Old 07-31-2023, 04:55 PM   #1
Radkins
Radkins is an unknown quantity at this point
SR20 Ponderous no spark on one coil. HELP
So I am getting no spark on any coil connected to the front pistons harness. I have swapped coils, checked the voltages and ground while running. Getting ground on black and 12v on the other 2 wires via a test light that pokes in the wires. I cleaned the connector and verified it is passing ground and voltage to the pins in the connector. What am I missing? I am getting the same readings on all 4 cylinders but the front simply won't spark. I can take the same coil out and plug it into a different location and it sparks. Seriously confused.
Recording School
Radkins is offline   Reply With Quote
Old 07-31-2023, 11:01 PM   #2
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Could be the Cam Angle Sensor or could the be the ECU.
e1_griego is online now   Reply With Quote
Old 08-01-2023, 07:51 AM   #3
kanyedian
kanyedian's Avatar
kanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nice
I would also check the ground on the battery, make sure it's fully charged, and check your fuses. I couldn't get my car started a few weeks ago and I dived so deep into cam sensor, crank sensors, a million fuel tech ECU settings, and all I needed was to replace a 15A fuse and she fired. Good Luck!
kanyedian is offline   Reply With Quote
Old 08-01-2023, 08:09 AM   #4
AMD 240
AMD 240 will become famous soon enoughAMD 240 will become famous soon enoughAMD 240 will become famous soon enoughAMD 240 will become famous soon enough
Send a message via AIM to AMD 240
I had similar issue with 1 coil not firing, ended up being the coil pack harness.
AMD 240 is offline   Reply With Quote
Old 08-02-2023, 08:19 AM   #5
Radkins
Would the cam sensor cause only 1 coil not to spark?
Also, why am I getting the same voltage readings on the one that doesn't spark as all the others. Ground on black, 12v on the other 2.
Recording School
Old 08-02-2023, 08:20 AM   #6
Radkins
How do I go about checking the ecu?
Recording School
Old 08-02-2023, 08:44 AM   #7
e1_griego
e1_griego's Avatar
Trader Rating: (24)
It sounds like you checked for continuity. The CAS sends signal to the ECU which in turns fires the injectors and coilpacks.
You can throw a known working CAS at the plug and spin it and it will fire off the cylinders.
I had a CAS drop two injectors in a fresh swap and went round and round checking wiring before figuring out it was the CAS itself not sending signals.
You need noid lights to really test for the signal as a conventional test light won't fire in time.
Old 08-02-2023, 10:17 AM   #8
Radkins
Does the SR20 pull the trigger to ground?
Is there a way to test the CAS?
Recording School
