#3151 | |
![]() Join Date: Jul 2007
Trader Rating: (18)
![]() Feedback Score: 18 reviews
What size are those threads?
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
#3152 |
I just installed my 2j water pump and drift motion pulley set on my 1jzgte.... but the alternator is nowhere near lining up
Zenki s14 1 J Z- G T E |
#3153 | |
Quote: Originally Posted by is300FREAK23 .. front plug(thats circled) is 1/8 npt and that is for a technician to read oil pressure .. Thanks atlspeed!
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#3156 |
Yes that's what it was..... I'm a retard lol. The pulley looks like it goes the other way.
#3157 |
![]() Join Date: Aug 2009
![]() Feedback Score: 16 reviews
Anyone have trouble installing their driveshaft. I have a sc300 motor/W58 Trans and my DS goes in .5" and hits the metal sleeve on the inside of the trans. Everything else seems to be good, just dont know if i should force it or if the way i am trying to put it in isnt allowing it to go in straight.
Check Out My S13 Build |
#3158 |
Im currently trying to find the measurements of the drive shaft for a s14 with a r154, 2jz. Buying mine in a few days from shaftmasters. Going with aluminum, they quoted me 340 shipped with black friday deal!!
Unfortunately I wont have the engine in till spring, wayyy after black friday lol Anyone have those measurements? Would like abs and non as well, going to look and see which one is mine when I go to storage next time. Thanks guys
Looking for good conditioned 2jzgte swap parts for 240sx s14! |
#3160 |
seem like my DriveShaft is alittle to short.....
#3161 |
Thanks a bunch turbob16ef, is yours abs or non? Also you ever get around to using the magnafuel 750? Or was that soneone else lol
#3162 |
Sorry to hear that, is there a "easy" way to fix that or just buy a new one?
#3163 |
I can have it fixed. Cut and Extend, or just have a new one made. I have a shop nearby that can do it.
#3164 |
![]() Join Date: Jan 2012
![]() Feedback Score: 13 reviews
Well I thought I had a tape measure here at my house, but can't find it. Ill bring it with me to work and take measurements there. I bought my aluminum driveshaft used, he had it in his s14 with s15 hlsd rear with abs. I will be using a 97 q45 diff that had abs. I was talking to the og owner and he was saying(before I bought my q45 diff) that the .25-.5 of an inch shouldn't be a problem.
As for the magnafuel 750, I will still be using it. Project is slightly on hold for xmas(got 2kids) unless I find good deals along the way. But I will be trying to fit the pump inside the stock tank with a fuel labs sock on it. Hopefully it'll work, if not Owell, don't mind showing the big ass pump off. Lol. |
#3165 |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Anyone have pics of their AC and lines installed in a s13? Also what lines did you use? Figure I could get some lines custom made.
I'm swapping my 2jz out of my coupe and into my vert and still want to retain the AC. I'll have to resort to refabbing my 4" downpipe.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#3166 | |
Thats cool yeah family first for sure. Yeah im hoping that it fits in there, just want mine clean but if it has to be inline ill figure that out too lol
#3167 |
the distance from the tip of the W58 spindle to the J30 Diff is: 47 1/8"
The total length of my driveshaft is 48 1/16". So mine needs to be extended, and i think i have a R154 yoke since it has been giving me pure hell to install it and it doesnt have the dimple on the inside of the yoke. ![]()
#3169 |
Thanks, confirms mine needs to be extended 3".
#3170 |
This is for an s14 driveshaft. I should have stated that earlier. I'm not sure about the s13 length. You might be able to call zerolift or get nuts and see if there nice enough to give out s13 lengths. Or maybe someone on here will contribute.
#3171 |
Well luckely mine is a s14, so you said i will be fine either way if mine is ABS or NON? I just wish i could go get my car now but its at my dads land in a barn and cant do this without him until thursday morning HOPEFULLY.... ugggg
#3172 |
I would think it would be fine to use the non abs driveshaft on an abs diff, but not sure about the other way around. Would more than likely fit, just don't want to guarantee that. Lol.
#3173 |
The guy that I got my driveshaft from works at a driveline parts supplier/maker. I asked hi. Before buying it if it would be fine to use it on a non abs, he said it slides on the tail more than enough, that the most possible of an inch really shouldn't make a difference.
#3174 |
I didnt realize the s14 ds was longer... anyhow, i have to get the right yoke and extend.
#3176 |
![]() Join Date: Nov 2011
Is anybody running a 2j in extreme heat? I already have a hard enough time keeping my SR cool on track days, and as much as OP was emphasizing the heat, it worries me.
#3177 |
I've took mine drag racing in 105 degree temps and clocked off back to back low 10 second runs. Only issue I ran into was the transmission heating up lol
#3179 |
It's not hot where I'm located but I run a Circuit sports swirl pot and heat wrapped alot of stuff in my engine bay and it's significant'y cooler. i'm running a Koyo Rad a big puller fan and a Isis 12" pusher fan as well and temps stay 150-160 for me.
BlackHand |
#3180 |
![]() Join Date: Jun 2009
![]() Feedback Score: 7 reviews
For those of you looking for Driveshafts,
Xcessive sells one that fits both ABS and Non ABS cars with an R154 or W58, i am using this one in my car and it fits perfectly, and was fairly cheap as well, cant recall the price, but contact Rich @ Xcessive |
