Old 01-17-2020, 09:03 AM   #811
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Originally Posted by Sr20-Vert View Post
I have mazworx kit also I feel like my clutch fork doesnt go all the way it barely moves car drives fine under full load it’s a little rough I use exedy twin disk is there a Solution to this it’s driving me crazy trans is brand new from Nissan and shifts like crap
you need to measure how much the clutch slave rod extends when you push down the clutch pedal. if its not extending fully (air in the system or clutch pedal not adjusted properly) then the clutch will not be disengaging properly
also, what pivot ball do you have? there are at least 2 different lengths.
Old 01-17-2020, 10:13 AM   #812
Sr20-Vert
Sr20-Vert's Avatar
Sr20-Vert is a well-known jackass
I have the nismo pivot ball where should my clutch engage at i have it set to middle of pedal
Sr20-Vert is offline   Reply With Quote
Old 01-19-2020, 05:06 PM   #813
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
Anyone using the A340 collins kit for JZ/CD009? Im seriously thinking of finally pulling the trigger on this
BiG MiKE86 is offline   Reply With Quote
Old 01-25-2020, 03:06 PM   #814
Shift n Drift
Shift n Drift has a little shameless behavior in the past
Big Mike, My homie is using it, message me and ill give you his info.
Shift n Drift is offline   Reply With Quote
Old 01-26-2020, 09:26 PM   #815
Sr20-Vert
Sr20-Vert's Avatar
I changed the clutch master bleed it but third feels a little funny only if I am spinning into third gear shifting at 8000 rpm which is every time I hit gas in second no stopping that But I am gonna try oem shifter the clutch fork was moving proper when I checked also regular driving in perfect I think it’s just the mazworx shifter idk I would love to figure this out
Old 01-27-2020, 08:43 AM   #816
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
Has anyone used poly trans mount with mazworx Kit I got the nismo mount and it moves all over the place
Careful on the mount selection, the cheaper ones wont fit in the cross member. I just bought a Drift Freaq trans mount, dimensionally the same as OEM. Will have to let you know how she pans out
Jorgs_7 is offline   Reply With Quote
Old 01-27-2020, 08:55 AM   #817
BiG MiKE86
BiG MiKE86's Avatar
https://autosportsengineering.com/pr...apter-package/
Anyone try this autosportsengineering kit? saw a vid of a 300z 2jz on youtube and the kit looks super nice and the price is right
Old 01-27-2020, 09:22 AM   #818
D.Bo
D.Bo's Avatar
D.Bo is an unknown quantity at this point
I had issues using the Gktech solid mount and Gktech crossmember. i had to cut down the solid mount so that it looked similiar to an oem mount for it to mount up right on the cross member.
Ordered a new megan racing mount just havent had a chance to install it.
D.Bo is offline   Reply With Quote
Old 02-01-2020, 01:00 PM   #819
BiG MiKE86
BiG MiKE86's Avatar
After doing a shit ton of research and watching countless videos on youtube I finally bit the bullet and ordered the SerialNine bellhousing and shifter for the JZ-CD009 swap. Got a brand new CD00A on the way as well. Ill keep you guys posted on this swap.
BTW I've seen some horror stories with these other adapter kits such as exploding flywheels so be careful out there guys!
Old 02-03-2020, 05:55 PM   #820
BiG MiKE86
BiG MiKE86's Avatar
The quality on this shifter is on point!
Sent from my iPhone using Tapatalk Pro
Old 02-07-2020, 08:06 AM   #821
BiG MiKE86
BiG MiKE86's Avatar
Can anyone recommend a good trans mount/bracket? The serialnine kit doesn't come with one so I have to get that separate. Thanks
Old 02-07-2020, 08:54 AM   #822
battery1882
battery1882's Avatar
battery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enoughbattery1882 will become famous soon enough
I used it and it's a good kit. only problem I had was pilot bushing wasn't the right size.
http://www.youtube.com/watch?v=FB8BTi3El9Q&t
instagram : battery1882
www.sterculture.com
battery1882 is offline   Reply With Quote
Old 02-07-2020, 08:59 AM   #823
BiG MiKE86
BiG MiKE86's Avatar
Ended up going with a full serialnine setup and competition clutch after watching a ton of videos and reviews on some of these other kits.
