ the paint. Wear a face mask, pants & long sleeves. The shit burns like you wouldn't believe. Edit... Depending upon how thick the coating is... You will have to eat it away layer by layer etc... Wire Wheel, or Wire Brush & Razor blades work the best. You can use the blade in a holder etc... for the inside barrel & all the flat/straight edges on the spokes. Wire Brush for inbetween the spokes & lug holes etc.
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 | |
#886 | |
I was also wondering if I was going to have to work the finish off with some kind of abrasive, I'll probably grab my 3M roloc wheels and see how they take off the crap still stuck on the wheels.
#887 | |
I've never used the 3M stuff but I will go out on a limb & say it doesn't work simply due to this comment "No harmful fumes-low odor". In my experience, odor & fumes is what you want or its crap. IE, wicked fumes = its actually eating the coating.
#888 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 7 reviews
3M may not have discontinued it voluntarily, per se. I wouldn't be surprised if all the EPA regulations over that last couple decades have castrated that product market.
#889 |
Anyone know where I can get the rubber grommets for the 90degree valve stems ?
#890 | |
Found the grommets. Last think I had a question on was the tq specs for vsxx face bolts. I've been reading 19 but also up to 29 ft /lbs ?
#891 | |
![]() Join Date: Aug 2016
(^ that's what she said) |
#892 | |
Ayo that's crazy @originaldonjosh |
#895 |
I recently acquired some Stich Evolution's and was thinking about getting some new lips for them. There a standard 40 hole affair so not to hard to pick up but i was wondering has anyone else made these wheels wider ? are they welded meaning i have to machine them apart or are they simply silicone joined.
#896 |
I'm not shore if they are welded or not I have a set of stitch mesh and they were not welded. If they do happen to be welded I'll u need is a cut off wheel and a grinder if u have access to a tire Machine it makes it easyer but it's not needed I've done it with out. Just take your time and cut more onto the old lip side once cut off clean up the barral with a flap disk.
#898 |
![]() Join Date: Feb 2007
Are equips with lips like this any different or is it just a different style lip? Still a normal face right?
![]() ![]() Friends help you move. Real friends help you move bodies. |
