Old 04-04-2022, 06:38 AM   #23701
Kylerkickass240
Kylerkickass240 is an unknown quantity at this point
Due to my schedule, I will be installing coilovers one weekend, and suspension arms the other weekend. Alignment happening right after. Which should I do first?
'92 vert, '10 accord coupe
Kylerkickass240 is offline   Reply With Quote
Old 04-04-2022, 07:44 AM   #23702
Thursday7
Thursday7's Avatar
Thursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfection
I'm assuming the car is your only mode of transportation for the intermediate week. I don't think it will matter very much either way. Without an adjustable rear upper your rear will have some added negative camber depending how low you set your coilovers if you install them first. You can dial out negative camber with the camber plate in the front if you are looking for stock-ish alignment.
Why can't you do it all in one weekend? Unless you have bad luck and every suspension bolt is seized, arms and coilovers are a pretty quick swap. Don't forget eccentric lockout hardware for the rear.
Thursday7 is offline   Reply With Quote
Old 04-04-2022, 01:52 PM   #23703
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
If you plan on driving the car in between these weekends I would do coilovers first. Keep the same ride height so the alignment is somewhat in spec. Then lower the ride height(if you choose) while you are swapping the arms on the other weekend and get the alignment right away.
spooled240 is offline   Reply With Quote
Old 04-04-2022, 03:00 PM   #23704
Thursday7
Thursday7's Avatar
Originally Posted by burnsauto View Post
My question for someone with an S13 SR, can you measure the bov recirculation fitting on the stock intake tube? I want to recirc. my bov and greddy sells different sized fittings. My thinking is then I don't need to find a hose that changes size from one end to another.
ID of the rubber part is 1"
Old 04-04-2022, 04:43 PM   #23705
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
https://gramhir.com/media/2077804870766445087
https://gramhir.com/media/1900519010093593573
What is the front wheel?
Corbic is offline   Reply With Quote
Old 04-04-2022, 06:38 PM   #23706
burnsauto
burnsauto's Avatar
not a Kansei Tandem? zooming in I don't see all the writing on the lip though..
Old 04-04-2022, 08:47 PM   #23707
Kylerkickass240
I might be able to, but I work nights and don't have a garage, so my time and schedule is quite limited. Appreciate the response though.
Old 04-05-2022, 05:48 AM   #23708
Thursday7
Thursday7's Avatar
Great Company Grenade GX-01
Old 04-05-2022, 10:36 AM   #23709
Corbic
Corbic's Avatar
Oofff, I knew they looked familiar. That sucks.
Old 04-06-2022, 06:07 AM   #23710
Thursday7
Thursday7's Avatar
So I have a GKTech "baffled" over the radiator catch can on my SR, and I just fitted a new Garrett to the engine. My previous S14 T28 seemed to get pretty oily in the intake after the catch can after a season of hard multi-day event drifting, and there's a little pool at the inlet to the FMIC. The engine doesn't make much blowby (S13 SR valve cover, so pretty much any oil that wants to leave, will), but pushes enough oil to somewhat defeat the baffles of the GK catch can. I'd rather not coat this brand new turbo's compressor blades if I don't have to.
I'd like to try steel wool in the catch can on the outlet side of the baffle. I'm worried of it breaking apart and naturally going straight into the turbo. Does anyone know of an inline filter with 5/8 hose ends and where I could find one? Or does anyone have better ideas?
Old 04-06-2022, 07:29 AM   #23711
tuzzio
tuzzio's Avatar
Not entirely what you're asking for, but I have some of this in my catch can and it hasn't seemed to deteriorate in the few years its been in:
https://www.amazon.com/Uni-Filter-BF.../dp/B000ONZT5Y
However, my catch can set up is VTA, so it's not under the same conditions yours is. Just food for thought.
Old 04-06-2022, 01:20 PM   #23712
Pain
Pain is an unknown quantity at this point
Anyone know if SR20 fan clutch/water pump studs fit the KA?
Pain is offline   Reply With Quote
Old 04-06-2022, 01:57 PM   #23713
Thursday7
Thursday7's Avatar
Yeah they should. both are a M6x1.0 and all else that really matters is the thickness of the water pump pulley and clutch fan 'pulley' which are roughly the same, if not the same between engines.
Old 04-20-2022, 08:17 AM   #23714
Thursday7
Thursday7's Avatar
Thought I'd follow up and share what I figured out that I'm going to do. It seems like an inline filter with 5/8 hose barbs does not exist in entirety, but I did find this on McMasterCarr with 3/8 NPT threaded ends, so I shouldn't have a problem clamping a 5/8 ID hose on either side and should do me just fine. Nice and small so it shouldn't look too ugly.
https://www.mcmaster.com/98355K853/
Old 04-20-2022, 08:54 AM   #23715
tuzzio
tuzzio's Avatar
That seems like the cheapest option, although im personally not a fan of the difference in diameter especially if its a MAF car.
