1990 240sx coupe wisefab ls1 t56
Really annoyed I have to sell this car, I just had surgery and need to pay off some bills so here we are.
![]() Asking $20,000 USD obo, any reasonable offer will be considered. I bought the car off another driver in the bay area, then proceeded to redo just about everything on the car except paint it. I've rewired the car including the tail lights themselves... Except for the engine wiring harness as its been fine the whole time I've owned it. Car dynos at 420whp, 387wtq, and drives great, with good power everywhere it feels like Engine: Low Mileage rebuilt LS1 Fast Vengeance ported 92mm intake manifold Holley sniper 92mm throttle body Holley EFI Fuel Rails with 42LB injectors Amazon Catch Can PRE/Texas Speed 243 2.5 extreme heads OE headgaskets and bolts Texas Speed 228r camshaft Stock piston/rings/rods/crank, wearables replaced upon rebuild, I have about 500 miles on this engine Sikky headers Aluminum Engine Mounts Canton Oil Pan w Baffles Oil cooler with -12 lines Spec Clutch and Flywheel - ARP bolts Mishimoto Radiator Tuned conservatively by request by Bay Area Racing Transmission/drivetrain: Was told by previous owner he rebuilt it with new syncros and replaced a gear, regardless this thing is solid, not a single crunch or grind, and doesn't leak a drop. 1 piece driveline Welded rear diff(s13) driveshaft shop axles sikky Trans mount Suspension: Wisefab v1 front suspension Wisefab v1 rear suspension Silvers NA front and rear coil overs 8k/6k Hydro Ebrake with second pair of rear calipers Front and Rear calipers are new with new brake pads Resurfaced front rotors 5 lug front and rear New drift hq Power Steering Rack Wheels/tires: Vors 17x8" front wheel 215/40r17 falken azenis rt615 Vors 17x9" rear wheel 245/40r17 burners Interior: OMP racing seats(can fit a bigger guy, I'd recommend you be under 240lbs/size 34 pant to fit comfortably) Autometer oil/water/volt gages, AEM wideband gage Pro spec/full Cage w/ Fire Extinguisher mounted Interstate Battery in Battery Box NRG quick disconnect hub Wood grain wheel, forget the brand but its in decent shape Text me if you're serious about the car, having troubles posting photos on here at the moment. 48o-652-3o74
0 horsepowers.· \ ' ' ·.1000 horsepowers |
![]() https://i.imgur.com/54JLzZe.mp4 exhaust tone @ idle
https://imgur.com/a/OS9VLQW
105* day at thunderhill, before cylinder heads and intake manifold, being kinda gentle because this was the cars first day out on track in my ownership.
