11-01-2005, 05:25 PM | #1 |
Check out my new BIG BRAKES!! anyone else do this yet???
stock rear.
Sti rear Brembo with EVO rear rotor and it BOLTS RIGHT UP!! it needs a 3mm spacer here for the correct offset, you need to trim/remove the dust cover thats all, the brembo brake line even screws right in! For comparison. I have the fronts going on too, but I need to machine a couple brackets, I had an extra set of the gold STI brembos, but Im close to certain the red EVO brembo calipers use the same bolt spacing. EVO take-off Brembos are pretty cheap, either from wreck part-outs or people upgrading, theres not a big market to sell them since all other EVO guys already have brembos so Ive seen whole sets front and rear sell for around $600! Im making a few sets of front brackets, let me know if anyone wants any |
11-01-2005, 05:44 PM | #3 | |
until then guess I'll be parking in gear like alot of the guys with Z32 rear swaps do that dont swap over the drum brake |
11-01-2005, 05:46 PM | #4 |
More importantly, how do you plan to bleed them? Unless you're gonna put the car on a rotisserie to bleed the brakes, make sure you switch those things side-to-side before you put it on the road.
Good call on the Wilwood spot caliper. I'm almost definitely gonna go that route whenever I get around to upgrading the rear brakes. |
11-01-2005, 06:03 PM | #6 |
very cool
i was gonna do this with a set of evo 8 brakes we have here, but never had time keep us updated, thats nice, STI x EVO combined is it installed upside down, i thought u need to install the bleeder facing up?
A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan Advertiser's Specials! Read / Give Feedback! Please Rate Us! |
11-01-2005, 06:06 PM | #7 |
Cool, are STI/EVO brakes identical?
Because i'd have thought that 5x100 bolt pattern would have been a deterrant, but hey cool. Still alot of work since there's no provision for e-brake, but if you want the bling, it's impressive. |
11-01-2005, 06:33 PM | #8 | |
11-01-2005, 06:37 PM | #10 | |
you think having big brakes is is just for "bling" and yes, you cant run the 04STI rotors since they are 5X100, the 05+ STI run the 5X114 but I dont know what the offset of those are, might get a set of those too to play around with, I'll keep this updated Last edited by Krinkov; 11-01-2005 at 07:11 PM.. |
11-01-2005, 07:30 PM | #11 | |
11-01-2005, 07:43 PM | #12 |
Nice write up.
But I already went the Z32 route and my S14 came with Z32s already on them. But its good to see someone out there is actually thinking outside the box
92 FastBack - Project 98 SE - Daily Driver |
11-01-2005, 07:53 PM | #13 | ||
11-01-2005, 07:55 PM | #14 |
props for trying something new. can't wait till everything is figured out.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till. -Emerson |
11-01-2005, 07:56 PM | #15 | |
he went over it at least twice. props, looks good. i was working on my friends STi this evening and wondered how difficult it would be to swap the brakes. |
11-01-2005, 08:13 PM | #16 | |
11-01-2005, 08:37 PM | #17 | |
*subscribes*
wow, good to know.
11-02-2005, 01:11 AM | #20 |
Other than the bolt pattern of the 04 sti, evo/sti brembos are the same. Only thing is EVO brembos are easier to find, the sti brembos sell FAST to ej20 owners. They both use the same exact pads with 4 pot front/2 pot rear.
Signature Exceeds Forum Limits |
11-02-2005, 01:16 AM | #22 |
Oh and if your able, replace those rotors with Powerslot/Rotora/StopTech/Endless/P.MU or whichever floats your boat, their not the best durability wise and youll have to do it later anyway.
11-02-2005, 02:15 AM | #23 | |
EVO rotors Front = 320mm Rear = 300mm STI Front = 326mm Rear = 316mm another interesting note is that the EVO front rotors are 32mm wide whereas the STI fronts are 30mm wide. They use the same Brembo caliper but the EVO actually uses 1mm skinnier brake pads! so you can use EVO pads on STI and just be short a bit of pad life(Ive dont this on my STI) but you cant use STI pads on an EVO unless you turn the rotors down 2mm. Some companies, Like EBC, only make one part number for EVO and STI pads and just cheat STI guys out of 1mm on each pad, lol. One other difference in the fronts, besides the diameter, is the hat height(offset) the STI(53mm) is almost identical to the 300ZX(54mm) whereas the EVO is 43.5mm. Since Im designing custom brackets anyways, I can make them to whatever offseet they need to be to fit, though all things being equal, the EVO rotors will move the Brembo caliper about 10mm closer to the wheel than the STI or Z32 rotors, so that could be a clearance problem depending on what wheel your running, the best combo might be EVO rear rotors and 05+ STI(%X114) front calipers to keep the offset as close to stock as possible, and they're 6mm bigger to boot! |
11-02-2005, 07:36 AM | #24 |
Just subscribed.
Kepp us updated for sure. Now to make off with the brakes from one of my coworker's evos here at the shop
S13 redtop 2871R.64 377 rwhp 322 rwtq 11.5 @ 117 |
11-02-2005, 07:45 AM | #25 | ||
Good work with the install.
11-02-2005, 07:56 AM | #26 | |
http://arizonazcar.com/240sxbrakes.html
11-02-2005, 08:33 AM | #27 |
id hope the hat area is sitting againts the hubs or thats some nasty flemingo action..
I say screw the wilwood brakes, tahts extra crap to put in the conversion, *not to mention added weight and lines* just put a hydrolic ebrake level that connects to the rear brake lines. So what brake master cylinder are you going to swap? Id asume u where going to change that too... I wonder how bad the brake bias will be...
Keep it Classy |
11-02-2005, 08:35 AM | #28 | |
11-02-2005, 08:53 AM | #29 | |
11-02-2005, 11:15 AM | #30 | |
I'll still keep a flying Subaru or two though, lol |