I did some quick research, and stumbled upon this which is about 10X the cost.
https://www.summitracing.com/parts/sdk-acc-gano-htr
VE labs makes a "coolant filtering and inspection system" but I couldn't find a part number. There is a 3/4" one listed on ebay.
Old 04-20-2022, 11:10 AM   #23716
Thursday7
Thursday7's Avatar
I'm surprised I haven't found that. Guess I should have searched for something for coolant.
My car is standalone so no maf. 5/8 ID hose will slip over 11/16" threads no problems and it won't leak. There is a small restriction in diameter but at the end of the day it's just to apply some vaccuum to the catch can, nothing overly sensitive.
Old 04-20-2022, 11:42 AM   #23717
tuzzio
tuzzio's Avatar
Actually, this is exactly what you're looking for. Cardone Part number 20-0058F
5/8 Barbed filter, and $18 on amazon. Win/Win
https://www.amazon.com/Cardone-Servi.../dp/B00A6RLS8K
Old 04-21-2022, 11:35 AM   #23718
Thursday7
Thursday7's Avatar
That's perfect. Looks like rockauto has it too so I'll just grab one with my next purchase. Thanks for looking out Steve!
Old 04-21-2022, 11:54 AM   #23719
tuzzio
tuzzio's Avatar
No problem man, shoutout to my new cubicle at work leaving me plenty of time to research dumb shit like this.
Old 04-22-2022, 02:54 PM   #23720
Corbic
Corbic's Avatar
30100-RS254 - Nismo Clutch
This is for a Push Type Trans, correct? Comes with Disk and Cover?
Old 04-28-2022, 12:04 PM   #23721
AKADriver
AKADriver's Avatar
What's the approximate added coolant capacity from an aftermarket 2-row 48mm radiator (eg Koyo HH, Mishimoto)? I know my stock capacity is 7.25qt (S13 KA24DE). A drain and fill of my Mishimoto rad (which is also draining some of the engine, upper hose, etc) seems to be about 5.5qt. Don't remember what it was for my stock rad.
Don't need an exact value, but Mishimoto literally just says "Capacity: 2" (2 what??)
AKADriver is online now   Reply With Quote
Old 04-28-2022, 12:09 PM   #23722
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
2 gallons = 8 quarts... sounds about right from what i remember filling my Koyo radiator. its been years since ive had to fill it so it dont 100% remember, but i DO remember buying 2 gallons of coolant for it.
Old 04-28-2022, 12:11 PM   #23723
AKADriver
AKADriver's Avatar
No, this is for pull style, you can see the center ring in this croooober listing. Nismo says it's a late R32/33/34 part
https://www.croooober.com/en/item/cp...82/NISMO-Cover
Old 05-06-2022, 01:33 PM   #23724
Corbic
Corbic's Avatar
What is the wheel?
Old 05-07-2022, 01:14 AM   #23725
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
What is the wheel?
work emotion XC-8
aaaaaaand dorkidori Type-RH skirts + Type-RH valances + urethane 180sx kouki lip (yes. plugging my own shit lol)
Old 05-16-2022, 07:33 AM   #23726
Future240
Future Moderator
Future240's Avatar
Anyone got a link to an english FSM that has the specs for a notchtop S14 SR20? I know a guy who is really good at building LS engines and figured if he had the specs he could help me rebuild my SR.
Originally Posted by ThatGuy
Old 05-16-2022, 08:22 AM   #23727
Agamemnon
Agamemnon's Avatar
I have an english FSM for the notch top. PM your email and I'll send you the file.
Old 05-16-2022, 08:34 AM   #23728
Kingtal0n
Kingtal0n's Avatar
Does anyone know if the S13 DOHC KA throttle cable is identical to S14 KA throttle cable?
I am collecting potentially strandable S14 parts, I plan to keep a spare throttle cable in my car lol I can just see it snapping clean off one day, and me hooking a string or a million zip ties together or something so I can pull the throttle from the driver seat to get the car home
Old 05-16-2022, 08:43 AM   #23729
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
I found the S14a manual and sent it to the mods at Nico club a few years ago. They have it hosted at nicoclub.com/FSM with all the other manuals.
You can also just grab the S15 EM section and use that since the engines are the same between them (mechanically).
Old 05-16-2022, 12:42 PM   #23730
Agamemnon
Agamemnon's Avatar
They're different
