Old 05-09-2022, 02:29 PM   #31
burnsauto
burnsauto's Avatar
..You bent a subframe jacking up the car? Pics or it didn't happen.
Old 05-09-2022, 03:58 PM   #32
Kingtal0n
Kingtal0n's Avatar
The huge piece of metal between motor mounts that has the steering rack attached to it,
yes it started to bend when I attempted to jack up my car from the center. Remember I am using a 650lbs Iron V8
It only bent a little tiny bit because I was paying close attention. But it def will not support the weight of my vehicle.
I want to switch to -120lbs aluminum block but the current engine won't quit. Its hard to remove a good engine.
Old 05-09-2022, 04:06 PM   #33
burnsauto
burnsauto's Avatar
oh, that makes a little more sense..lol. Just one more sign that those engines don't belong in an s chassis (I kid, I kid..)
Old 05-09-2022, 09:27 PM   #34
Kingtal0n
Kingtal0n's Avatar
Well, they make an aluminum version, -120lbs which makes the car similar to stock weight and balance. Actually it could be better than stock, or more similar to SR weight.
https://ls1tech.com/forums/conversio...ce-inside.html
I was just being cheap student and used the iron engine to save money since it was my first LS I figured I would learn on a free test engine. But I guess between the iron block and the 4l80e its just a bit too much up there. I am def looking to plate the engine to the chassis using a stiff damper and reinforcing the core support and control arms and frame rails, and tunnel regardless of weight however because once I put some real tires I don't want the chassis to twist, I'm not sure how much it takes but I don't want to find out
Old 05-09-2022, 09:45 PM   #35
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
Personally i only use the tow hitch points as a starting point to lift the car a bit with a 2nd jack since the car is so low and then jack the car up using proper locations
ZenkiKid is offline   Reply With Quote
