#31 |
![]() Join Date: Mar 2009
I will gladly put 2-3 grand in oil changes over years of ownership versus risking burning up rod bearings more quickly.
Amsoil Dominator 15/50 is perfect for sr's in hot climates, and within the oem viscosity recommendation. Hell I ran 15/50 in my daily driven sr through two Idaho winters and it was fine lol. IMO There's no need for a 0/40 or a 10/40. Also it's not Weight it's Winter. |
#32 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
AMSoil has their own compromise in oils to be honest. They have the multiple lines of Oils for different prices. $15 a QT is crazy expensive but doing quick math, If I had to change my oil once a year opposed to 2-3 times, I am already saving money! This is all factored in on miles you drive each year, I maybe get 10k in a year if I am lucky. I use T6 in my WRX so going to the Boosted series, which would still last me 1 year would be cheaper and one less oil change. To me this doesn't matter, just food for thought. I don't think i'll switch my WRX to AMSoil but I know my RB is going to run it once I get it going. He showed me the 3 common kinds. Signature series/Boosted/OE. I think the prices were $15/10/7(This might have been dealer price? I am not sure) don't quote me but it's close! EDIT:TheRealSy90. I agree with the 0/40 being useless. I ran 0/30 in my RB for about 8 miles until I changed it out due to having no ZINC whatsoever, my lifters were ticking like crazy. After my rebuild I am seeing like 9bar psi at WOT so was testing lighter oil to see if it would help lower my pressure. Im not sure when or if too much oil pressure can cause issues.
#33 |
![]() Join Date: Oct 2004
Actually on that note guys!!!! I need a little help.
I have a 3qt accumsump..... I am going to run Rotella T5 as a startup oil to get to about 500 miles...... So obviously I am going to fill that accusump..... So when I switch to AMS Signature.... how do I get all that oil out?? I guess put 60psi in the accusump, to push the oil and drain it.... Any good ideas on how to drain the oil cooler and lines? or screw it a little mix is alright? -Ken
#34 | |
![]() Join Date: May 2019
The right way is, drain engine oil, then open the valve on the accusump, let it bleed out. As for the cooler and lines, ive always disconnected the lines. Put one in a bucket and ran shop air thru it(low psi) can get messy but only way to get all the oil out. Do not forget to prime the motor backup before starting... |
#35 | |||
![]() Join Date: Nov 2005
#36 |
![]() Join Date: Oct 2013
This thread really makes me want to fix my leaky valve cover gasket and change my oil / intervals, mostly because im lazy...but I change frequently because I definitely have that "oil is the blood of your engine, the fresher the better" mindset.
Also, filters. I used to check up on bobistheoilguy once and a while, and people seem all over the place with answers. I currently run the Purolator Boss PBL20252 on my KA (Which ive ran for 5 years now) and never had any issues. Should I change to something else? Or.. |
#37 | |
either way any of those filters will easily handle 15,000 miles of daily driving, and eaaaasily 3k-5k of track driving. sounds crazy, but from what i've read, i feel comfortable doing that with those synthetic filters. if this KA is just a daily put put car, then you don't need to worry one bit about a filter. even the normal wix and orange fram or the middle fram (tough guard i think) will be just fine. |
#38 | ||
Also keep in mind that your air filter is a huge factor in how clean your oil is. If you have some chicken-wire air filter on your setup, then you best make sure your oil filter is up to par, because there's going to be shit in your engine that you don't want, haha. From what I can tell, Amsoil and Injen both have their "nano-web" filters that actually filter well while being high flow. Plenty of "high flow" filters on the market that are basically just screen doors. Quote:
Track driving is a special case, and you may want to switch to a non-bypass racing filter for track days. High-flow racing filters offer some filtration (usually in the 30-50 micron absolute range) at all times, versus standard filters allowing the bypass to open at 3-4k rpms, which means very little oil is going through the filter and most is just going around. This is something that you have to weigh the "risk" and decide for yourself which is best. I plan on testing some standard and racing filters to see if they really have different pressure drops. Another thing, if you're running a 13/16-16 oil filter relocation mount, you can run a 2-quart racing filter (if you have the room), which adds capacity at the track, and may be another advantage.
#39 |
When I used to run Mobil1 15/50 for years before they changed their formula and got rid of all the lovely zinc that sr's love, I ran the Purolator PureOne filter, supposed to be better than anything else on the shelves. But could only get them at PepBoys as far as local stores go.
Now that I run Amsoil I just order the Amsoil filter along with the oil order. |
#42 |
I used to work at a place that was an amsoil dealer, and I still get everything at cost through them so theres that. I'll look into that as well. Motul is readily available to me as well (through them)
