Old 06-25-2014, 08:55 AM   #3151
livelovesole
livelovesole is an unknown quantity at this point
I wanna get a set of Work XD9. I want to maintain a stock body ( no over fenders ) but dont mind roll & pulls. Im deffitnitly gonna lower it as much as i can. I am also going Z32 5 lug as well. Was wondering if I having clearance issues running 17x8.5 +30ish up front and 18x9 +20ish in the rear ??? Or if anyone can tell me what sizes I'll start running into issues??? thanks guys in advance.
livelovesole is offline   Reply With Quote
Old 06-25-2014, 12:43 PM   #3152
wafflez66
240 Dismantler
wafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond reputewafflez66 has a reputation beyond repute
I just picked up a set of Starforms (2) 17×8+9 & (2) 17×9+15 for my stock body s13 on k-sport coilovers. Was wondering what tire sizes you guys might suggest?
Originally Posted by Knuckshaft View Post
You're the one playing in the sand box with no panties on.
wafflez66 is offline   Reply With Quote
Old 06-28-2014, 03:01 PM   #3153
lalo167
lalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the rough
Anyone know if I can clear Q45 brakes up front and stock rear with "A DISK" Work Wheels?
lalo167 is offline   Reply With Quote
Old 06-28-2014, 09:30 PM   #3154
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Rears will clear for sure, i've cleared Z32/R32 rears with O-disk. Front, not 100% but I dont see why it wouldnt. Q45 front brakes aint exactly thick.
CLICK HERE!!!
Old 06-28-2014, 09:32 PM   #3155
lalo167
Yeah exactly what i was thinking. Thanks man,
Old 06-28-2014, 09:35 PM   #3156
fliprayzin240sx
Worst case scenario, it shouldnt need more than 5mm spacers if it doesnt. You can slap 5mm slip ons on the stock studs.
CLICK HERE!!!
Old 06-28-2014, 09:41 PM   #3157
lalo167
Yeah ill most likely try the wheels on before i re-barrel them.
Old 07-01-2014, 01:49 AM   #3158
Ryan_1
Ryan_1 is an unknown quantity at this point
18x9.5-6 on standard S14 front gaurds. what size should i go? 215 35 or 225 40. does it look funny going 35 profile and and 40 profile rear. i have extended front lower control arms.
Ryan_1 is offline   Reply With Quote
Old 07-01-2014, 09:02 AM   #3159
stuckonfresh
stuckonfresh's Avatar
stuckonfresh is an unknown quantity at this point
The tire profile is just a percentage of the tire width (265/35 tire means the side wall will be 35% of 265), so a 225/35 will have a "thicker sidewall than a 215/35. so I supppse you could measure this out for a 40 profile tire and decide what you want to do.
stuckonfresh is offline   Reply With Quote
Old 07-02-2014, 12:44 AM   #3160
Ryan_1
my rear tyres are 235 40
Old 07-02-2014, 06:33 AM   #3161
I'm Redline
I'm Redline's Avatar
Keeping it 'square' is an advantage when you rotate wheels from front to rear. Not staying square means you wear tires faster and suck it up faster eating raman
My work in progress...
Old 07-02-2014, 07:41 PM   #3162
LRDS13
LRDS13's Avatar
LRDS13 is an unknown quantity at this point
I have an s13, looking into buying some 17x9 +12, +22 or 17x9.5 +15, +18 rims but don't know what offset to get them in, I have fortune auto coilovers and don't know if I will need spacers to clear them,
LRDS13 is offline   Reply With Quote
Old 07-02-2014, 08:04 PM   #3163
LRDS13
LRDS13's Avatar
or what other offsets can i use without having to use spacers?
Old 07-03-2014, 11:40 PM   #3164
Black R
Black R's Avatar
Black R is an unknown quantity at this point
New one:
18x12 et+20 with 335/30/18 up front on s13: how much spacer?
I'm guessing 30-35mm.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 07-04-2014, 10:29 AM   #3165
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
^^^Dear lord...
Yeah, you definitely don't need spacers with those options. 17x9+22 will PROBABLY clear most coilovers without spares, but the 17x9+12 will CERTAINLY clear. Same with the 9.5's. +18 might clear, but probably won't, so the +15's are a safer bet.
"Simplicity is the key to brilliance." - Bruce Lee
simmode1 is offline   Reply With Quote
Old 07-04-2014, 09:05 PM   #3166
s13-Silviaa
s13-Silviaa is an unknown quantity at this point
hey guys! im kinda new here but ive been reading posts on this forum as a guest. epecially this one.. i've been trying to research wheel fitments and have seen a few.. but dont recall seeing anything with a similar setup i plan on having..
i have a 93 240sx coupe. will be doing silvia fron conversion with 50mm rear overfenders and 40mm front. my car has allot of aftermarket suspension parts.. i havent had a thorough look to see what is all there (car had everything on it when i bought it).. it does have coilovers so i know that will help with fitment in most cases.. i would like to avoid modifying the wheel wells in the front. i would like a wide and aggressive setup with deep dish and whatnot. with a square stance or with minimum camber if possible.. but all these setups and offsets get kinda mind boggling.. perhaps you guys could help me and post some wheel specs that will work on an s13 with widebody fenders that i mentioned.. but of course.. with some play room for spacers as i intend to upgrade my brakes before i get new wheels..
thanks guys! hope someone can help
s13-Silviaa is offline   Reply With Quote
Old 07-05-2014, 09:19 AM   #3167
Black R
Black R's Avatar
^ I can tell you right now that 18x12 et+20 fits the rear with 50mm overs.
