Old 10-09-2012, 02:35 PM   #301
JDGrimReaper666
JDGrimReaper666's Avatar
JDGrimReaper666 is an unknown quantity at this point
Are you guys using galvanized sheet metal? I was thinking of using 16 ga galvanized sheet metal for the surrounding parts of the tubs. My tubs are 16 ga btw.
"Show no compassion, like having a straight face orgasm"
JDGrimReaper666 is offline   Reply With Quote
Old 10-09-2012, 11:17 PM   #302
07sitos13
07sitos13 is an unknown quantity at this point
thats not galvanized. just plain sheet metal
07sitos13 is offline   Reply With Quote
Old 10-10-2012, 01:08 AM   #303
JDGrimReaper666
That's exactly what I asked for when I went to one of my local suppliers, he said all they carried was galvanized. It looked fine but I'd rather get input from you guys before pullin the trigger. I'll be trying to source some plain sheet metal...
Old 10-10-2012, 01:21 AM   #304
Captain
Captain's Avatar
Captain is an unknown quantity at this point
Eventually i had to ditch the hks filter because it wouldnt fit under a hood with my tubs :/
Captain is offline   Reply With Quote
Old 10-10-2012, 06:54 AM   #305
Beejis60
Beejis60 is an unknown quantity at this point
Though there's research that boasts of its safety, I still don't trust to weld galvanized steel and inhaling a bunch of zinc oxide fumes.
Beejis60 is offline   Reply With Quote
Old 10-10-2012, 11:53 AM   #306
JDGrimReaper666
^^^ thanks for the input. I had no idea. Seems like the best bet is to get plain sheet metal.
Old 10-10-2012, 12:19 PM   #307
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
cant you just grind it down and clean it up where you're going to weld?
pacotaco345 is offline   Reply With Quote
Old 10-10-2012, 12:40 PM   #308
Beejis60
Sure, but why spend the money on galvanized then? Unless you get it for the same price as steel. Also, the propensity to make the job look shitty is higher by grinding anything. Considering you should paint it regardless, might as well just go with plain ole sheet metal.
Old 10-10-2012, 01:18 PM   #309
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
if its going to be a track car ,just take a bigg ass hammer to it , just going to get beat up any ways!
blessedhellrider is offline   Reply With Quote
Old 10-10-2012, 04:44 PM   #310
KoukiMonsta
KoukiMonsta's Avatar
As for galvanized I would stay away, it costs more and as mentioned involves harmful fumes. Another thing to note is painting it can be...funky
@UpshiftEngineering
Old 10-10-2012, 07:16 PM   #311
JonathanPrem
JonathanPrem's Avatar
JonathanPrem is an unknown quantity at this point
What are you guys doing with the fuse box for s14 other then relocating inside
JonathanPrem is offline   Reply With Quote
Old 10-11-2012, 09:32 AM   #312
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
I work in a large scale fabrication facility, and have inhaled zinc oxide fumes accidentally before.
Trust me, regardless of if it's bad for your health or not, it's not a fun experience.
thefro526 is offline   Reply With Quote
Old 10-11-2012, 09:47 AM   #313
Beejis60
Ya, I'm a chemist so I know all about it
I think the claims are if you're using a MIG welder, the shielding gas 'should' blow away most of the particulate.... but something about breathing in fine powder makes me think of it as silica and relate it to silicosis.
Old 10-11-2012, 05:10 PM   #314
JDGrimReaper666
From what I was told you're able to clean it with household vinegar and primer it to be able to paint it.
Old 10-24-2012, 11:14 PM   #315
PerilousActs
PerilousActs is an unknown quantity at this point
Here's mine. Welds look rough from not having access to a mig to do them.
PerilousActs is offline   Reply With Quote
Old 11-12-2012, 02:51 AM   #316
turbonola
turbonola is an unknown quantity at this point
you stick welded that? looks good
turbonola is offline   Reply With Quote
Old 11-12-2012, 07:45 PM   #317
Martino
Martino's Avatar
Martino is an unknown quantity at this point
IG: @vsMARTINO
Martino is offline   Reply With Quote
Old 12-04-2012, 06:10 PM   #318
StryfeS13
It's Always Broken.
StryfeS13's Avatar
StryfeS13 is an unknown quantity at this point
Does anyone have pics of how much you actually need to cut out before the install of tubs? Do you need to cut into your strut tower at all?
once its done you can drive it off a fucking cliff for making such a fucking stupid thread.
Gotta love Zilvia.
StryfeS13 is offline   Reply With Quote
Old 12-04-2012, 06:51 PM   #319
Martino
Martino's Avatar
Depends how you want to do it really. I took the harder route and cut it pretty much all out, making my own panels and allowing more room height and width wise.
But yes, you need to cut into your strut tower at some point.
IG: @vsMARTINO
Old 12-04-2012, 06:57 PM   #320
Nismo 240
Nismo 240's Avatar
Nismo 240 is an unknown quantity at this point
Here is what i cut out on mine
Nismo 240 is offline   Reply With Quote
Old 12-04-2012, 08:58 PM   #321
Beejis60
You will need to cut into the towers some. I did my final cutting after I had tacked in the arches. Mine is a little unlevel but IDGAF
Old 12-04-2012, 09:22 PM   #322
tricky_ab
tricky_ab's Avatar
Originally Posted by Martino View Post
This is the business right here!
Old 12-04-2012, 09:42 PM   #323
Vadim's13
Vadim's13's Avatar
Vadim's13 is an unknown quantity at this point
Not done but u get the idea. :-)
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Vadim's13 is offline   Reply With Quote
Old 12-04-2012, 10:48 PM   #324
theabbott
theabbott is an unknown quantity at this point
them not being level would bug the shiz out of me
theabbott is offline   Reply With Quote
Old 12-05-2012, 11:49 AM   #325
Beejis60
It did for a few months. It wasn't me who started the welding on the drivers side arch, it was my friend who, unbeknownst to me, was high at the time. In the end, it's not a show car so I got over it. Needless to say, I've not let him help me with anything since.
Old 12-07-2012, 01:01 AM   #326
StryfeS13
It's Always Broken.
StryfeS13's Avatar
This is all you cut out? So when you welded your tubs in you still had that chunk of your strut tower hanging under there?
Someone needs to start making pre-fabbed tubs for our cars. I know I would buy them.
Gotta love Zilvia.
Old 12-07-2012, 01:33 AM   #327
CleanAndLegit
CleanAndLegit's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
I believe it's in the works.
Old 12-07-2012, 03:52 AM   #328
pancakes562
pancakes562's Avatar
pancakes562 is an unknown quantity at this point
damn just imagine the extreme wheel sizes you could do with those!!!!!!!!!!!
pancakes562 is offline   Reply With Quote
Old 12-07-2012, 07:17 AM   #329
Nismo 240
Nismo 240's Avatar
im not done my tubs are in now and im gonna cut out more
Old 12-07-2012, 09:25 AM   #330
Beejis60
Go to tractor supply; I would call them semi pre-fabbed. They have an arch plus the drop already tacked on. If you cut carefully, that's all you would need.
