#23461 | |
Future Moderator
![]() Join Date: Jun 2007
While we are talking spark. Any point to split fires if hp goal is 330-350?
#23462 | |
![]() Join Date: May 2019
U can delete the ignitor and go r35 coils. HUGE upgrade....but if ur cry over $300 might not be the way for u..go isr for 80 |
#23465 | |
Maybe this will help
95 infinity Q45, but just google https://forums.nicoclub.com/sr20det-...ng-t59345.html
S13 SR, S14 KA |
#23467 |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Well s14 kouki light burnt out. Went to swap bulbs. Looks like I have to take the whole assembly out. Or am I missing something? It is super hard to reach after you take the plastic cover from behind the headlight. I swapped them out before YEARS ago.m, bit dont rememeber being that difficult.
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE! 240 addict miata addict |
#23468 |
You should beable to access the light bulb easily once the covers off. That is if ur car is a true 97-98. Core suppost is diffrent and has a hole cutout behind the headlight. 95-96 does not
#23469 | ||
Future Moderator
In addition to the above, here is my parts lists Koyo Radiator Exedy Stage 1 Clutch isr downpipe oe style motor mounts rad hose isr fmic kit cody ace a/c kt a/c drier A/C compressor Tomie Oil Pan Walbro fuel pump Greddy Intake kit - Z32 MAF turbine outlet hks bov recirc kit high flow cat tomei exahaust fan shroud gtech clutch fan upgrade Fuel pressure regulator Please advise if I am missing anything. Yes I am keeping the clutch fan, no I don't want efans.
#23470 | |
![]() Join Date: Jun 2003
Trader Rating: (130)
gktech fan. Moves a fuckton of air. Highly recommend. Only downside, is that many people have experienced it moving TOO much air at idle, preventing the car from reaching operating temps. I know a few people who use cardboard to block off 1/4 - 1/3 of their radiator, for street driving, then remove the cardboard when its time to drive at the track or canyons. a few years ago, before FRSport became pure trash, I went there and had them pull up a tomei oil pan, a Phase2 oil pan, and a ISR oil pan. All 3 are same design. I placed them all face down on the glass, and bought the one with the least amount of distortion on the flange. it was the phase2 one. haven't had a single issue with it. not a huge capacity increase, like the greddy pan, but I also run a fairly large oil cooler and filter relocation kit. make sure you keep the bracket from exhaust to transmission. it will save you from wrecking 3bolt and 4bolt gaskets. also, I prefer a cobra downpipe. IMO Moonface/Dmax is best since you get much better ground clearance, but the PBM cobra is good too, and readily available. |
#23471 |
![]() Join Date: Nov 2005
Speedo stopped working again. Odometer works fine.
Already replaced speed sensor. Already re-soldered the board of the speedometer worked great for a bit but now flat out dead. Bad speedometer?
http://www.nissanroadracing.com/ |
#23472 |
Anybody know the sizes for the bolts used to mount 180sx front seat belts?
#23475 | |
Edit: It has to be. Thats the only size that comes up.
#23477 |
Do you need a shifter extension if you run a T56 magnum?
#23478 |
Anyone running Street Faction CTSV 4 Piston front s14 brackets? If so, can you just tell me if the brackets mount to the front or rear of the knuckle?
Dont be a pussy...Leave your name |
#23479 |
Where to start on a build?
I recently came across a 1991 240SX Coupe that's been stowed away in an old barn since '08. If I can get it running it's free for me to take, and after a little bit of research, this car could potentially be worth it. As it sits, the spark plug wires have been chewed through (darn peanut oil), the oil is old and black, the gas tank straps rusted out so the tank sits on the ground right now, battery is obviously dead, the clutch is all wonky: you can push it all the way in by hand with ease, and it stays down, so my guess is the master/slave cylinders are shot. The tires all are flat and have dry rot, I haven't been able to jack the car up and see if the rotors are rust-welded to the pads. There's a moderate amount of mold inside, though some D Germ along with some elbow grease should make quick work of that.
My question is what is absolutely necessary and worth it to get the car running? So far my list contains: gas, oil+filter, battery, spark plug/wire kit, cap+rotor, fuel filter, and if i can get it running then i would go ahead and replace the whole clutch cylinder system. Anything else anyone can think of? I would really appreciate input, as well as a suggestion for a better thread to post this in. |
#23480 | ||
Future Moderator
My concern now is in the winter time will the gktech fan make the car drive poorly. It will not see much track time.
#23481 |
![]() Join Date: Sep 2004
Trader Rating: (24)
I still have the stock fan and my car mostly gets used on track. For your street car the stock fan will be fine.
I'll echo the sentiment around a different oil pan, I always add one on the swaps I do. |
#23482 |
Shit..i picked up a ebay p2m clone for $45.... fitment was on point, no flange warpage, swing baffles worked good, even check pickup clearence.. 1/8th.... solid in my book
#23485 |
![]() Join Date: Jan 2019
Can someone with a KA measure the temperature of the fluid in the power steering reservoir after some city driving?
Sent from my SM-G950U using Tapatalk |
#23486 | |
#23487 | |
Future Moderator
My s14 is weird. I bought a new a/c drier from rock auto and ebay, they are both the same but the holes are too small for my lines. Anyone have this issue?
#23488 | |
Had that thru cold air distributor. I could never find the right drier..i drilled holes bigger and light counter sunk for o-rings...worked perfectly |
#23489 | |
Future Moderator
It is listed weird. A distributor on eBay actually showed me his distribution list and it lists the dryer I bought for the 97‘s. Though clearly not.
I doubt I would be able to drill it right. Anyone got the correct drier? 97 de factory manual w/sunroof
#23490 | |
Future Moderator
It is listed weird. A distributor on eBay actually showed me his distribution list and it lists the dryer I bought for the 97?s. Though clearly not.