I'll have to do some math for the front.
What ride height?
Old 07-05-2014, 03:14 PM   #3168
s13-Silviaa
What ride height?
not exactly sure to be honest... i dont exactly have perfect roads in my area so nothing crazy.. at a side view i want a little bit of a gap between the top of my tire and my fender.. not going for a crazy slammed look.. just want something that fits well and is able to be flush to the side of the car..
also.. if you or someone else could possibly provide a decent range of wheel spec setups.. with some wheel suggestions.. (can just give names and i can look it up myself) pretty much just looking for a deep dish.. dont have a specific style of wheel i like more then others really.. so im open to all suggestions.. thanks
Old 07-05-2014, 09:27 PM   #3169
MeGusta
MeGusta's Avatar
MeGusta is an unknown quantity at this point
Where to purchase Wheel lip for a Vsxx in SoCal at a good price
would you guys recommend having someone taking the wheels apart n replacing lips or the processes is pretty basic & DIY ?
MeGusta is offline   Reply With Quote
Old 07-05-2014, 09:37 PM   #3170
andyonevia
andyonevia is an unknown quantity at this point
Question: Does adding camber to the front bring the inside of the wheel closer to the coilover? I'm have serious rubbing issues.
andyonevia is offline   Reply With Quote
Old 07-06-2014, 09:07 AM   #3171
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
Will 18x10.5 +20 fit on the front of an s13 coupe without tubbing the front? Obviously wider front fenders are required. I'm just wondering if I can pull it off with a some stretch, camber and hammering the wheel wells. Also whats the minimum spacer size I need to clear the coil?
e30gangsta is offline   Reply With Quote
Old 07-07-2014, 08:45 PM   #3172
fliprayzin240sx
New one:
Spacers the least of your worries...
I wouldnt go anything wider than 9.5j on S13s. You can make it fit but good luck making u-turns.
CLICK HERE!!!
Old 07-07-2014, 08:47 PM   #3173
fliprayzin240sx
Depends on HOW you're adding camber. Most coilovers have slotted upper perch holes, if you push the knuckles in, then tightening the perch holes, you'll get more camber but you'll also be pushing the wheels closer to the strut/suspension.
CLICK HERE!!!
Old 07-07-2014, 08:49 PM   #3174
fliprayzin240sx
Pretty basic, just gotta make sure you clean the mating surfaces and getting good silicon to seal them. Trick is, dont over do the silicon and letting them cure atleast 24 hrs before you mount tires on them. Can't remember what the torque specs is off the top of my head but there are a bunch of guides on line on how to reseal 3 piece rims.
CLICK HERE!!!
Old 07-08-2014, 02:47 AM   #3175
jruiz801
jruiz801's Avatar
jruiz801 is an unknown quantity at this point
s14
okay well im looking to buy some str 514 to put on my s14 and i dont know much about offset and fitment and ive done quite a bit of searching and cant find which ones i want to get so i can fit under stock fenders here are my options
17x9 +20
18X10 +10
18x10 +20
there are all the options someone please help me choose please here http://www.str-racing.com/products-p...w-machine-lip/
240sx S14 Kouki work in progress
jruiz801 is offline   Reply With Quote
Old 07-08-2014, 10:25 AM   #3176
Kyle5.0
Kyle5.0 is an unknown quantity at this point
Im coming from the mustang world and have a couple questions on s14 wheel fitment. Ive searched but haven't really had any luck. I dont want to run any spacers but want a pretty flush wheel. Could I run 18x8.5 +20 (F) and 18x10 +20 (R) mustang wheels without needing spacers and have enought coilover clearance?
Are people running fr500s/saleens using spacers? Thanks
Kyle5.0 is offline   Reply With Quote
Old 07-08-2014, 06:45 PM   #3177
fliprayzin240sx
17x9 +20
18X10 +10
18x10 +20
17x9 +20 is a safe pick if you dont want to pull fenders. 18x10 +10 is doable if you want to pull the fenders and should clear suspension all around.
Its not a bad set up, just kick the fronts up to a 9 or 9.5 if they're available. But if you opt with the 8.5s, they should clear suspension without the need of spacers. Mind you, it may not be flush enough to the fender, that would be the reason you might want to slap some spacers up front. Thats why I recommend 9 or 9.5s.
CLICK HERE!!!
Old 07-09-2014, 01:10 PM   #3178
jruiz801
jruiz801's Avatar
Okay thank you very much
Old 07-09-2014, 04:00 PM   #3179
gman-s14
gman-s14's Avatar
gman-s14 is an unknown quantity at this point
Offset wise on a s14. 18x9.5 245/35 front and 18x10 255/35 r
The front I'm up in air with 235/40 or 245/35
Stock front fenders. Rolled but not pulled rears
gman-s14 is offline   Reply With Quote
Old 07-09-2014, 10:54 PM   #3180
fliprayzin240sx
+20 up front and I'd go mid +20s to 30s for the rear. Fronts, personally, 225/40-18s.
CLICK HERE!!!
