#272 |
i need help i just baught a s14 and one injector is bad i would like to know if i can replace it with another injector maybe from a maxima or altima??? or sentra or something i can find in the junkyard.......just for a quick fix...any sugestions?
#273 | |
![]() Join Date: Jul 2009
Trader Rating: (50)
![]() Feedback Score: 50 reviews
aslong as the injector is red its a 270cc which is the same as the s14 ka injectors. ka altimas are the same. ![]()
wtb s14 roof wing/spoiler! pm me |
#279 |
![]() Join Date: Apr 2008
But the dyno #'s was on a bone stock ka...now run those on somethim wit high comp,better intake mani design and some bolt on's , ecu tune
n u might b very surprised.the stock ka cant take advantage of those kind of bumpsticks |
#280 |
![]() Join Date: Jan 2010
![]() Feedback Score: 7 reviews
those #s had bolt ons and tuning
#281 |
the #s are still like 10 wheel hp so its not a bad gain but its the curve that im interested in, by the way what did u think of that intake man u had?
#284 |
Looking to do a rebuild on my hatchback soon and will be looking for opinions/expericence with N/A power in mind.
Will over build the bottom end incase i want to turbo this one down the road aswell. So far i have.. Good running 93 motor with new lightweight flywheel and act clutch combo. Hot shot header 272 delta cams spare 93 head spare ecu lightweight crank pulley custom intake piping parts Looking to make this motor as responsive and efficient as possible. |
#286 |
im looking into building up mine NA (hopefully to 200 bhp) is it worth it to build it NA and DD it? or (since its my dd) should i just give in like many others and get a turbo? (i like the idea of NA much better)
#287 |
all depends on what u wana do with it. if its just a car that u can enjoy and tool around in then go for it i like building n/a cars cuz u can do one bolt on at a time, not like turbo where u need a lot of things done at once. but to get 200 hp it needs a lot of work the ka sucks at na
#289 |
can anyone confirm that this o2 sensor is for a KA24 or an SR20.
i'm looking for a pre cat #1 o2 sensor (on the manifold). seller might have mistaked it for the 2nd o2 sensor, but insists its off a ka24. the shop i took it too said it doesn't fit on my ka24 pre cat o2 bung and that the sensor i received was for an sr20. ![]()
Team Taylor Swift - Retired |
#291 |
I can confirm that my rear 02 sensor from my '95 KA looks EXACTLY like the one pictured.
'95 240 | @SleepySteve72 |
#293 |
![]() Join Date: Sep 2010
![]() Feedback Score: 12 reviews
prpject D180 you have a cool KA. Any recent Dyno's? Any new parts on your NA KA?
I hope you still have it! Anyone else currently building an NA KA set up? |
#294 |
I think something is off, or it's really tired. This is from after a tune. Granted it did 149 on a mustang a few weeks later with no other changes.
Ebay 4-2-1 header BC-264's DIY 2.5" mandrel bent exhaust Intake Custom intake manifold SR 370cc injectors Bikirom tune Some sort of irridium spark plug PS removed TB coolant thing eliminated Oil analysis came back fine, compression was/is fine... the last time I checked it. Think maybe my BC264's arent doing what I want them to, or that the intake manifold isn't working out like I'd have liked. ![]()
#295 |
Not really sure where to post and dont want to get yelled at for being a idiot and not searching, but here goes!
So im looking into buying a blown ka (spun rod bearing, head gasket etc) and rebuilding it for myself one day. i have a few questions i have tried to find the answers to but cannot. 1. I know the short way to write it , EVG or what ever. But what are all the componets needed to pass CA smog. i want to rebuild a reliable and smog legal engine, in my area i've seen a few smog checkpoints and i just dont want to deal with the hassle of RB/SR/Built KA. (not really one for power) dual cam. 2. Would after market Rods and pistons effect SMOG? i would like it just to be strong and built to maybe one day handle power, but this is for the long run. 3.i was reading somewhere that people do a cam swap, 248/232. are those after market cams, or stock cams? cant really find anything on those either. i probably have a lot more questions, but none i can think of right now. if anyone has any info i would really appreciate it. or links you can call me a noob i dont really mind, i am anyways. thank you! |
#296 |
Different rods and pistons will not effect smog unless you change compression ratio, but even then you can still pass.
You will need to retain all the other shit though as CA does visual inspections iirc; so evap canister and solenoids need to be functioning, EGR, idle air, cat, no other CEL's, etc.
#297 |
scope240sx ,well my project has ben on hold for a couple years as you can see lol,my bad.i sold my last 14 last year n the one before that got destroyed thanks to a happy driver takin up 2 lanes..i been gettin parts together slowly.i knife edge my crank n rebalanced it for 9 rpm not saying im goin to rev it that high,other than that im in the middle of moving so idk whats goin to happen.i'll keep you guys updated when im back
#298 |
I've got a fully built ka from top to bottom has everything you can do to a NA motor do you know anyone who would be interested in it I'm done with NA to exp for me
Sent from my iPhone using Tapatalk |
#299 |
Replacing a Head Gasket
My 240 needs a new head gasket. Do I have to buy a whole kit (http://www.partsgeek.com/gbproducts/...L_6xoCGXjw_wcB) or can I just buy a head gasket (http://www.summitracing.com/parts/fe...sxoCAmrw_wcB)?
Thanks in advance. |
#300 | ||
GM2 (SW/AW)
Come on guys, attempting to revive an old thread. I know there are still guys out there with old reliable that have some questions. Let it all out.
KA-T for life! Current for sale advertisement ![]() |
