Old 01-10-2023, 10:18 PM   #31
inopsey
cant see your wastegate in those pics
Old 01-11-2023, 04:04 PM   #32
240boosted
240boosted has a little shameless behavior in the past
So it’s the tial wastegate hard take a picture of it but I have the lower and upper air port use and the other air port at the top middle should I leave that and the other air ports open?
https://ibb.co/XJQ59WM
240boosted is offline   Reply With Quote
Old 01-11-2023, 04:10 PM   #33
jr_ss
So, you have an air ran to a single port on the gate?
What model Tial? MVR?
ONE port on the gate, not two..
Old 01-11-2023, 06:15 PM   #34
240boosted
Yes it’s a 44 mm tial mvr
Old 01-11-2023, 06:50 PM   #35
240boosted
So question also since I have greddy I take manifold do I need cap both I capped one
https://ibb.co/jZCR0DC
Also here my wastegate when I was building it
https://ibb.co/Qdmbd6c
Old 01-11-2023, 07:07 PM   #36
jr_ss
Photos aren?t working
Old 01-11-2023, 07:52 PM   #37
240boosted
They not showing up when I click them they show
Old 01-11-2023, 07:55 PM   #38
240boosted
They should be in the middle there working just small
Old 01-11-2023, 09:00 PM   #39
jr_ss
Again, feed only the lower port. Supplying top and bottom side ports equalizes pressure on the diaphragm, resulting in the gate not opening.
Old 01-11-2023, 09:02 PM   #40
240boosted
Yes I did it only to the bottom port I going to try a few more things once I get my car back like s14 waterbuck and check all fittings again I report back when I got them all done
Old 01-12-2023, 09:34 AM   #41
nick_d_240sx
nick_d_240sx's Avatar
nick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymorenick_d_240sx is not welcome here anymore
At this point I'd suggest removing the gate and checking it's operation with a hand pump or air compressor set on ~15 psi.
S13
nick_d_240sx is offline   Reply With Quote
Old 01-12-2023, 06:11 PM   #42
240boosted
I know it opened up I heard it when it was on dyno but ya I check when it cracks and fully opens up
Old 01-12-2023, 06:59 PM   #43
slider2828
slider2828's Avatar
At this point just swap it for a known good one or a new one.... I think that would be easiest. You can't be sure the diaphrams is bad either
Turn and Burn!
Old 01-13-2023, 05:28 PM   #44
240boosted
It was brand new I changed the spring so i know the diaphragm is not pinched or anything but I take it off and see when it cracks with air to it
Old 01-14-2023, 02:18 PM   #45
slider2828
slider2828's Avatar
Also make sure that pressure line isn't cracked or leaking or pinched between your pressure pipe and your wastegate when you eliminate your solenoid.
Turn and Burn!
Old 01-14-2023, 08:30 PM   #46
240boosted
Thank you guys for all the help really. I am using Quick Push Tubing for all my fittings. i going to rest the system again
Old 01-14-2023, 08:31 PM   #47
240boosted
these on the throttle body i just saw were open the left middle plugged and right side are open isnt the middle to charcoal canister
https://freeimage.host/i/HYgkj4I
Old 01-14-2023, 09:37 PM   #48
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
I?ve tuned a few sr?s over the years running the mazworx manifold and with a high flowing head there can be some boost creep issues while trying to target low boost with an efficient turbo. With your setup you will likely see the boost creep 3-4psi above 1 bar spring pressure.
As everyone has suggested, test/run the car at wastegate spring (no boost solenoid plumbed in) until you can get boost under control. Then once you know you have a functional wastegate it is easy to plumb the boost solenoid back in and tune accordingly.
These lines/fittings are great but be very very careful of melting the lines. Super easy to heat damage those lines running to the wastegate. Even a small leak in wastage plumbing will prevent the wastegate from opening correctly.
**I just tuned a R34 gtr that melted these lines on the dyno even though they were well insulated there is so much heat they ended up melting together.
On a budget use a quality silicone line, best option AN4 line and no matter what you use be sure to insulate and completely isolate (free floating) not testing on any hit exhaust/engine parts.
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 01-15-2023, 06:07 PM   #49
240boosted
Thank you looking at everything again now I hope my parts come this week so
I can test
Old 01-15-2023, 07:46 PM   #50
inopsey
if you changed out the spring on the wastegate i would double check that first. i remember with my 38mm msv the springs were tricky to install properly since multiple springs were needed for 1 bar psi base pressure
Old 01-15-2023, 07:58 PM   #51
240boosted
I going to change the spring now to 10 or 11 pound spring tonight and next week I be able to test
Old 05-11-2023, 08:05 PM   #52
240boosted
Car is now fixed thank you guys so I made 498hp next question he says on e85 I getting spark blow out should I try ngk BKR8e
Old 05-11-2023, 09:50 PM   #53
slider2828
slider2828's Avatar
Wow took for ever..... so it was just spark blow out? What coils and plugs you using?
Doesn't make sense it was overboosting.
Turn and Burn!
Old 05-12-2023, 03:35 PM   #54
240boosted
Sorry no the issue was the routing of the boost controller and I changed it to another haltech one and routed it like told and the problem went away. Now the issue is spark blowout according to my tuner I check the plugs and report back I think bkr7e
Old 05-12-2023, 03:50 PM   #55
slider2828
slider2828's Avatar
Awww so it was kind user error..... but spark blow out, simply just update to R35 coils from rockauto using hitachis and there is a whole thread on how to do it.
Turn and Burn!
Old 05-12-2023, 11:05 PM   #56
240boosted
Yes do you think p2m coil I have brand new would be good enough need figure out why I only at 13.2 volts with car running I think that an issue
Old 05-13-2023, 07:54 AM   #57
240boosted
Ok I looked this morning and I did use bkr8eix plugs will look. For issues low voltage
Old 05-13-2023, 07:59 AM   #58
jr_ss
8?s are too cold for your setup. 7?s for anything under 5-600hp.
Also, what is the gap?
Old 05-13-2023, 04:22 PM   #59
240boosted
It’s on e85 made 500 hp he had it gal .019 I trying figure out why 13.2 when running once I figure that out I guess next is coil upgrade the I guess my new p2m not good enough so I will look at R35 coils, haltech IGN1 coils or AM IGN1 smart coils.
Old 05-13-2023, 05:38 PM   #60
240boosted
Ok so I grounded the alternator to chassis and now 14.2 volts it should be good now thank you all for the help!!
