#1021 |
![]() Join Date: Feb 2016
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Last I saw it was 15k. I already have every part I need, just want someone who knows what they’re doing to assemble it and do the minor necessary machine work |
#1024 |
![]() Join Date: May 2006
Who's selling, I want to see the motor?
#1026 |
noob question, sorry in advance for my ignorance.
My current setup (parts in hand, not engine setup) incorporates a ross tuffbond race series balancer (no integrated crank trigger teeth) and the taarks hall effect cam sensor kit. I was under the impression that running a hall effect kit was simply a way to get a cleaner signal to the ecu rather than running the nissan cas. From what Im researching now am I correct in saying you have to run both a hall effect cam sensor as well as a crank trigger setup in order to utilize an aftermarket standalone ecu? Ill most likely either use an aem infinity or haltech elite. If the answer is yes, and I need to incorporate a crank trigger into my build what options do I have? It looks like ross doesnt sell a separate crank trigger wheel for the race series balancers (must be ordered with the option of integrated crank trigger wheel). I cant run the mazworx or the taarks kits as both are made for the ATI balancer. Open to suggestions on what to do, as well as short explanations as to what crank/cam trigger setups actually are since I cant find a straight answer anywhere in terms of our application and I feel like an idiot, lol |
#1027 |
No. The taarks hall wheel acts as both a sync (180) and a home (1 degree) signal to determine where in the cycle the engine is currently.
That's exactly the way Nissan has it currently as the CAS does the same exact thing |
#1029 |
Hey everyone!
Newbie here, been lurking for a while & took the leap into Zilviadom last night. I have a ton of work ahead of me, so will be adding my two cents & picking some brains along my journey. Lots of very experienced & knowledgeable members here & the older I get, the less I wanna reinvent the wheel. Some background; Been a Datsun/Nissan nut all my life, some were NA L series, some nitrous L series & the past 10 years or so, FJ’s & SR’s have been my choice. I’m building a 510 now & going back to my L series roots on this one but later in the year I’ll be putting a 500-600hp VET into a 710 chassis. The SR’s thus far haven’t been anything extreme, the most putting down 314 kw atw at 22 psi, remember these were all in old school Datsun platforms, 300kw is plenty. So the VET build coming up will serpass all before & at 46years old with kids nearing college etc. I really can’t afford to bump my head & I’ll be leaning on all to head in the right direction. Thanks in advance & thanks for this awesome forum. |
#1032 | |
#1034 |
Wanted to ask a quick question from those of you who've had some higher hp sr's built. Is it more worthwhile to upgrade main caps or the girdle? I know the stock main caps have some issues with 'walk' around the 550-600hp mark and up. Will mazworx billet main caps solve this or is a JHH billet girdle paired with stock caps more than enough? I dont really want to do both as I dont see it as completely necessary for my build, but if either is cost effective insurance for track use Im willing to go with either.
#1035 |
I was wondering about that. I wasn't going to upgrade the main caps till I heard they have a cracking problem over 600hp.
#1036 |
Same here ha ha haven’t been able to find solid info on this other than on parts sites but then you don’t know if they’re just trying to sell their parts [emoji23]🤣 I’m looking to be around the 6-650 range on mine so would be good to get some proper info on what’s actually necessity
Sent from my iPad using Tapatalk |
#1037 |
![]() Join Date: Oct 2007
Garage motive / jet200 s14 , andrew did talk about it ... main with the bolt hole in the middle and the weakess ... after that you have gtir main (they dont have a hole in them) 600/650 whp mark and after it would be billlet main + and 1/2 studs
I just dont know if gtir and a billet girddle like jhh or plazmaman would do the trick
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#1038 |
I have mazworx billet main caps with 1/2 head studs and main studs that i think about selling !
#1040 | ||
How much play does the damage allow? I would say if the cams drive forces are on the undamaged side, youd be fine. The cam should never rotate backwards. See picture below for explanation.
#1042 |
Have you found a car to put this setup in yet? Last we talked you didn’t even have a chassis.
#1043 |
In case anyone's interested, here's an EFR 7163 .80 on my VE'd SR.
89mm x 91mm. Compression is around 10:1. P12 head which has oversized in/ex valves installed, no other headwork/porting/whatever done. P12 cams. This was on ordinary pump fuel (93 in your AON rating). 1.8bar of boost tapering to 1.6bar (26 to 23psi). 567 PS is 417 kw. Max dyno reading was 582 PS / 700 nm (515 lb ft) at 2 bar, but we decided for a bit of safety in the end as the car will see full throttle quite often and has to work in all kinds of situations (like 4th gear full throttle drifting on a slow track at 110 F). Quite happy with the result. 500 nm (~370 lb ft) for nearly 4k of revband was the target. We about got there. With E85 this should be even wider... Response on the dyno was mind blowing. Haven't driven it on the road yet. Freakin curious on how it will drive. ![]() |
#1044 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
Going mechanical pump on my P12 build. I haven’t really seen anyone else go mechanical.
Anyone else do this? ![]()
IG/TikTok-ThatS14_Z06guy |
#1045 |
Interesting is the boost falling in the higher RPM's? the power is falling slowly to 7500 or did you adjust the cam gears to get it that way?
#1046 | |
Are you mounting that where the flan clutch should go?
#1047 |
Trader Rating: (26)
From the looks of the kit, it’s going to mount where the water pump would be, and driven off of the crank. I’m going electric water pump and e fans anyways.
#1048 | |
- "60lb" turbo on 93 Octane, so no surprise to see it falling off up top - P12 cams may be holding him back up top. - Boost taper up top Otherwise, this is a very wicked dyno! Love everything about it ![]() |
#1049 |
Holy hell, thanks for posting your dyno. My setup incorporates a single scroll EFR 7163 .85 indycar turbo, and I was afraid I wouldn't be able to push 550 wheel out of it. This gives me a lot more confidence that it's the right turbo for my goals, especially since ill be on e85. Hopefully I dont suffer too much more with spool compared to your twin scroll/smaller a/r setup.
