Old 06-10-2005, 04:51 PM   #1
driftfactory
driftfactory's Avatar
driftfactory is an unknown quantity at this point
Sun Hyper Ground & Hot Inazma Install
We just added a new install write-up to our site. This is for all of you who are interested in voltage/grounding sytems.
We installed the Sun Hyper Ground and Sun Hot Inazma systems onto our IS300.
Click here to view the install
driftfactory is offline   Reply With Quote
Old 06-10-2005, 07:45 PM   #2
TheTicTac
TheTicTac's Avatar
TheTicTac is a well-known jackass
So this hot inazma system is similar if not the same as a MSD 6A or Crane Cam Hi-6 CDI boxes?
*GorgeousGarage* L.oose S.ocks D.aisuke !
TheTicTac is offline   Reply With Quote
Old 06-10-2005, 07:54 PM   #3
S14DB
AFC #1
S14DB's Avatar
Um no.
The MSD and Crane are Ignition boxes.
This is a capacitor in a fancy box.
Old 06-10-2005, 08:57 PM   #4
Ritz S14
Ritz S14's Avatar
Originally Posted by S14DB
Um no.
Not even that sometimes.
Ritz S14 is offline   Reply With Quote
Old 06-11-2005, 04:17 AM   #5
TheTicTac
TheTicTac's Avatar
Um no.
Last time I checked CDI stood for Capacitive Discharge Igniton, and going from what driftfactory explains in their write up, it sounds like that inazma box is a cdi box.
Old 06-11-2005, 12:03 PM   #6
S14DB
AFC #1
S14DB's Avatar
"The Sun Hot Inazma is a computerized hyper voltage system that stores energy from the battery and releases it back into the system at times of high load - for example, full throttle."
Sounds like a Capacitor to me. Just like you would have on a stereo system before the amps. I see nothing that would indicate anything to do with a igniton system.
Old 06-11-2005, 01:10 PM   #7
atom
atom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to allatom is a name known to all
Instead of reading the description, just look at where they hook it up to. It can't possibly be the same as a real ignition box like MSD, it's not even hooked up to the ignition system in any way..........
atom is offline   Reply With Quote
Old 06-11-2005, 02:51 PM   #8
TheTicTac
TheTicTac's Avatar
Do you agree with me or just wanting to prove a point you don't fully understand? The boxes I am talking about from MSD and Crane are controlled capacitive discharge units, that needs the original igntion system in place. I have never seen anybody use just a CDI box alone to start a car.
Old 06-11-2005, 05:50 PM   #9
Jeff240sx
I hate you too...
Jeff240sx's Avatar
For speaking so bluntly, you sure are wrong here.
CDI is capacitive discharge ignition [system]. The ignition box itself stores power and releases it during the ignition cycles.
This box is a capacitor, designed to keep the voltage steady in the car's electrical system (in theory). There is a massive difference between a full-on ignition system that has capacitors in it, and a capacitor in the box attached to the grounding system.
-Jeff
Whatup?
Old 06-14-2005, 10:44 PM   #10
AllenRPS13
AllenRPS13's Avatar
AllenRPS13 is an unknown quantity at this point
my friend also go that, it's pretty good! the response of the car has improved a lot
~小アレンのリベリオン~
いくせ, 勝負た! 轟こう, オレのKRMS13!!!
オレの得意技!蹴り進入!角度の少ないドリフト!
AllenRPS13 is offline   Reply With Quote
