05-31-2005, 02:39 PM | #1 |
17x9 17x10 4 Lug!!
The Magic of 3 piece wheels.
Old lips New Lips Lips on wheels Note: This is a friends car.
PROCEED Grip Gambler |
05-31-2005, 02:48 PM | #3 |
That's cool. Do you use loctite on the fasteners?
My 240 vBgarage |
05-31-2005, 03:04 PM | #4 |
what were the original sizes of the rim?
can you ask your friend how s/he went about doing this process...seems cool. Last edited by tomenugen; 05-31-2005 at 03:23 PM.. |
05-31-2005, 03:18 PM | #5 |
Hey guys, if you read the bottom of the post. He says its a friends car. Not sure if he will have all your answers.
Looks good.
LSX Kouki Project, swap completed in Dec 09 |
05-31-2005, 03:24 PM | #6 |
raging panda - http://www.kodiakracingwheels.com/
kandyflip445 - yes... tomenugen - 17x7 17x8 +38 I know enough about what he did considering I was there for most of it. The wheels are now 17x9 +8? 3"lip 225/45/17 ES100 17x10 +11? 3.5" lip 235/45/17 SONAR NCbCF Version Select Full kit, Origin overfenders, S14 LCAs
05-31-2005, 05:50 PM | #11 |
How is it unsafe?
The S14 ball joint is identical, it's just 1/16" longer and doesn't have enough threads to allow the nut to tighten it onto the s13 knuckle. I simply threw on a 1/8" thick washer under the nut. Being a taper fit, that thing isn't going anywhere. Lips=$600 Wheels=$600 $1200 hotness
JDM fun |
05-31-2005, 10:44 PM | #14 | |
You can do it with any real multipiece wheel. You must figure out if you can take it apart first, some wheels are welded together, some just have some sealnt on them. Then comes lots of measuring.
05-31-2005, 11:56 PM | #17 |
Yeah I emailed these guys last year about my wheels, and they said they couldnt help me because my wheels have a "soft type edge" or something. Sucks.
(edit) here is the actual reply from them: Hello Nate, We do make replacement parts for some manufacturers but currently we do not supply the parts like you need. Your wheels have the "soft" lip edge and we do not produce that. Sorry. Daryle Kodiak Motorsports Inc. So I guess it isn't ALL multipiece wheels. For reference, my wheels are 15in Volk Mesh. And I have no idea what a "soft" lip edge is, btw. |
06-01-2005, 12:33 AM | #20 | ||
quote from the owner Quote:
Soft edge lips? Not too sure what that means, did you ask for an identical copy just bigger? Should have asked what exactly that meant.
06-01-2005, 12:35 AM | #21 |
no, but they can bitch about wheels that arent 2 or 3 peice, which are common as shit.
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
06-01-2005, 02:52 AM | #22 |
Soft lip is kind of the same thing as reverse drop center, meaning the outer lip is not stepped. You can get them replaced, you just have to look somewhere other than Kodiak since apparently they only make stepped lip halves.
06-01-2005, 09:52 AM | #23 | |
i thought the soft lip is the one that's kinda wavy...the other style is w/ a sharp edge
so the lips on these wheels are "soft"
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
06-01-2005, 12:53 PM | #25 | |
06-01-2005, 01:06 PM | #26 |
Last night I had a dream about getting three peice wheels, and in the dream I was recalling this thread. This is the first thread that has ever been in my dreams. I figure I'd share. That means if you have never typed anything, I would have never had the dream. I would have had a different dream, which could be a good or bad thing. The rim dream was OK, as far as fun in the dream. I rated it a 5/10. I figured I would share, since if you ask me, making people dream something is an accomplishment.
06-01-2005, 10:06 PM | #27 |
You wouldn't be able to make a wheel that doesn't fit (too high offset) fit this way would you? All this does is extend how far out the wheel is in relation to the fender edge correct? This wouldn't affect backspacing in the least right?
BTW, both the fronts and the rears now have +12.6 offset. The backspacing on the wheels never changed all he did was extend the outer lip 2" on each wheel. Since each wheel was modified identically, they would all still have identical offsets just like before. |
06-01-2005, 10:28 PM | #28 | |
The measurments can not be determined that simple, face design plays a big role in it. Yes backspacing wont change but offset isnt backspacing. Th wheels were not modified identically. IIRC the fronts got 3.5" Lips and the rears have 4" lips. The offsets I listed are guesses from measuring and closer to what they really are.
