![]() Bought this car that was daily driven. Previous owner said it started to give him starting issues until it eventually stopped starting completely, he would jump it until that didnt work anymore then parked it for a year(he knew nothing mechanically). I installed brand new starter and battery. I can turn the engine with a breaker bar, it has oil, when i look in the engine the tops of the cylinders are black, has new starter and battery. Tried push starting it but when I release the clutch pedal rear end just locks up. Is it a timing issue? compression issue? It's frustratingly beyond my knowledge...
1st vid of weak start https://youtu.be/cQGraoorXVc same vid with spark plugs removed https://youtube.com/shorts/gVna1dc3W3A?feature=share If anyone has dealt with this before and knows what the problem is your help would be greatly appreciated! |
Compression test it
Are all the grounds connected ? Is the wiring okay ? Are all the connectors connected Does it get enough power on the starter ? Sounds like it either loses compression or doesn't get enough power to start. |
Test for spark and compression. Fuel as well, however you prefer to do this. If you have all of those, check your base timing.
Set Cyl 1 to TDC on compression stroke. Pop the valve cover and look down the timing chain passage to where the distributor enters the head. There is a timing mark and a dot (like a divet) that need to line up. One is on the distributor gear shaft and the other is on the body of the distributor. If they are not lined up, pull the distributor and reinstall so that they do. This may require a few tries. You can also verify that the rotor contact is perfectly lined up with Cyl 1 on the cap. I prefer to use the timing mark on the distributor itself as it is more concrete and requires less guess work, even if it does mean pulling the valve cover. |
![]() Join Date: Sep 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
How many miles. Do nothing else until you comp test. If low, put an ounce or so of oil down the plug well and repeat. If comp jumps up, you have bad rings. Based on what you said it's likely rings.
#6 | |
#7 | |
Given the below, I assumed the car doesn't start at all... Either way, weak spark or a fucked up fuel system will make any engine run less than stellar.
![]() Join Date: May 2002
That intake manifold bolt that's right in the middle of the video is supposed to be connected directly to the battery with the heavy gauge ground cable. It's one big cable that goes from battery to the chassis right below the battery tray to that bolt. Without that the starter is relying on a much weaker ground path, unless you relocated the battery and added a new dedicated heavy gauge engine ground somewhere.
When it makes the high pitched "whizz" that sounds like the starter bendix isn't fully extending so it's spinning the motor but not making flywheel contact. It's a new starter but it's not an OEM starter, there's a chance the starter could also be a POS. Lots of aftermarket and reman starters and alternators are defective. My car has a reman starter and it works but it kinda... sucks and cranks slowly even though my battery is good and engine is healthy. |
#9 | |
I think you may still need a better engine ground. As it is it's kind of relying on the small ground strap on the firewall as its main engine ground. This could be where the problem started for the PO and why it would start from a jump.
Can't hurt to try, grab a jumper cable and just whack it from the motor to a big chassis bolt and see if that helps. |
