01-17-2020, 09:03 AM | #811 | |
Trader Rating: (130)
Feedback Score: 130 reviews
also, what pivot ball do you have? there are at least 2 different lengths. |
01-17-2020, 10:13 AM | #812 | |
01-26-2020, 09:26 PM | #815 | |
01-27-2020, 08:43 AM | #816 |
Careful on the mount selection, the cheaper ones wont fit in the cross member. I just bought a Drift Freaq trans mount, dimensionally the same as OEM. Will have to let you know how she pans out
01-27-2020, 08:55 AM | #817 |
https://autosportsengineering.com/pr...apter-package/
Anyone try this autosportsengineering kit? saw a vid of a 300z 2jz on youtube and the kit looks super nice and the price is right
01-27-2020, 09:22 AM | #818 | |
I had issues using the Gktech solid mount and Gktech crossmember. i had to cut down the solid mount so that it looked similiar to an oem mount for it to mount up right on the cross member. Ordered a new megan racing mount just havent had a chance to install it. |
02-01-2020, 01:00 PM | #819 |
After doing a shit ton of research and watching countless videos on youtube I finally bit the bullet and ordered the SerialNine bellhousing and shifter for the JZ-CD009 swap. Got a brand new CD00A on the way as well. Ill keep you guys posted on this swap.
BTW I've seen some horror stories with these other adapter kits such as exploding flywheels so be careful out there guys!
02-07-2020, 08:06 AM | #821 |
Can anyone recommend a good trans mount/bracket? The serialnine kit doesn't come with one so I have to get that separate. Thanks
02-07-2020, 08:54 AM | #822 | |
02-07-2020, 08:59 AM | #823 | |
Ended up going with a full serialnine setup and competition clutch after watching a ton of videos and reviews on some of these other kits. Sent from my iPhone using Tapatalk Pro
02-11-2020, 05:15 PM | #824 |
Anyone know the thread pitch and bolt length for the 2 bolts that hold the trans mount in place? Thanks
02-12-2020, 06:07 AM | #825 |
So for folks with shifters which utilize the nylon shifter cup; has anyone experienced issues with the shifter popping out of the cup after a 1-2 or 2-3 or any shift?? It has happened several times now, and I am hoping it's not a design issue (I am on a Hook shifter) and it's just a worn out shifter cup.
02-18-2020, 02:32 PM | #828 | |
Is a "Hook" shifter the brand or what? Never heard of. |
03-02-2020, 10:20 PM | #830 |
What clutches is everyone running with these Mazworx kits I got exedy twin disk and it feels horrible i get omost what feels like lockout first to second and second to third clutch rod is all the way extended in clutch master might be to much idk can’t figure it out brand new transmission should shift smooth this thing is lock out king
03-03-2020, 05:49 PM | #831 |
What kind of grease are you guys using for the clutch splines/throwout bearing? Also anyone got a writeup on how to properly set the TOB clearance and stroke?
03-03-2020, 10:40 PM | #832 | |
03-04-2020, 04:39 PM | #833 |
Anyone using the a340 kit with a serial nine shifter in a s14 or even s13? Also if anyone is using a340, hows the t56 slave setup working for you? (drifting not just normal driving)
@Michayyl |
03-04-2020, 10:56 PM | #834 | |
From looking at my R154 & CD009 side by side on the ground it looks like the serialnine shifter is dead on. Should be in next weekend. I can give you better feedback then Sent from my iPhone using Tapatalk Pro
03-05-2020, 07:11 AM | #835 | ||
https://hokeperformance.squarespace....-shifter-mount Either way, I ordered a BNIB cup from Z1. We will see how it goes |
03-05-2020, 07:19 AM | #836 | |
03-06-2020, 09:15 AM | #837 | |
I'm on clutchmasters fx850 twin. OS/Ogura is king though. What kind of clutch master cylinder are you using? if stock, it may not extend far enough depending on air gap between pp and throw out bearing. |
03-10-2020, 12:13 PM | #839 | |
Forsure I’ve searched it up I’m thinking it’ll be dead on too, let me know tho man! Thanks Sent from my iPhone using Tapatalk
@Michayyl |
03-14-2020, 08:18 PM | #840 | |
I had to trim the shifter hole to make this thing fit. This trans is MASSIVE in the S13. Literally zero room in the trans tunnel Sent from my iPhone using Tapatalk Pro
