#2971 |
![]() Join Date: Feb 2002
Trader Rating: (68)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 68 reviews
Well finally got mine fully assembled and in the car. Just need to have a downpipe made and charge pipe coming off the turbo. Needs some other small things but its very close to running!!! Once the motor is running and everything is working the way it should I will finish looming all the wiring and have it tucked away nicely.
![]() Sittin pretty ready to go in. ![]() Almost there now!!! ![]() Home at last!!! ![]() A little heat shield I had made up for the drift freak motor mount on the driver side. ![]() A shot of the heat shield installed. Fits like a glove!!! ![]() Mocking up the HX35 w/BEP .60 a/r housing. Will be relocating the power steering reservoir. Also need to rebend one of the brake lines that will interfere with the downpipe. ![]() Another shot of how it sits now with most of the intercooler piping hooked up and wiring run. ![]() And a shot of how my wiring will be run through the firewall. Of course I will have grommets in place and everything will be loomed up in techflex loom. Will be routing the MAF and CAS wiring down the turbo side of the motor so it isnt run across the front like normal which I hate. I will be looming that wiring in kevlar techflex high temp loom since it will be so close to the turbo and manifold. Thanx for looking, Cameron |
#2972 |
![]() Join Date: Feb 2008
Who/how was that ps pump bracket made? That is exactly what i need to do on my ka-t.
https://www.facebook.com/HeatBloom |
#2973 |
Cameron, it is about damn time! I sold you that motor years ago now...
Everything looks great btw...
#2975 | |
![]() Join Date: Oct 2007
Its a billet plate i bought from Taarks in australia ! They only make it for sr though and it bolt right where the ac was
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
#2977 |
1995 chase bays 240sx Garage built > shop built Follow build on Instagram @jakeillest
1991 built 240sx / swapped sr20det redtop/ built |
#2978 | |
Trader Rating: (68)
Cameron |
#2983 |
![]() Join Date: Jun 2011
Looks like a mustard container...... and I hate! Mustard......... still looks clean and simple
TAPATALK
zenki time! "Cant buy weed and pussy with disney dollars" |
#2986 |
Here is mine now that it is 99% done.
#2990 | |
![]() Join Date: Mar 2011
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 21 reviews
Just need to add BOV, vacuum line to hot pipe, and blow by to intake. ![]() ![]() ![]()
DLG - DIRTYLOVE |
#2993 | |
A good budy of mine is running a forge bottom end + stock head DOC Race exhaust mani Precision 46mm wastegate Precision 5557 ar.63 And he's making 390 whp // 400lbs at 20psi on pump gaz (on a mustang dyno) You should get close to 400whp
#2994 |
![]() Join Date: Oct 2012
![]() Feedback Score: 13 reviews
Pretty darn close to my setup. Forged bottom with rebuilt head and bc 264 Cams and valvetrain. I have a 5857 .82. Will also be on pump gas with an aeromotive 340 pump and ID 1000 injectors.
#2997 |
![]() Join Date: Nov 2010
Just put mine back together after an attempt at painting and hiding the wiring without cutting and actually tucking.
#3000 |
Not without a water pump sir lmao no belts. Is that powercoat on the turbo and mani? Looks great
TAPATALK
battery relocate |