Old 02-11-2020, 05:15 PM   #824
BiG MiKE86
BiG MiKE86's Avatar
Anyone know the thread pitch and bolt length for the 2 bolts that hold the trans mount in place? Thanks
Old 02-12-2020, 06:07 AM   #825
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
So for folks with shifters which utilize the nylon shifter cup; has anyone experienced issues with the shifter popping out of the cup after a 1-2 or 2-3 or any shift?? It has happened several times now, and I am hoping it's not a design issue (I am on a Hook shifter) and it's just a worn out shifter cup.
Old 02-18-2020, 01:14 PM   #826
RalliartRsX
Trader Rating: (32)
Sooooo....anyone??
Old 02-18-2020, 02:32 PM   #827
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
Originally Posted by RalliartRsX View Post
Sooooo....anyone??
When I ran a plastic bush on a gktech shifter, the bush deformed and split...
Sent from my SM-G960U using Tapatalk
foreverdeath is offline   Reply With Quote
Old 02-18-2020, 02:32 PM   #828
Jorgs_7
Jorgs_7's Avatar
Sounds like a design issue or adjustment issue. GKtech also used the Nylon cup design and mine never popped out or had issues in that regard.
Is a "Hook" shifter the brand or what? Never heard of.
Old 03-02-2020, 03:48 PM   #829
BiG MiKE86
BiG MiKE86's Avatar
What are you guys doing with that vent on top of the trans?
Old 03-02-2020, 10:20 PM   #830
Sr20-Vert
Sr20-Vert's Avatar
What clutches is everyone running with these Mazworx kits I got exedy twin disk and it feels horrible i get omost what feels like lockout first to second and second to third clutch rod is all the way extended in clutch master might be to much idk can’t figure it out brand new transmission should shift smooth this thing is lock out king
Old 03-03-2020, 05:49 PM   #831
BiG MiKE86
BiG MiKE86's Avatar
What kind of grease are you guys using for the clutch splines/throwout bearing? Also anyone got a writeup on how to properly set the TOB clearance and stroke?
Old 03-03-2020, 10:40 PM   #832
TheRealSy90
TheRealSy90's Avatar
When I did the mazworx kit I used an OsGiken TS2BD dampened twin disc clutch. Also used their specific throw out bearing and bearing carrier, as it’s different length than a single disc carrier.
Such a good signature.
Old 03-04-2020, 04:39 PM   #833
240msh
240msh's Avatar
240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known240msh is making his/her stupidity well-known
Anyone using the a340 kit with a serial nine shifter in a s14 or even s13? Also if anyone is using a340, hows the t56 slave setup working for you? (drifting not just normal driving)
@Michayyl
240msh is offline   Reply With Quote
Old 03-04-2020, 10:56 PM   #834
BiG MiKE86
BiG MiKE86's Avatar
From looking at my R154 & CD009 side by side on the ground it looks like the serialnine shifter is dead on. Should be in next weekend. I can give you better feedback then
Old 03-05-2020, 07:11 AM   #835
RalliartRsX
Trader Rating: (32)
I think the OEM based setup is a little different. The shifter bushing itelf is brass. However, the shifter sits in a plastic cup.
Hoke (I spelled it incorrectly initially) was a small scale company. However, the guy closed down shop about a year ago to focus on family
https://hokeperformance.squarespace....-shifter-mount
Either way, I ordered a BNIB cup from Z1. We will see how it goes
Old 03-05-2020, 07:19 AM   #836
RalliartRsX
Trader Rating: (32)
ATS twin plate carbon carbon. Will probably be up for sale in the next month or so if anyone wants it. Used with a Mazworx bell housing and standard SR20 clutch hardware (fork, clutch line, pivot and slave). Works perfectly!
Old 03-06-2020, 09:15 AM   #837
battery1882
I'm on clutchmasters fx850 twin. OS/Ogura is king though. What kind of clutch master cylinder are you using? if stock, it may not extend far enough depending on air gap between pp and throw out bearing.
www.sterculture.com
Old 03-10-2020, 12:11 PM   #838
240msh
240msh's Avatar
Forsure I’ve searched it up I’m thinking it’ll be dead on too, let me know tho man! Thanks
@Michayyl
Old 03-10-2020, 12:13 PM   #839
240msh
240msh's Avatar
@Michayyl
Old 03-14-2020, 08:18 PM   #840
BiG MiKE86
BiG MiKE86's Avatar
I had to trim the shifter hole to make this thing fit. This trans is MASSIVE in the S13. Literally zero room in the trans tunnel
