Old 12-02-2019, 06:06 PM   #1
K_never_broke_again
K_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura about
sr20det injector decapping, good idea or not?
So the other day, in my search to find the cheapest possible way to make 350hp, I came across this interesting ghetto injector mod(decapping). For anyone who doesn't know what it is, you basically grind off the pintle cap of the injector to increase the flow of the injector. From what i've read, it can nearly double your flow rate, but at the expense of consistency across injectors and the effectiveness of fuel atomization. I noticed it's mostly truck people who do this, but I figure if it works for them theres a chance it'll work for me. Does anyone have any experience doing this? Or any insight on how risky it would be?
K_never_broke_again is offline   Reply With Quote
Old 12-02-2019, 06:15 PM   #2
Turbosauce74
Turbosauce74 is an unknown quantity at this point
Man I'll sell you injectors used for cheap so you don't have to mess something up more serious. Injectors aren't even expensive.
Sent from my SM-G965W using Tapatalk
Turbosauce74 is offline   Reply With Quote
Old 12-02-2019, 06:24 PM   #3
S14rebuild
Theres no reason for this...injectors are cheap enough...do it right or ull end up with a blown motor and alot less $$
Old 12-03-2019, 07:50 AM   #4
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
No.... just no.
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 12-03-2019, 02:11 PM   #5
jedi03
I am seeing this a lot with modders...witch hunter actually debunked a lot of myths behind this, it does leave risk of damaging injector but yes you can increase flow on certain types of injectors...it does change the spray pattern as well as the variance between injectors so balancing them could be tricky too...
Old 12-03-2019, 05:49 PM   #6
S14rebuild
So.....dont fuking do it.
Just cause it "works" doesnt mean its right and/or proper.
To.OP....
If u take pride in ur car/build buy proper injectors
But by all means do as u want, its ur car n ur $
Old 12-03-2019, 09:16 PM   #7
K_never_broke_again
The variance between injectors and the fact that I wouldn't know what the fuel output is without getting them tested is the main thing that I worry about. When I get it tuned what am I supposed to say... "yeah man its got decapped stock injectors, not really sure what cc but people say its about double, give or take 5% on each one." I find it hard to believe any tuner would take that risk lol.
When I get the funds for the upgrade in a few months, and if I go the safc tuning route, ill probably end up trying it. I guess theres a chance I could destroy my engine, but hey, someone has to be the first to try it, right? Gotta risk it for the biscuit.
Old 12-03-2019, 09:58 PM   #8
ultimateirving
ultimateirving's Avatar
Terrible idea. Even eBay injectors would be less risky. And forget about the safc. Get a tune to match your injectors with either a rom tune or standalone(given the nature of the post I doubt you’d shell out the cash). You will also likely want a z32 maf to accommodate the extra power.
Z32 with lq4 swap
Old 12-04-2019, 08:37 AM   #9
TheRealSy90
TheRealSy90's Avatar
Originally Posted by K_never_broke_again View Post
safc
Don't, just don't.
Such a good signature.
Old 12-04-2019, 11:38 AM   #10
Kingtal0n
Kingtal0n's Avatar
350hp on a safc and de-capped injectors?
Hell why not, should last at least 5 minutes
Look on the bright side, you saved like $500 but then the new engine costs 3k so hmmm not really a good deal
Old 12-04-2019, 12:36 PM   #11
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
That's exactly 4 mins and 50 secs longer than his last engine...….
RalliartRsX is offline   Reply With Quote
Old 12-04-2019, 12:43 PM   #12
240msh
240msh's Avatar
240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known
you can literally get Subaru 550s for like $100 lol
@Michayyl
240msh is offline   Reply With Quote
Old 12-04-2019, 01:17 PM   #13
jedi03
my tuner didn't care what physical status my injectors were, just brand/flow and what other power mods were on it as well as my car being mechanically sound...Very few injectors can be modified to increase the flow and still work correctly. Usually the spray patterns will be poor and their flow rates will be very mismatched after modification.
The only injectors we currently modify are the pink or blue top-feed Denso's and the yellow side-feeds that are used in the late model Subaru. These will typically flow within a few percent of one another after modification. We perform this operation using a lathe or mill to prevent injector damage. See our Subaru Mods page page for pricing.
https://witchhunter.com/injectorfaq1.php#do
so do it if you want, but getting a properly sized set of injectors would be best practice
Old 12-04-2019, 05:40 PM   #14
RalliartRsX
Trader Rating: (32)
Or just buy some topfeeds and be done. Sidefeed injectors are literally a 30-40 year old design lol
Old 12-04-2019, 06:07 PM   #15
S14rebuild
This is a thread i expected to see from 10 yrs ago......
Come on all the technology out there, newer injector styles, fair prices and many options for tuning
Safc=fail
Decapped=fail
Old 12-05-2019, 06:56 AM   #16
collegekid
collegekid's Avatar
collegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to allcollegekid is a name known to all
OP
Screw these guys and what they tell you. This is America. It's YOUR car.
Also, I'm interested in your car with the blown engine after you're done with it. I'll come down and pick it up and make you a fair cash offer. Keep in touch friend, let me know how it works out.
collegekid is online now   Reply With Quote
Old 12-05-2019, 08:14 AM   #17
jedi03
lol I additionally have a set of sti 550s...im sure there have been some revisions along the way!
Old 12-07-2019, 12:52 PM   #18
kyral
kyral's Avatar
kyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nicekyral is just really nice
When you make more power you have less room for error and inconsistency and want more precise control over everything running the engine, (which is why SAFC are bad for making big power) so its counter productive to do this. youre trying to make more power with less precision.
does it do what you think it does? yes
Is it a good idea? no
The Game
you lose haha
kyral is offline   Reply With Quote
Old 12-23-2019, 01:43 AM   #19
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough1988montecarloss is a jewel in the rough
Feedback Score: 24 reviews
this x2
gonna cost $80 to have the decaps flow tested so youre at least not pulling a guess out of your ass as to what they flow and theyre still not gonna be anywhere near close to each other
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
240sx, engine, injector, sr20det
