#961 |
![]() Join Date: Apr 2013
At what power level would you guys recommend upgrading to supertech oversized +1 in +2 exh valves on a p12 head? I just sent my p12 head to maxworx to get their stage 0 head work done and was thinking if i should slap on oversized valves. Im aiming for around 500-600hp at around 25-30psi of boost. Head is going to have supertech 93lb dual valve springs amd tomei cam gears, thats pretty much it as far as the head goes.
#963 |
What's choking you up top? Intake manifold? you seem to peak at 7200ish rpm or is the cam timing you are running?
**Fark I need glasses lol it's the turbo maxing out.
95 240sx RB20 415whp 91 Nx2000 VVL yo Last edited by Yellow4g63; 08-22-2018 at 11:26 PM.. Reason: i'm blind |
#964 | |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
IG/TikTok-ThatS14_Z06guy |
#965 | |
Spend your money on valve seat/valve work. THAT is where the gains are. The VE head could benefit from opening up the exhaust ports, but unequivocally, where the air actually enters and leaves the engine is where the magic lies. |
#967 | |
![]() Join Date: Nov 2005
#969 |
hello after a few people on Instagram told me to post here im @jp_s14 on Instagram I run a S14/P11 ve+t making 532whp at 29psi on 93 octane 9100rpm redline, it is my drift/weekend streetcar with 8200 miles so far, fully built engine 87mm bore on stock sleeves, using an old gt3076r T3, sr16 non n1 cams, id1000cc, aem v2, custom intake manfold using stock runners, modified doc race exhaust manifold, fully built valve train shimless oversize valveswith ported exhaust, and bottom end.. using stock s13 trans Lol, I build engines for a living so if anyone needs a bulletproof vet setup let me know. I am from CT. before anyone says its "dynojet numbers" this dynojet has been calibrated within less of 6hp of what your "mustang" dynos read. ive been on and off both too many times
#971 |
#973 |
I ran into valve float issues with the supertech springs and bent all my exhaust valves so I went with a better spring setup, but the shimless setup was the best thing I could have done to stop spitting shims.
#975 | |
![]() Join Date: Oct 2007
I never saw an plate for the style of coils you plan on running ! Custom it is or maybe look into an other coil set-up
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#976 | |
Maybe the problem is when the lobs are switching over
#977 |
The problem is simply drifting. The shock on the valve train by banging off the limiter @ 9000+ RPM (JP revs it out to that range) is utterly tremendous! No ammount of shim working would ever really fix that unless one wants to spend cubic amount of $$ to keep shims in place and bang off limiters @ 9000+ RPM
#978 |
![]() Join Date: Mar 2005
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
My question for those who have gone shimless is how long until you have to tear down the head to replace valves because the lash went out of spec? Do VVL heads have a worse likelihood of spitting shims than a solid lifter DET head? I never once spit a shim in the 13 years I've had my DET head (spun up to 9k with solid lifters, but mostly between 8-8.5k), but I'm in the process of switching over to a P11 head now.
96 S14: Grip Track Car 90 R32: Bucket List Car 92 S13: Just for Fun Car Instagram: @SS.Maxey |
#979 |
![]() Join Date: May 2006
Correct me if I'm wrong. The P12 Head uses the same Valve Springs as the H22 head?
#981 |
You're saying its the same part number for p12 as well.
#982 |
#983 |
gotcha Chris
#984 |
for you guys who are pushing 700hp range. are you guys using -8 AN or -10 AN fuel lines.
#985 |
-8AN fuel lines should suffice but folks just step up to -10AN for peace of mind.
Anyone here running Taarks Hall sensor and ECU Master ECU?? Or any other ecu with the taarks hall sensor?? Looking to pick someone's brain on setup. |
#986 |
Trader Rating: (26)
So turns out my P12 head is missing two shims. And I cant get new ones for another 6-8 weeks.
Whats this I hear we can run shimless heads? How can I do that because I really doint want to wait 6-8 more weeks. I already waited 8 weeks for custom CP pistons. Im done waiting lol
#987 | |
![]() Join Date: Apr 2012
Trader Rating: (63)
![]() Feedback Score: 63 reviews
Mazworx shimless valves 600$ plus a new valve job |
#988 | |
#989 | |
#990 | |
I have several different sizes here. If you need a few let me know. I'll send them to you |
