08-18-2005, 08:38 PM | #1 |
thumping when taking a left turn. New Brakes.
So, I got all new q45 rotors and used calipers with new metal matrix brake pads for the front brakes.
I got everything installed and bled the front brakes. So I took the car for a test run, slowly at first to make sure they worked. And they worked fine. There was some rubbing that you could hear, but I think that is because of the new brake pads and new rotors, if I could confirm this that would be great. I heard that you need to do some hard braking to break in the rotors, so I started braking fairly hard. After some time, there was less rubbing on the pads, but then I could feel and hear a constant thumping under the clutch area. The wheel didn't shake, so it couldn't be anything related to alignment. The thumping would also increase the faster I drove. I then noticed that the thumping would increase in strength when taking a left turn and decrease in strength when taking a right turn. I'm not sure what this could be, so if anyone has any ideas. I did read on a different post that it could be the wheel weights? .... |
