![]() Hello,
I'm struggling to get my low beams to produce the correct beam pattern on Bricks It's got a beam either side and a hole in the middle Any ideas? |
![]() Join Date: May 2002
Bricks are just an old school fixed reflector headlight, and you're in a RHD country so it should 'just work'. What bulb type are you using? As far as I know the outer lens just uses an H4. There shouldn't be any adjustment unless something got warped.
Or are you saying each individual light's beam is OK but they don't meet properly in the middle? Make sure the headlights' mounting tabs aren't cracked and warped, your core support isn't bent, and you're using the OEM inner brackets. |
#3 | |
You can see its bright either side and dim in the middle https://ibb.co/KV1ycqT |
I dunno how crisp an old late '80s lens-optics H4 headlight should look against a tin shed. : )
My first thought then is still that something is focally out of whack, that for some reason the reflector and bulb are slightly out of focus with the lens. It's not adjustable but something could be loose or warped. |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
Hard to tell what's going on in that image since it's taken during the day.
Hot spots in almost 40 year old reflector housings isn't uncommon.
It's not adjustable... you could spend ages pulling the housings apart and trying to focus them.
Your best bet is probably to swap in a set of projectors. Either dual or triple. They produce the correct cutoff for the low/dip beams for the UK. |
